Question about Brother HL-2030 Laser Printer
HOW CAN I REPAIR MYSELF MY 2035 PRINTER DRUM?
  • adicegrani Sep 18, 2010
    as a matter of fact my drum has printed 12500 papers, is there a way how to extend drum's life?
Cleaning printhead Brother HL2035
Ideally the drum should be disassembled, the brush inside should be cleaned (carefully as it will be full of toner and dust), and the drum cylinder cleaned with isopropyl alcohol and a cotton ball (also carefully as it's fragile) if the coating on the cylinder is scratched or worn thin and uneven, you should replace it. When reassembled, clean the corona wire with the slider and ensure the sloder is returned to the resting position.
Mar 14, 2014 | Brother Hl-2035 Drum
There is no HL-2035 listed on Brother's website. Please double check you model number and follow up with me. Why do you want to clean the printhead? Brother Solutions Center Search Result
How do I reset the consumables counter on myBrother HL-2035 printer printer
1.) Turn the printer off.
2.) Hold the 'go' button while turning the printer on. All panel lights should be on.
3.) Release the 'go' button once all lights are off.
4. )Press the 'go' button 2 times.
5.) Pause.
6.) Press the 'go' button 5 times.
7.) The toner light should be off.
8.) The paper light should be on.
9.) Close cover. The ready light should be the only light on.
Once all steps are successfully completed your "low toner" light should be fixed.
Jun 16, 2013 | Brother Hl-2035 Drum
Printer not working
Which type Of problem your Printer.
have u Any type of problem in your Brother Printer Please Call Now-1-855-383-7237
Brother Printer Support
Sep 16, 2012 | Brother Hl-2035 Drum
No CD Rom for 2035 set up can i DOWNLOAD
If you cannot install the driver on Mac OS X 10.7 - 10.9 from the CD-ROM, go to the Downloads section of this website to install the latest drivers. Click the link below to go to theDownloadssection: Download Brother Printer Drivers 1 855 383 7237 Tech Support Printer
Jul 22, 2012 | Brother Hl-2035 Drum
Brother HL-2030 Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
