Question about Dryers
Creda Simplicity Tumble dryer manual - Dryers
5 Suggested Answers
SOURCE: tumble dryer Creda Smplicity T320VW
I am an authorized servicer for Creda and I can explain how to remove the front panel to change the belt. Email me at starztruck4u@aol.com if you still need help.
Posted on May 19, 2008
  • 1462 Answers
SOURCE: creda tumble dryer repair
with great difficulty - these belts are so tight!there is a special tool for doing it but there are other ways
one way i have used is to make a spanish windlass from belt to bottom of machine. when belt is level with motor spindle, push belt on and release spanish windlass. could also try levering belt on with a screwdriver
another method is to get a short piece of tubing that will fit over motor spindle. put belt over tube, lever down and slip belt on. this is the best way
Posted on Jul 20, 2008
AlmostBob
  • 550 Answers
SOURCE: how to fit a belt
open case
loop belt around bits
close case
more particularly
Unplug dryer
pull dryer away from wall
remove 1 screw each side at back of top plate
slide top plate backwards and lift off
undo 1 screw each side of front kickplate
tlit front panel up
unplug door switch
set front panel aside
careful of control panel its V.fragile
(I lay the dryer on its back)
pull out old belt and bits of belt
loop new belt round drum at wear marks
pull tensioner to end of travel against spring
loop belt round motor pulley & both tensioner wheels(most creda) 1 wheel (old)
relax tensioner
rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
creda uses hotpoint parts
Posted on Oct 31, 2008
SOURCE: drum wont turn on my creda t622cw tumble dryer
my tumble dryer drum wont go round
Posted on Mar 11, 2009
Creda simplicity dryer
new interlock then .....cheers
Jan 30, 2014 | Dryers
How to fit belt on Creda Reversair 37643 Tumble dryer
New belt is very tight, so you have to use more strength. Put it on motor and all other on "drum". Spin it easily and slowly but with strength until its done.
Be carefully, use gloves.
Apr 13, 2013 | Indesit Hotpoint Creda Tumble Dryer Belt...
Our tumble dryer is not blowing hot air only cold wot could the problem be ? its a creda simplicity condenser dryer - tc 22 cw
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 24, 2011 | AEG T58840 Dryer Electric
Where do i get manuel from for a creda simplicity dryer ! wanna knw easiest way to change driver belt
Check out www.espares .co.uk and look at the advice centre, it contains videos on how to change tumble drier belts. May not be you particular make but they are all similar. Hope this helps
Mar 01, 2011 | Dryers
Hi the door catch for my Creda T522VA Simplicity dryer has broken - where can I get a replacement?
http://www.espares.co.uk/parts/tumble-dryers/doors/creda/t522vw/p/1580/720/0/423760
hope it helps
Jul 05, 2010 | Dryers
Dryers Logo
200 people viewed this question
Top Dryers Experts
