Hi.
The Ignis dishwasher does not need reset code. It will normally restart working after tripping the circuit breaker.If the machine is beeping, that means that the dishwasher is in fault mode because some fault condition is detected. Among conditions that can cause the issue, residual water inside the machine, clogged drain, arms jammed.
Try disconnecting circuit breaker and drying water from the inside, also remove the drain well and clean it. Eventually carefully pour some hot water intor the drain well, inside the machine tub.
Connect back circuit breaker and try restarting the machine.
Here a forum on similar problems.
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. The drain pump can be clogged and refuse to work as it hums. If so remove and clean the drain pump, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated.
Cleaning a pump:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Thank You for using fixya
Hi thanks but solved problem by holding down start key then pressing one of the washing modes that stoped the alarm and I could then get access to all functions
