Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
How to connect usb hard drive to aquos tv - Sharp Aquos LC-46D62U 46 in. LCD HDTV
How do I download latest firmware onto my Sharp Aquos LC-52LE640U?
hi does your tv have usb port if so, go to the sharp website look enter the model number of your tv look for firmware for your tv download it, then load it on to a usb flash drive, thanks
shaun
Mar 16, 2017 | Sharp LC52LE640U 52 inch 120hz AQUOS LED...
How to connect wd external hard drive to sharp aquos tv?
I am not specifically familiar with Sharp Aquos TV but this procedure should work on ALL TVs with USB ports. What you should start with a USB flash drive. Format if for NTFS file system. Add a few video files with mixed containers like mp4, avi, mkv. Also make sure you have a mix of codecs like mp4, AVC, AAC, xvid, etc. Attach it to your TV. Now check your TV if the files show up on your TV's listing. If they don't try again with the flash drive formatted as Fat32. If this works fine next thing to determine is driving power of the USB port.Connect a drive which draws under 500 ma. If this does not work you will have to get a special cable with dual USB connector and use a smartphone's charger for powering it or use a drive with external power supply. I think this should give a general idea.
I have come across TVs that won't support file size greater than 1 GB. Some like Sony that won't support any kind of compressed container. TVs sold in he US will not support xvid but those sold in Canada do. The one I own is a Samsung which supports absolutely everything under the sky with sufficient power to even support 1 TB drives that have difficulty on the PCs.
Sep 02, 2014 | Computers & Internet
Beeoing noise and wont connect to television
the tv usb is not able to read all drives....drive size and formats are different per tv maker..
secondly you need to supply external power to the.... tv usb connection do not supply enough power(usually only 500ma) to run hard drives
Nov 17, 2013 | Akasa integral P2N black, USB 2.0...
I COULD NOT ABLE TO SEE THE MOVIES OR SONGS OR PHOTOS FROM MY DRIVE WHEN CONNECTED TO T.V,BUT IF I CONNECT IT TO A COMPUTER VIA USB I CAN READ ALL THE ABOVE, PLEASE TELL ME THE SOLUTION HOW TO SEE THE...
The problem maybe is that your T.V. does not recognizes large space of hard drive. You can try to use a smaller storage like USB Flash disk or Memory Card.
Sep 16, 2011 | Samsung HM251JI 250 GB SATA Hard Drive
Can I connect a USB memmory or an USB HD in the USB port (SERVICE)? Can I use this port? Mi TV is an LC32DH57E
Yes you can use it to view the media files on the flash drive or even play media files from mp3 that has the port.
Jul 16, 2011 | Sharp Aquos LC32DH57E 32 LCD TV
How to make WD MyBook essential 1Tb work on sony bravia EX300 LCD TV ? I tried to connect the external hard drive on my sony dvd player and it appears on the tv screen that the USB device is not...
this will not work by it self you will either need to buy a computer with media software that will support your hard drive or a DVR that will support you hard drive.
the hard drive connected to the device you have tried to connect to are not smart devices they will not support a stand alone external drive even though there is a usb port.
Mar 17, 2011 | Western Digital My Book Essential 1TB...
How do i set up my internet connection for my sharp aquos 42 inch
you can't there is no input for a network connection or a usb WIFI
Mar 01, 2011 | Sharp Aquos LC42XD1E 42 in. LCD TV
I wondering only,how to connect my hard drive to the LCD TV
Hello.
If you have an external usb hard drive and usb ports on your tv just plug it in. Sometimes the menu for usb drives pops up. If not, try to press source or input select, input on your tv remote. You must see your drive name in the list. Just select it and you should be able to access your hard drive.
Hope this helps!
Feb 13, 2011 | Computers & Internet
Aquos screen blacks out with xbox 360 using Component Cables
Downloaded the updated firmware from the sharp website to a usb drive. Placed the drive in the TV and went to the update software option on the TV menu. Since the update, I no longer get the black-outs on the screen. I also put the resolution on the 360 back up to 1080p and it works great, even through the component cables.
Jun 29, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
777 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
