Question about Roper Washing Machines
Hello, my roper washer filled up with water but will not do anything else.
    Problem Solver:
  • 10 Answers
Check/replace the lid switch - modern Roper machines are direct drive. You can bypass the switch (join the contacts with a conductor) but it is a safety feature for a reason.
Posted on Sep 11, 2010
Testimonial: "Thank you soo much! It worked! God bless you! Jesus loves all and wants us to live for him. Praise God!"
  • sunshine_363 Sep 11, 2010
    Thank you soooo much! It worked! God bless you! Jesus loves all and wants us to live for him! Praise God!
My Roper heavy duty 8 cycle 2 speed combination washer does not fill up on rinse cycle
when in rinse washers use just cold water so clothes don't wrinkle,try this,set the washer to just cold,start it and see if it fills or fills slowly if so you have a bad water valve on washer or no cold water going to washer.
Dec 04, 2017 | Roper Washing Machines
Washer won't run to do wash cycle
Don't worry about that "fuzzy little belt" ;) I mean - just toss it.
If the motor runs but the agitator is not agitating - check the coupling, the two plastic thingies and a piece of rubber between transmission and motor.
If it will not do anything after filling up - the problem is electrical, and it can be anything from the water level switch to timer to motor... The schematic diagram is inside the control panel. To open the panel remove 2 phillips screws holding control panel's side plastic caps. The screws are in the back. Good luck! %)
Mar 04, 2010 | Roper RAS8445KQ Top Load Washer
Have a roper ax6245 - cold water will not shut off even with washer turned off - HELP
Hello,Sounds like a problem with either the inlet valve or the pressure switch, the way to determine which is bad... while the machine is filling pull the power plug..if the water keeps filling it's the inlet valve that is going to be bad..if it stops filling it's going to be the pressure switch. The pressure switch is located in the control panel and has a small rubber pipe attached.once you have figured which it is replace it good luck.
If you have any other questions or concerns please feel free to comment again..Mike
Oct 14, 2009 | Roper RAX4233PQ Top Load Washer
Roper washer fills with water continuously
Your inlet valve is defective, can be easily changed. Approach your dealer with your model number he will direct you to the spares shop, or tell you where you can get it. Or google 'roper washing machine spares'
Feb 23, 2009 | Roper RAS8445KQ Top Load Washer
Roper Top Load Washer Does Not Fill To The Top on ''Extra Large''
the water level switch can be adjusted to raise the water level but is not recommended. The level you have is normal.
Jan 24, 2009 | Roper RAS8445KQ Top Load Washer
Roper washer ras6233kq
Hello, So unit should fill with water though right? Just no spin and drain. more than likly you have a bad lid switch. look and see if there is a hole somewhere on the frame. usually on the lid you will see a actuator that plunges into the lid switch. When you close the lid you should hear a click if there is no click you a bad lid switch.
Dec 24, 2008 | Roper RAS6233KQ Top Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
ROPER RAS6233KQO T.L.W.-Won't fill/rinse with cold water
Most washers have a small screen at the water inlet valve. They can be accessed simply by revoving the hose from the back side of the washer, using a small screw driver you can carefully remove the screens and clean them out under a faucet.That may be all that is wrong.
Oct 27, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
379 people viewed this question
Top Roper Washing Machines Experts
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
