Question about Pool & Spa
Hallo, I have a jupiter sand tilter type 14. I would like to replace the sand inside. I have taken oof the glass on the top and released the screw cap from the bottom to let out the water. My problem is that the jets inside the top don't move I had hoped to flush the sand out through the water outlet at the bottom but very little happens even when I put a hose pipe inside. Help please.
    Sergeant:
  • 192 Answers
The only way I've heard of or have been able to do myself is to scoop the sand out, or when the sand is dry, you can use a shop vac.
Posted on Sep 11, 2010
My sand blast box glass is frosted
The glass has been damaged from the sand and will need replaced. Many companies offer cheap replacement windows along with stick on protectors for the inside that you can change when it gets frosted. We change our stuck on protector at work about once a month find the brand and look them up online for parts
Feb 22, 2017 | Cars & Trucks
Can grains of sand be used for fuel?
No sand is merely a fine silica glass and is inert.
Putting it in your fuel tank will wear out your engine in about a week.
Nov 18, 2015 | Miscellaneous
How do I clean inside of glass on door of AMV5164BAQ?
You can use normal glass cleaner or bleach with anything but metal abrasive pads
Mar 02, 2015 | Amana AMV5164 Microwave Oven
Is there anyway to remove scratches from inside glass on inside oven door of a Wolf?
There isn't any safe way to sand down glass by yourself. If the scratch is really bad, I suggest contacting Wolf for a replacement glass. Here is their site for replacement accessories.
Feb 22, 2013 | Wolf Range 24" Natural Gas Range w/ 4...
Sand on inside of cups and glasses on top rack of dishwasher
it souds to me like lime scale detaching its self from the heater element.
try calgon, it should fix it
Jun 03, 2012 | GE 24 in. Profile PDW7880G Built-in...
How do you use the Yamaha CSAT-930 Tiered Cymbal Stand Attachment?
Take the tilter off your existing Yamaha (700 or 800 series), attach the CSAT930, and place the detached tilter onto the CSAT 930. There is a set screw on the CSAT930 and you would disconnect to place your cymbal (or hihats) allowing you to stack another cymbal on top.
Feb 04, 2012 | Food Mixers
How to remove spark plugs. 2006 buick lacrosse cxl.
The front spark plugs should not be a problem. The rear are accessed with use of an "engine tilter". It can be purchased at many auto parts businesses, I purchased mine from NAPA. However, you may have to order one on-line as it is "an unknown item" as many of us are unaware that it even exists and I am sure that the mechanics and techs want to keep it that way. My cost in 2009 was in the $35 to $80 range for the tilter. It may sound a little scarry using it because you loosen the upper (literally right up on top where they are most easily accessed) mounts, but it is easy. I found that no electrical, air flow from filter, exhaust, etc., had to be loosened or removed. You only remove one side and install the tilter. Next you adjust the "tilter" to remove tension on the other bolt. Finally, simply screw the adjuster toward the front of car until you either have enough room to access the rear plugs or until you run out of bolt threads at which point you have as much room to do the job as any tech/mechanic. As usual, remove the old plugs (I only do one at a time which also eliminates crossing plug wires) and screw the new ones in several turns by hand to make sure that there is no cross threading. Once you are satisfied with your level of maintenance, simply adjust the "tilter" back to a point where the loose motor mount accepts the bolt to front frame, tighten it, remove the "tilter" and reinstall the second bolt. It really is that easy, but you will want to protect your paint with a proper cover as you do have to lean heavily against the fender or fenders. Oh, by the way, many mechanics skip the difficult-to-access plugs, knowing that when they, or it fails, you will be back. Enjoy, you will feel like a real pro, knowing that your job was done correctly and is complete!!!
Feb 13, 2011 | 2006 Buick LaCrosse
Cleaning inside glass door, kitchenaid range
you do no tneed to remove the top to release the glass, yea aslong as the lower trim is removed then the only thing holding the glass, is the grease/sticky rubber gaket. lift up from the bottom slightly and twist out from the tabs. just be carefull when cleaning inner door glass, those "ridges in the paint, are just that paint, so dont use anything abrasive, youll ruin the finish!
Oct 30, 2008 | KitchenAid KGST307 Gas Kitchen Range
Will not take picture
Some digital SLR camera have a mirror lock and others have a viewfinder shutter In each case this will be a knob in the region of the viewfinder that turns. Check that this model has it and it has not be inadvertently turned. Then come back
May 21, 2007 | Nikon D70s Digital Camera
Pool & Spa Logo
43 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
