Need code for URC-2230 universal remote controller, to control Philips DTR320 digibox.
SOURCE: universal remote
need a code for a philips remote to control a zenith tz
Posted on Dec 27, 2007
SOURCE: i need codes for philips universal remote control
http://www.lexrixa.com/vcr%20codes.pdf
Some kind soul scanned the code book.
Posted on Feb 02, 2008
SOURCE: Olevia remote control codes
Have Olevia 237T with same problem. Bought Universal URC-R6 remote control. Works for TV, cable box and audio system as well. $20 at BestBuy.
Posted on Apr 02, 2008
SOURCE: remote control code
i have a universal remote gemini G610S polaroid tv model TLU-OO1541CU, does anyone know the codes for the remote.
Posted on Jun 25, 2008
VOTIT
  • 2071 Answers
SOURCE: philips universal remote codes for zenith t.v.
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 01, 2008
Total Control Universal Remote. URC 4140. What is the 4 digit code to operate the above TV
Search Results
    [PDF]Total Control URC-4140 - Universal Remote Control Codes
    www.remotecodelist.com/remotes/URC_4140_B00_and_B01.pdf
    UNIVERSAL. Remote control. URC - 4140 ... Your TOTAL CONTROL can operate four devices: a Television, ... The TV, VCR/DVD, SAT and AUX keys select the device.... 4. Enter your four-digit code using the number keys. The red light will blink twice.... To set up your other devices, follow the same instructions above, only.
    Codes and links for a number of universal remote controls, including Sony, RCA, ... GE Remote Codes, General instructions for GE Universal 3 and 4 digit remote controls. ... This manual may work for a number of Philips-Magnavox remotes. ... Total Control URC-4140, PDF Instruction Manual (remote also known as Crest .
Jan 13, 2016 | Sanyo 42 in. LCD TV
Need remote code for urc-3220 remote for phillips-magnavox tv
Here are the codes for the Tv.
Magnavox 0054 0030 0179 0187 1254
Philips 0054 1354
Or you can get the manual and codes on this link below.
http://www.oneforall-na.com/remote.php?type=URC3220
Good luck
Nov 14, 2010 | Televison & Video
How do i put a code in for philips?
I can help you with your URC-1030 Universal Remote Control issues.
The URC-1030 codes for Philips TVs is actually: 1132.
For complete instructions on entering the URC-1030 remote codes, please refer to my posted Fixya Tip One For All URC-1030 Code Entry.
I hope that helps.
_______________________________________________
One For All URC-1030 Manual
One For All URC-1030 Code List
One For All URC-1030 Code Search
One For All URC-1030 Reassign Key
Mar 06, 2010 | One For All URC-1030 Remote Control
Need code for philips vcr/tv combo
I can help you with your URC-3021 Universal Remote Control issues.
I do not see a listing for Philips TV/VCR Combos in the Urc-3021 Code List.
But don't give up; many manufacturer's re-use other's control codes.
Therefore, I recommend using the One For All URC-3021 Code Search feature to find the compatible codes to control your device.
I hope that helps.
Reassign URC-3021 Device Key
Urc-3021 Code List Download
Feb 14, 2010 | One For All URC-3021 Remote Control
How can i program my tv philips-magnavox.
The codes for Philips TVs are:0054, 1454, & 0690.
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
I hope that helps.
Jan 09, 2010 | One For All URC-3021 Remote Control
DVD player code
From the One For All webpage which provides support for your remote, it appears that the URC-4330 does not have the ability to control Citizen equipment.
http://www.oneforall-na.com/advanced_search.php?action=dosearch
I have a Philips universal remote and, according to the support page, it will control Citizen equipment using the code 1908. You may want to consider getting an inexpensive Philips URC. Here is their page: www.urc.philips.com.
Jan 21, 2009 | One For All URC-4330 Remote Control
Remote Control Code for Magnavox mdv-430 dvd player
Yes, a Philips replacement remote should be an excellent choice for your Magnavox DVD player, since they are sister companies. I am using the inexpensive Philips URC US2-PH5DSS and it works well. Your Philips remote will come with a page with all manufacturer codes listed by the type of device. Or you can visit the Philips URC code lookup website at www.urc.philips.com.
The codes listed for Magnavox DVD players are:
0441, 0442, 0447, 0599, 0799, 0699, 0247, 0193, 0093, 0598 You'll have to try them one at a time to see which works best for your player's functions.
Jan 21, 2009 | Philips Magnavox Learning Universal Remote
Televison & Video Logo
Top Televison & Video Experts
