Question about Blanco Plumbing
I have a Blanco BM5300 "Eye" tap and need to change the cold ceramic washer. I have got a replacement washer but can't see how to remove the tap handle from the old washer which presumably fits over the end spline of the washer. Does it just pull off - as I can't see any fixing screw?
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
There are several other methods.
Pop out a screw-cover cap on the end of the top of the handle.
Unscrew the base of the handle.
Unscrew the lever off the handle.
Pop out a small setscrew cover plug on the side of the handle under the lever. Hope this helps.
Posted on Sep 11, 2010
I have secondhand blanco monoblock tap and don't know which is hot and which is cold
there is normally a grub screw which shows the back of the tap? or a name on the front of the tap, once you find this you need to use the theroy hot on the left cold on the right, thats once you have decided front and back.
Jan 21, 2013 | Plumbing
Blanco Eye Kitchen tap cold water is leaking from tap[ WHEN TURNED OFF. I have remove the allen screw that secures the the cold lever but I cannot remove the leaver
Hello doy.. get a can of WD-40 penetrating lubricant and spray it on the seam connecting the lever and the body. It will penetrate within an hour or so. Repeat if necessary.
Also use a plastic head or a rubber head hammer to tap it up.
Joe
Thanks for choosing Fixya!
Mar 12, 2011 | Blanco Plumbing
How do I replace a cruciform tap washer
There is no washer in that tap it is a ceramic insert which you will have to order from manufacturer or elsewhere.
Turn off the water supply, unscrew tap actuator (knob) (remove screw and pull), there will be a large nut to undo....undo it and withdraw the insert. Cleaning it thoroughly may help. it's worth a try as there only has to be a small impediment on the ceramic and it will leak.
A picture is worth a thousand words, I believe this may be your tap
http://www.abodedesigns.co.uk/downloads/ATLAS%20MONO%20PARTS.pdf
hope that is helpful.
Jan 25, 2011 | Microwave Ovens
I have a Blaco eye BM 5300 tap and need to get the handles off to replace a washer. The setscrews have been removed but the tap handle seems firmly in position. Is there something else that needs to be...
Be very careful. I had a plumber help be and we ended up breaking the value with the bit stcu inside the handle. I managed to source a new handle, GBP12 plus VAT, but can't get hold of the valve!
Jan 21, 2011 | Blanco Plumbing
Our Blanco Cleo 6100 Cruciform Monobloc tap is dripping & I think it has a ceramic disc valve as opposed to the more common tap washer. Is it possible to replace the ceramic valve & if so...
The tap is a Blanco Cleo BM/6100 tap.
The cost for a pair of valves is £41.51 including postage and VAT, the cost for one is £25.97.
Scott Lindley
Blanco Customer Service Manager
Top Brassware Ltd
T- 01709 819077
F- 01709 798888
E- scott@topbrassware.com
Top Brassware Ltd
Unit 3E Aven Industrial Park
Tickhill Road
Maltby
Rotherham
S66 7QR
Jan 07, 2011 | Microwave Ovens
The tap is leaking it appears at the bottom of the tap where it meet the sink it is a hansa single handle with vegatable sprayer with a ceramic cartridge
Hi, there are flexible water pipes that scew into the bottom of the tap, one of these could of come loose; try tightening, or the washer may need replacing.
Hope this helps
Jul 21, 2010 | Blanco Classic Single Handle Faucet with...
Leak from blanco aderlphi tap above sink line may be a washer required
this could be a leaking cartridge or more likely a likely a leaking o-ring that sits around the base and seals the joint between the spout and the base
Jul 01, 2010 | Blanco Plumbing
How to replace cartridge on blanco single handle
Somewhere around where the handle fixes to the tap should be a grubscrew of some kind undoing this will allow the handle to be removed this will give you access to the cartridge which can then be removed with the correct socket, obviously you will need to turn off the water supply to the tap first!!
Jan 25, 2009 | Blanco Classic Single Handle Faucet with...
Plumbing Logo
1,824 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
