Question about Canon LBP5000
Out-of-Register Colors Correction has not been performed
  • 59 Answers
Hi to all! I have solved this problem. If you interested for please contact me on: adzicc@yahoo.com
Posted on Dec 07, 2010
Canon lbp5050 printer out-of-Register Colors Correction Error
So your mean is changing of all 4 cartridges istead of charging them Krishnan ? Do you have an experience with compatible cartridges or you say they must be replaced with 4 new original cartridges ?
Oct 22, 2012 | Canon I-Sensys Lbp5050 Laser Printer
Out of register color correction
1st option is also right go for solution.
2nd is Patch sensor, laser dirt, hvt, or ITB unit..
Oct 02, 2012 | Canon LaserShot LBP5050N A4 Colour Laser ,...
Hp photosmart C4180 all in one. I want to set black (greyscale) as default. I can't find where to do this. Can you help?
  1. Click start-->Control panel--> Printer & faxes.
  2. Right click on printer icon and click "Properties".
  3. You will find an option to select "print in greyscale" under one of the tabs.
  4. Else, if you dont find there, click "printing Preference" under general tab and check.
Regards
Riztech
Dec 04, 2010 | Office Equipment & Supplies
My xerox phaser 8560 is printing muted color
First off on your screen access troubleshooting, and perform the remove light strips and also remove smears and skips.
Next go to Xerox.com, under support and drivers enter 8560 in the search box. then go to the support page.
You want to look up the procedures for TEC color correction. And follow those steps.
If you are using a generic ink then, all bets are off in getting true color reproduction.
Feb 10, 2010 | Xerox Phaser 8560DN Printer
Canon LBP 5000 Out-of-Register Colors Correction has not been performed. Happens with two different new yellow cartridges. Put the old one in and it is fine. Have changed the other cartridges and they seem...
Ok, Contact me on mail for solution of this problem. I solved this Canons **** software problem in this LBP-5000 printer.... my e-mail address is: adzicc@yahoo.com
Aug 24, 2009 | Office Equipment & Supplies
Phaser 8560 Colors are Off
Here are the directions for Tec Color correction. If this doesnt work then replacing the print head is the most likely solution. The TekColor correction options provide simulations of different color devices. Automatic is the default correction for general image processing. Use the following table to determine what option you want to use. TekColor Description Automatic Applies the best color correction to each graphic element: text, artwork, and photographs Office Color sRGB Display: Approximates the colors on a computer display. sRGB Vivid: Produces brighter, more saturated colors than sRGB Display. Press Match SWOP Press: Matches specifications for Web Offset Publications. Euroscale: Matches Fogra glossy paper specification. Commercial: Approximates U.S. commercial press target. SNAP Press: Matches specifications for Newsprint Advertising Production. None Applies no color correction. Use with other color management tools, such as International Color Consortium (ICC) profiles, ColorSync, or the PANTONE Color Chart for the printer. Black & White Converts all colors to shades of gray From the workstation, select the color correction in a supported driver. Microsoft Windows 98 SE / ME / 2000 / XP/ Server 2003 / NT 4.x Operating Systems (OS): NOTE: Some of the color corrections are grouped under Office Color or Press Match. 1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed. 2. Click on the [Properties] button located on the top, right of the window. The Properties window will be displayed. 3. Click on the [TekColor] tab. 4. Select the required color correction. Apple Macintosh OS 9.x: 1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed. 2. Click on [General], and then select [TekColor] from the pull-down menu. 3. Select the required color correction. Apple Macintosh OS X, (version 10.2 and higher): 1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed. 2. Click on [Copies and Pages], and then select [Image Quality] from the pull-down menu. 3. Select the required color correction.
Jun 08, 2009 | Xerox Phaser 8560MFP Laser Printer
Can not perform out of register colors correction
I have a similar printer, canon LBP 5000, with the same problem.
I contacted Canon guys and explained them the problem. This is what they said:
this problem occurs in either of the 2 situations:
1. when your colors/toners have gone or nearing empty.
2. when you have REFILLED your cartridges.
Solution:
Need to replace cartridge (which costs really tooo much).. its sad!
For me it was the first case, but, un-really-fortunately, I REFILLED the cartridges (this is al b4 contacting canon guys). And still the problem persisted (so now even the 2nd case).. After finding out that i will have to replace the cartridges.. i'm really confused whether i should do it,, or buy a new printer instead.! (since i've already spent and wasted quite a lot of amount in refilling the colors :( )
So, please DO NOT refill the cartridges if u god-forbid come across this problem ever. Go replace the cartridges. (unless n until someone else comes up with a solution atlast!)
Thanks,
Krishnan a.k.a krislogy
Mar 11, 2009 | Canon Office Equipment & Supplies
Canon LBP5000 laser colour printer. Problem: 'Out of Register Colors Correction has not been performed. Perform calibration again'. I have carried out this instruction so many times, the error keeps...
Had the same problem a while ago.
In my case it was simply that the plastic tab had come away from the plastic strip you're supposed to pull out from from the cartridge before installing. Found the end of the plastic strip and pulled it out and this sorted the error.
An additional problem we had was alignment of the colours when printed. Magenta and black were misaligned by about 0.5mm after changing a cartridge. This was cured (after much frustrated cleaning/calibration) by switching the printer power off and on (couple of minutes to cool down).
Hope this helps.
AJ
Nov 16, 2008 | Office Equipment & Supplies
Color printing problem~only green, yellow, blue
TekColor
Description
Dec 05, 2007 | Xerox Phaser 8500/DN Printer
The Picture is filled with rainbow colors
Hello Big Sav,
It sounds like you have a Convergence Correction IC problem. This problem happens quite often and is fixed by replacing the ICs and the biasing resistors. There are many articles on the Internet about how to do this yourself. Here is one:
http://www.digitalhome.ca/forum/showthread.php?p=564268#post564268
I should mention that, If you do not have a background in electronics you could do damage to your TV by performing this procedure. I you feel that you can not perform this procedure properly have a qualified technician perform it or have the board serviced at a TV repair shop that specializes in board repair.
I hope this helps,
Thank you,
Shuttle83
Feb 03, 2007 | Hitachi 42V710 42" Rear Projection HDTV
Computers & Internet Logo
658 people viewed this question
Top Canon Computers & Internet Experts
Aashish Chaudhary
Aashish Chaudhary
Computer Links
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
