Question about Samsung AS18A6RB Air Conditioner
Compressor is not getting on but fan is working fine and i noticed the fan out air is not hot
  • Samsung Master
  • 17,129 Answers
If the compressor is not working then for sure your AC is not working. So first of all we need to check why the comrpessor is not switched on. Need to check on the thermostat if the relay is activating according to the set data.
If so the comrpessor relay must work or both compressor and relay can be faulty. Check also the capacitor to the motor.
The main controller must give the output to trigger relay, Can be bypassed to confirm status of compressor /relay/capacitor or else the main controller board can be faulty.
Posted on Sep 11, 2010
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
LG model LFX21960ST. No cooling in either fridge or freezer. The compressor comes on for about 7 seconds when first turned on and then will cycle on for a few seconds every few minutes. The fan in the...
There could be a loss of freon(unlikely but possible), the start capacitor for the compressor is bad (most likely) or the thermal cut off switch on the compressor is cycling from the hot compressor.
Mar 28, 2017 | LG Refrigerators
Outside temp was 113, the compressor stoped fan stayed on.Only hot air. Latter in the day compressor and fan worked fine. Should I be concerned ? Thank Mike duo therm 13500 .no heater
It just got so hot that the unit kicked out on high head pressure...
Check the outside condenser coil for dirt... wash it out with soap and water so that you can get maximum air flow through it...
Air Conditioning - Cleaning the Condenser Coil
heatman101
Sep 28, 2010 | Dometic Rooftop RV Air Conditioner
Goodman heat pump stopped cooling
yes, but I would try a "hard-start" kit before replacing the compressor itself
Jul 10, 2010 | Goodman CPLE24-1 Air Conditioner
Getting very hot in the middle betweenthe fridge and freezer
The condenser fan located on the bottom near the compressor is not circulating well enough to keep the compressor at a good operating temperature causing the compressor to shut down for longer periods of time until cool enough to run again. Clean the coils good and replace condenser fan and you will be fine. The fan works as a cooler for the compressor. Imagine working in the yard on a hot day wearing a mask over your nose and mouth. Your body shuts down quicker because you have to take more rest due to the restriction of fresh air. Same applies to the compressor. Hope this helps. Rick
Apr 27, 2010 | Samsung RS2630SH Side by Side Refrigerator
On third compressor. Had the temperature sensor
With the AC on, the fan will come on to help the ac codensor. Why your compressor keeps crapping out is definately something to look into. If your AC is overcharged the head pressures can get pretty high and if the oil is low, that would not help either.. Good Luck.
Aug 03, 2009 | 2006 Chevrolet Equinox
My a/c system is blowing hot air; outside fan is not engaging
First check for line voltage 240v...if thats good .check for burnt wiring at fan capacitor.if you hear the compressor humming but still no fan you may need a fan motor.. when buying your new motor make sure to match horsepower and r.p.m
Jun 22, 2009 | Weather King 10AJA3601AH Air Conditioner
Freezer works Refrigerator will not cool down
The compressor should be OK this time because you caught it in time. But if the condenser fan stops you need to consider replacing the fan. I have had refrigerators do fine until the fan motor warms up and you are away, it stops. Don't think you should use the refrigerator until the fan is fixed. Sea Breeze
Apr 22, 2009 | Kenmore Refrigerators
Maytag Refigerator Condensor Fan not Running
yes it is your getting proper voltage, fan simply went bad, center mullkion was the unit trying to disperse the heat the fan was not able to!
Nov 01, 2008 | Maytag MZD2766GES Side by Side...
Samsung AS18A6RB Air Conditioner Logo
463 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
