Question about Hotpoint Freezers
We appear to have a blockage in the pipe that takes liquid from the fride part of our FFSS70 model. Because of this we get water forming in the bottom of the fridge each day.We have tried all ways to try to clear the ice that appears to have formed in this pipe which is inaccessible. Could you please help with this. Thanks Bob Skelt.
  • Hotpoint Master
  • 3,740 Answers
Hi Bob. First off let me say that a clogged compartment drain with ice in it can be a real pain. Portable hair dryers don't work because the water insulates the ice. You may not like the answer here but this is several decades of hands on exerience speaking. So here goes......
1. Unplug the unit.
2. Empty the contents of the freezer
3. Place a fan blowing into the freezer section for well over 2 hours.
(THIS MAKES A MESS so be ready with rags and a mop)
<After external fan period and mess period>
4. Get yourself a single strand of #14 gage household electrical wire with insulation. Strip the end of the wire about 1 inch on the very end of the wire, fold it back on itself so that there is not a sharp end. (Flat tight U Loop) and start pushing it through the drain. If you hit any blockages or elbows try bending the loop just slightly. (Just do not force it really hard as you may detach the drain tube from the freezer compartment. Measure the distance that you have traveled the wire through the drain. It is pretty much a straight shot top to under the bottom of the chassis at which point there are some bends. Once you know you have reached the bottom of the chassis... pour HOT water thru the drain and observe the lower catch tray in the bottom of the unit checking for water flow from the tube. Often the plastic tray in the bottom of the unit has water in it just as a result of normal defrosting. The end of the cabinet drain tube sits in that tray. Over time the dust and lint that collects forms an ugly goo in the plastic tray. That goo eventually dries out and can also encapsulate the end of the drain tube. Make sure to clean the drain pain and the end of the drain tube during this process.
If you have problems and there is water in the drain that you need to remove; a roast baster works pretty good for removal of the water near the drain.
While you have it manually defrosted do your best to clean the drain top and bottom. These 2 areas are where most blockages occur.
Once your all done cleaning... wipe the bottom catch tray dry.
Pour a measure amount of water 50 ml or so in the top drain.
Check to make sure you get 50 ml at the catch tray. If you do not get close to what you put in.. at least 45 ml. Then there is a problem with the drain tube. i.e Hole, pinch, fold etc.
Getting the unit to room temp... (Fan) and letting the room temp defrost the ice in the tube is the best way to clear this. Slow process but a must do. There really is not a fast way to do this. If you don't have access to a piece of wire... a larger LONG plastic ZIP / Cable / Spot tie (Like they use for handcuffs) will work well also.
Just a final note. I looked up your unit parts via Hotpoint UK.
http://www.hotpoint.co.uk/hotpoint (Model FFS70S)
There are 116 parts available and the drain is not listed.... be careful.
Thanks for choosing FixYa.
Kelly
Posted on Sep 11, 2010
  • 4,793 Answers
Use a meat syringe to blow it out with neat clorine bleach....
Freezer insulation
Could you fit a trace heater inside the drain tube to keep the ice from forming? Or extend the dripdown time after defrost cycle so the water doesn't accumulate? If the tech thinks the insulation has blown, it may be time to bite the bullet and replace the fridge.
Apr 18, 2014 | Freezers
Cause for burning smell from lower back of upright freezer
your freezer might be having blockage on the drain pipe thus not allowing water to flow on the drain tray if the drain tray is mounted on the compressor and its dry then the compressor or the condensor pipes are burning the drain tray. the solution to this problem is to service your freezer
Jan 23, 2013 | GE Freezers
Ice forming on copper pipe coming from compressor
Hi, It is not uncommon for the suction line on a unit to have ice on it when cooling. This means that where the ice starts forming on the line, there is liquid freon there. But, if it continues to get worse, would indicate a problem as you don't want liquid freon to enter the compressor as it will burn out the valves, or slug it as we say. Icing of this line can be from a few things. Low on freon will cause it to ice up. The freezer fan/evaporator fan motor not working. The freezer iced over real bad. An over charged system will do this, but you haven't had to charge it. Check the fan I mentioned and keep an eye on this line and monitor the units temperature. If you start to loose your cooling then we need to go from there. I can't prevent it from forming ice unless I was on site to install my service gauges to check the internal condition. Please keep me posted though. If the freezer fan is not running, this would be the problem and would need to be replaced. If you had excess to a volt meter and it wasn't running, you could check power to this motor. Let me know if it is not running and check the temperatures closely.
Good Luck,
Shastalaker7
Mar 09, 2010 | Freezers
Whirlpool model ET18PK not cooling
You have either got an internal leak or there is a bolckage in the system. switch off as soon as poss. as the gas is what keeps the comp. cool.being low on gas , comp.will eventually burn out. Quick check so that you have nothing to loose. (inspection for blockage). Look for the copper drier .At the back by the compressor. It has a 1/4 inch copper pipe on the one side and a very thin pipe on the other. Flex the thin pipe until it breaks. If gas pours out of the broken area. then its a good sign which Indicates a blockage. Decide weather it would be worth it to regas. If no gas comes out or very little, almost certainly it is an internal leak. In that case look for something else.
Sep 20, 2009 | Freezers
Compressor is running, but is not getting cold. evaperator fan is not running. freezer has been sitting unused for awhile. can feel one pipe getting cold but nothing beyond where it goes into a part I dont...
Ok often when fridges and airconditioners have not been used for a time the liquid that gets compressed becomes thick and sludgy. This sludge is like cholesterol in arteries. That is what is happening in your system.
In essence it needs a service to recapture the liquid gas and refill after cleaning.Especially the control valve
You could try a quick fix by turning the unit upside down ( if that's even possible in your situation) this often relieves the blockage by gravity,allowing it to be returned to the bottom of the tank. The restarting allows the circulation to start again and will eventually start to work correctly. However this is often only a tempory fix and will require a service intervention to replace the valve that may be stuck closed and have the problem occur over again.
if you can see the valve, a thickened cyleinder somewhere on the cold pipe you might also want to try tapping it with a rubber mallet to see if you can unstick the valve.
even in the middle of winter the A/C should be run for a few minutes every week to ten days just to keep the liquid gas from becoming thick and sludgy. This applies to your car A/C as well
Aug 09, 2009 | Frigidaire Freezers
Frigidaire side by side: water fills up in bottom of freezer
You have a blockage in your drain tube, at the bottom of the metal tray there is a hole which is connected to a tube which runs down the back of your refridge to a pan next to the compressor. It is an easy fix have done this 1000's times. Remove back panel in freezer, grab a heat gun or hair dryer and melt the ice it the bottom of tray. Clean the water in the tray with some paper towel next get some hot water in a measuring jug and pour into the pan(hot water will help melt ice in tube) repeat this process a couple of times and then get a curtain wire or something flexible to push down the pipe to clean the blockage...you will know when the blockage is clear because the water in the pan will suddenly drain off....put cover back on...make sure to unplug appliance before servicing...hope this helps :)
Jun 22, 2009 | Frigidaire 17.8 cu. ft. / 504 liter...
Small puddle of water won't drain
make shure the strainer is clean
there could be a partial blockage in the pipe
make shure the drain pipe isnt kinked
Mar 18, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Proline Freezer upright /not freezing down very well
Defrost it and see if you have lost the insulation aroundthe pipe. If you have you can use expanding spray fome insulation on it. like you use on your house.
Dec 27, 2008 | Freezers
Freezers Logo
454 people viewed this question
Top Hotpoint Freezers Experts
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Ken Wieczorek
Ken Wieczorek
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
