Question about Nike New Hammer WC0021 002 Watch for Men
How to change band of a digital watch - Nike New Hammer WC0021 002 Watch for Men
Where to buy white polyurethane watch band
This band you will easily get on Amazon, Ebay, Etsy and Discountedwatches247 etc. The Discountedwatches247.com provides beautiful watches and watch bands in discounted price and lots of designs and colors available. You can purchase a cute ladies watch for function, causal watch or a stylish digital watch and many more. These Cheap watches are good quality watches with the latest design and style.
Jan 27, 2014 | Kenneth Cole Kc2461 New York WomenS Kc2461...
Maxum Watch Band X6003L2 - Australia Need a replacement band, but distributor says it can only replace whole watch not band. It is only 18 months old. Any advice?
You might be able to replace the band with a generic watch band (meaning a band that will fit the watch but is not the exact band that it came with) Some good companies would be speidel or Hadley Roma to get the bands from. Just find out the millimeter length (or the size of the band) and you probably could change it.
Jun 26, 2013 | Watches
I have an nike oregon series watch and need to replace the band. i have the replacement band but do not know how to change it.
It looks like the outer steel ring on the back (with the 6 indentations) must be removed before the strap can be taken off. You will need a watch case opener for this - these go for very little money on auction sites. Possibly, the battery hatch needs to come off first.
Jul 17, 2011 | Nike Oregon Series Digital Super Watch...
I have a Casio (593 F91W) and cannot get the pins out to change band. Jeweler cannot get the pins out. What is the secret?
It's likely that your band pins are thin and do not have collars that can easily be grabbed by most band removal/installation tools. If you are already changing the band, the best thing to do would be to cut off the band so that the pins are clearly visible, then use a set of nipping pliers to cut the band pins in the middle. At best, you'll cut them in half; at worst, you'll bend the pins into a "V" that will pull at least one end out of their holes. Obviously, you'll need fresh pins with your new watch band.
Efforts to dig the pins out of their holes can easily damage the holes themselves, making the watch useless.
Apr 26, 2011 | Casio Classic Black Digital #F91W1 Watch...
Can a cloth "sport type" watch band be used on a
mcdevito75 here, As lomg as the watch band, no matter it"s material fits the watch lugs and your wrist, any band can be used. Your answer is yes.
Feb 09, 2011 | Casio Pathfinder AltimeterBarometer...
Broken band
You can go to walmart and they sell bands and also try the flea mkt. They have all different brands that fits your style and even change the pins.
Nov 30, 2009 | Diesel 3 Hand Brown Digital Quartz Display...
I need to change my watch band
Where the band meets the watch - push the band a bit to expose the pins that hold it on.. The pins are spring loaded and will compress with the push from a tiny flat screw driver..
You can get replacement bands at most retal stores..
OR - take the watch to WalMart jewlrey dept and find a band that fits and they will help you chang it..
Good luck ;o)
Sep 16, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
How do i change watchband for casio bg169wh
Take the watch with the broken watchband and place it on the table. With a ruler, measure the width of the broken band at the point where it is attached to the watch. Now, measure the total length of the watchband when it is in one piece and fits around your wrist. There will be a crease on the band where it is normally buckled.
  • Step 2 Go to the local store and select a band that you like. You should make sure that the width of the band at the point of attachment to the watch is the same as the old band. Also make sure that the new band will be long enough and not too long to fit your wrist. Purchase the band and return home to change the band.
  • Step 3 Clear a spot to work and make sure that there is a small towel covering the table top so that you can see anything that may drop or pop out during the process of changing the band.
  • Step 4 Use a magnifying glass to look at the point where one side of the band is attached to the watch. You will see a small pin connecting the band to the watch on either side of the band. Carefully use the jeweler's screwdriver to depress the spring loaded pin from the watch to the band and release it from the watch. When the tension on the spring pin is released it may pop out of the band and you will want to take care not to lose it. Repeat this process with the other half of the band.
  • Step 5 Take the new band and slip the spring pins into the small holes on the end of the band where it will attach to the watch. Working with one end at a time, slip one side into the pin hole in the watch body.
  • Step 6 Use the jeweler's screwdriver to depress the other side of the spring pin and guide it into the pin hole in the other side of the watch body. Repeat this process with the other half of the watchband and other spring pin. You now have a new band for your broken one.
  • Jun 20, 2009 | Casio BabyG BG169WH3V (Size: ) Watch for...
    Change casio g shock resin watch band
    It can be done and not too difficult i think but look out that the leather band ain't too wide for the band orginal place,
    make sure you keep all original parts in case of toruble
    Post a photo if you can after the change will be nice to see the change
    Tom
    Nov 10, 2008 | Casio G-Shock GW500A-1V Wrist Watch
    Nike New Hammer WC0021 002 Watch for Men Logo
    20 people viewed this question
    Top Nike Watches Experts
    Jimmy Accardi
    Electro Med Services...
    Are you a Nike Watch Expert? Answer questions, earn points and help others
