Question about Acer Aspire 5500 5570-2609 Laptop
No sounds comming out from my pc speaker - Acer Aspire 5500 5570-2609 Laptop
    President:
  • 2,291 Answers
First verify you see a small sound icon in the Systray . If this icon is missing follow the below section
1. Open the Control panel
2. Open the "Sounds and Audio Devices" icon.
3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document.
4. If you were able to check this box, click ok and close out of this window and the Control Panel.
5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start.
Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reg in out to scan for errors.
Posted on Sep 14, 2010
No sound on my pc?
You can check software issues with the following link.
http://support.microsoft.com/mats/no_sound
Try your speakers on other sound devices to see whether they are working if you use speakers.
Some more reference:
http://windows.microsoft.com/en-US/windows/help/no-sound-in-windows
http://windows.microsoft.com/en-US/windows-vista/Tips-for-fixing-common-sound-problems
Apr 22, 2011 | Acer Aspire™ T180 PC Desktop
No sound
There are a number of different reasons why your computer may no longer give sound.
Check the Speaker Connections and Volume Control Settings
Verify that the lack of sound is not due to faulty speaker connections. A simple way to test it is to substitute the speaker connection with headphones and see if you get any sound.
Read more: How to Fix a No-Sound Problem From Computer Speakers ' eHow.com http://www.ehow.com/how_2225072_no-sound-problem-computer-speakers.html#ixzz11nkQCSL4
Oct 08, 2010 | Computers & Internet
Sound is staticy for both internal speakers and external speakers through the headphone jack
Let verify first to narrow down to where the problem can be, attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find. You may be better off if the sound does work through the PC speakers, to get the TV repaired; it will be more than $100 and up.
Parts: www.shopjimmy.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 07, 2010 | RCA L42WD22 42 in. LCD Television
I have a new PC with Vista installed. BA 745 do not work.
check to make sure you have the speaker icon in the bottom right hand corner. If you do, see if you can move the sound bar up and down. This will verify that you definitely have the right sound drivers installed and they got installed properly.
Make sure you have the speakers connected properly. Here is a setup poster to show you how. Follow this just to be sure
http://supcontent.gateway.com/support.gateway.com/s/SOUND/speakers/7003709/700370935.jpg
Once you verify this and the sound still doesn't work then it could be a problem with the speakers or the sound card or sound chipset (if you have integrated sound on the motherboard).
To verify whether its the sound card or sound chipset on the motherboard or whether it could be the speakers. Put the speakers on another machine that you know has the sound drivers installed and turn up the sound bard in the operating system thru the speaker icon. If you get sound then its a problem with your other computer. If you still dont' get sound then the sound speaker system is bad and would need to be replaced.
Jan 14, 2010 | Boston Acoustics BA745 Computer Speakers
External speakers don't work but internal speaker works fine.
Try your speakers on another system to make sure speakers are working.
Make sure volume control on PC is not set on mute.
Make sure onboard sound is enabled in BIOS
Try re-installing the sound card driver.
If all this fails and you have a spare slot on your PC just purchase a new sound card for about $10.00 or so.
May 21, 2009 | HP RT987UAABA - HP Compaq dc5700...
How do i reinstall my dell speaker? i deleted them off cp. my bad
The speakers are not the sound device, the sound card is. You ust select the sound device that is installed in the computer. If you PC is a Dell, go to Support.dell.com and enter your service tag in the downloads section. download the latest audio driver for your PC and it should reset everything to the correct parameters.
Good Luck!
Jan 05, 2009 | Dell A215 Computer Speakers
No sound comming from speakers for monitors
it could be:
  • the sound has been muted,
  • you need to re-install the sound driver for the sound card or chip, un install first
  • make sure you have the speakers plugged into the green socket and it is turned on ,most speakers have a small light that comes on when the power is on
  • the sound card or chip has died.
good luck & please rate my efforts
Terry
Apr 05, 2008 | Computers & Internet
No Sound Now on Computer
Might be trivial, but try the volume controls, that little speaker icon on the Windows task bar.
Dec 28, 2007 | Acer Aspire™ T180 PC Desktop
Acer Aspire 5500 5570-2609 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
