Question about HP Photosmart C4150 All-In-One InkJet Printer
The computer does not detect the printer, but everything is plugged in correctly.
  • 35 Answers
Try to use another printer cable. If the computer still doesn't recognize the printer, install the newest version of the printer driver. Hope this will solve the issue.
Posted on Sep 11, 2010
Network intializing
see if the DHPC is enabled if so disable and give the IP address in copier. and ping in run command type: ping ip address space and -t to be entered to get reply.
May 13, 2014 | Toshiba E-STUDIO 450 Copier
My Brother MFC215C is not working with my newish computer which has WIndows 7 on it. I have tried uninstalling and reinstalling the correct software but when I get to the point where I have to plug the...
Are your usb ports correctly configured ? Are you using the right printer software/drivers for your windows 7 (32bit or 64bit) ? Try uninstalling everything and try again, but don't plug in the printer until it tells you to.
Jun 20, 2012 | Brother MFC-215C All-In-One InkJet Printer
My 3250 printer has a blank screen and my computer cannot detect my printer
it would help if you post what operating system you are running,
With some printers, you have to start installing the driver / software before you plug the printer in. happened to me one time where i plugged the printer in first and it wouldn't work properly. after reading the instructions (because i can be a mr. know it all sometimes),and running the software BEFORE plugging the printer in, it worked. Hope that helps, good luck
May 31, 2012 | Kodak Esp 3250 Allinone Multifunction ( ...
Computer does not detect printer
What all have you done so far? Is the printer brand new and did it come with everything you need like the printer cord and the installation cd? If so, the first thing you need to do is run the cd, then immediately following, plug the printer cord in from the computer to the printer (and don't forget to make sure the printer is plugged into the wall outlet for power). After you put the cd in, follow the instructions exactly word for word. You shouldn't have any problems. Let me know if you do.
Jun 18, 2010 | HP Officejet J5780 All-In-One InkJet...
I can't install my lexmark 4300. it keeps telling me to make sure my computer is turned on and connected correctly. i have already checked it over and over again and everything is correct.
did you connect the printer before installing the drivers ????
Follow the instillation back to the part where it says connect your device.. make sure its on and plugged in the usb port.. then.
if so
for xp - winserver..
  • click start
  • right click computer
  • click hardware tab
  • click device manager
  • right click on any item in the box that appears and click scan for hard ware changes
for vista - win 7
  • click start
  • right click on any items and select scan for hardware changes..
that should detect your device and install the drivers for you.. good luck.
Mar 17, 2010 | Lexmark P4350 All-In-One InkJet Printer
Error message
Uninstall the printer driver from Device Manager, then scan for hardware changes and install the printer driver when it detects the printer...All the best
Oct 02, 2009 | HP Deskjet 6940 InkJet Printer
Setting up two printers on the same pc
You need to manually setup the serial printer, as it probably isn't getting detected via plug n play:
  • Go to Start Menu\Printers & Faxes
  • Click on the 'File' menu and choose 'Add Printer'
  • Click next at the wizard, then select 'Local printer attached to this computer' and leave the 'Detect Plug n Play...' box unchecked, click 'Next'
  • Choose the correct serial port (either COM1, COM2, etc), click 'Next'.
  • Choose the correct printer manufacturer & model to install the correct driver, click 'Next'.
  • Print a test page, just to make sure it's working
Aug 04, 2009 | Epson POS TMT88IV Thermal Receipt Printer
Lexmark X8350 "communication not available"
I fixed this by completely uninstalling the Lexmark software, then unplugging the USB and restarting. I then installed the new Lexmark software that I downloaded from their site, make sure not to plug the USB back in until it told me to. It then detected the printer properly and started working.
Jun 02, 2009 | Lexmark X8350 All-In-One InkJet Printer
Was printing fine. I turned the printer off and it won't go back on. Everything is plugged in correctly.
Possible hardware failure, unfortunately.
Turn it off. Then unplug it from your computer and unplug it from the wall too.
Plug it directly into a working power source. Then turn it on.
May 03, 2009 | Epson Stylus Photo R800 InkJet Printer
HP Photosmart C4150 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
