Question about Hilti SFH 18A Cordless Hammer DrillDriver 3445466
Trigger not working - Hilti SFH 18A Cordless Hammer DrillDriver 3445466
    Scholar:
  • Hilti Expert
  • 123 Answers
The SFH 18 is still under the warranty period. If you are in the US contact Hilti at 800-879-8000
Posted on Sep 14, 2010
New purchase. The trigger lock doesn't work to allow you to turn on. What are we doing incorrectly?
The saw may have an interconnect between the choke and the trigger lock, however unlikely. Set the choke, pull in the trigger as far as it will go, then attempt to set the trigger lock.
If that works, undo it all, and try it again with the choke at half position. The trigger itself usually has to be fully squeezed in for the lock to engage.
If that works, undo it all, and try again with only the trigger fully squeezed.
If none of these sequences work, take it back to the place of purchase and ask them for a demonstration on the proper starting sequence.
Mar 17, 2015 | Garden
Keeps repeating itself
Most nailers have a two position setting on the trigger to allow for single fire or bump fire. If set on bump fire, the gun will work better when you bump fire the gun instead of placing the gun on the work then depress trigger. Bump fire works best when safety spring has good tension. Easy test. Make sure that the safety spring is in place (with air hose removed, contact foot should spring back quickly when pushed against work). With air connected, hold trigger and quickly bounce the gun against the work. If the gun does not fire when you bump, the trigger is most likely set to single fire. With trigger set to single fire, you must place the gun against the work, then depress trigger. If the gun shoots two nails while set to single fire, most likely worn trigger or worn out trigger valve. These parts are not expensive and are easy to replace. Good luck
Apr 12, 2013 | Dewalt D51321 3/4" 1 3/4" Heavy Duty Coil...
Broken trigger on dc31
I had the same problem where the trigger doesn't always work (it works if I turn the unit upside down). I've since worked out it's the battery contacts which just needs a bit of a clean. It works now no matter which way I'm holding it.
Sep 20, 2012 | Dyson DC31 Animal Bagless Handheld...
Pull the trigger, no nail, only continuos air until I release tyhe trigger. not jammed, gun is clean, very new. acted that way right out of the box then it worked and then not and so on, worked...
Safety foot and lever inside of trigger are not pushing the trigger pin all the way in. To verifty that the gun will fire, remove the nails to allow for dry fire. Remove the trigger to reveal the trigger valve. Hold the gun against old coiled rubber hose or soft wood. Very quickly depress the trigger pin all the way in. If the gun fires, adjust safety foot and trigger so that the trigger pin is fully depressed when your bump fire. If the gun will not fire after adjustment, remove the head and lube headvalve/orings with silicone paste lube.
Sep 03, 2011 | Stanley Bostitch Mcn150 Strapshot Metal...
How does the framing nailer work with a black button grey button
Dewalt has two triggers available for their framing nailer. The black trigger (390746-00) is a bump style trigger. While holding the trigger, you will be able to fire a nail by pressing nose against work. This trigger is preferred by most framers because it is much faster. Gray trigger will only allow one nail to be fired. Bumping will not work with the gray trigger. With trigger released, you must place the nose against work then pull trigger to fire. To fire next round, you must release trigger, pull gun off the work, again place nose against work then press trigger. Check dewalt web site for recall information. Some dewalt framers have been recalled for faulty trigger. Good luck with your projects.
Aug 11, 2011 | Dewalt Round Head Framing Nailer D51845
Replacement FR350A Trigger PLEASE IE Where can I find One, or something that will work
Trigger from FR350 will work and in stock here:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/portercable/FR350_TYPE_1
Trigger itself however should last the life of the gun. Check the trigger valve to make sure that it is not the problem. The trigger valve is the same for both fr350 and fr350a
Nov 18, 2010 | Porter Cable Cable No. FR350A Rnd Head...
Trigger will not work.
first im sure you have tried this but use a lubricant on the trigger if that doesnt work try unscrewing the case and inspecting the trigger inside for broken or stuck parts you mayneed to buy a new trigger switch
Aug 29, 2009 | Ingersoll Rand Air Tools & Compressors
Hilti SFH 18A Cordless Hammer DrillDriver 3445466 Logo
70 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
