Question about Dryers
Ineed manual for LG Clothes Care 7kg TD-C70043E fully automatic clothes dryer
4 Suggested Answers
  • 142 Answers
SOURCE: LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Posted on Sep 28, 2009
Washer_tech
  • 164 Answers
SOURCE: Tumble Dryer not drying clothes
the problem could be several different things. first remove the front panel and see if the globar glows. if it doesn't check it for cracks and replace if needed. if it glows, replace your gas coils, they are usually the problem
Posted on Nov 01, 2007
gotgeek2
  • 565 Answers
SOURCE: Dryer is not drying clothes fully.
As long as the dryer doesn't have electronic controls, this very common symptom indicates a bad(open) heating element.
Posted on Jan 25, 2009
LG TD-C70040E Automatic Clothes Dryer. The diver closes the cover and forces it to work and makes noises
call a good repair service locally,perhaps they will understand what you say
Apr 21, 2018 | LG Dryers
It only wash & don't spin? Then it stops and leak water by the door....
LG Washer & Dryer 7 (WD12331AD)
Its is a direct drive front loader with 7kg capacity for washing and 3.5kg capacity for drying.
when new
thats 7 kg with wet clothes and water
and only 3.5 kg wet clothes to dry
the older it gets the less weight it can wash and dry
worn motor or drum overload if it doesnt want to spin at all
leak at the door . replace the door seal ..is a most common fix
extra info
It has 9 preset settings, 400 - 1200 RPM, 5 temperature settings, digital display and delayed start timer.
Sep 20, 2016 | LG Washing Machines
I have an LG WD-1457RD washer and dryer and it shrinks all of my clothes, Possibly Temperature problem?
Very few driers have temperature controls. The best way to stop this happening is to run it for less time. Take the clothes out when they are still very slightly damp. If you hang them up straight away, you will find that most wont need ironing. Some dryers allow you to set the amount of moisture in the clothes when they shutoff, but they generally are the most expensive ones.
May 16, 2016 | LG Washing Machines
Broken belt for clothes dryer LG
Remove the front panel .. two screws probably.
Look for the belt tensioner on the floor when you get it open.
Mar 28, 2010 | Dryers
The check filter light is on. The clothes are not
The check filter light, is default message LG was put in place. No problem there. As for the clothes, I'd need some more infomation, what settings are you using on your dryer? I'll need to know if your using sensor dry, or manual dry.
Jan 30, 2010 | LG DLE5932W Electric Dryer
Dryer puts holes in clothes why
very care fully run your fingers along the inside edges of the tumbler both front and back
obviously your searching for something that is cutting your cloths so be care full it will cut you too
with the ge, i would tend to believe that your tumbler might be off or have worn though your front slides, they are made of nylon and fall out of place
check behind the door twords the top
Oct 25, 2009 | Dryers
LG TD C70045E problem
Fluff has blocked the drain hole into the water drawer.Try locating the hole and using a small bore plastic tube **** the debris out of the container.
Feb 21, 2009 | Zanussi TC7102W Electric Dryer
Lg tumble dryer td-c700453 all lights working just not drying clothes and drum turning round
turn the power off and pull the dryer out and take the back off and press the red button in at the back
Aug 06, 2008 | Dryers
On sensor dry, dryer remains at 1 minute for hours...will not shut off automatically
I'm sorry to hear of your problem with your LG dryer. I have one as well and it works very well. I found my owners manual. It has a web site WWW.LGSERVICE.com. They also have a toll free number 1-877-714-7486. Perhaps either of these will help you find an answer. Good Luck
Dec 03, 2006 | LG DLE5932W Electric Dryer
Dryers Logo
480 people viewed this question
Top Dryers Experts
