Question about Memorex Electronics - Others
Flash Drive 32509070 stuck in write protect mode. I can't format, delete files, or add files. What to do?
pk86bhat
  • 75 Answers
SOURCE: flash drive write protected can't move files
a small lock is presents in side of your flash drive ,u just change the current position of this lock
done,now try to copy or your work
regards prasanna
Posted on Mar 06, 2008
SOURCE: how to remove write protect on my usb flash drive
how to remove write protected on my usb flash drive and i have mp3; when plugin into the usb hub it shows a problem occured during installation
Posted on Nov 11, 2008
worldvet
  • 859 Answers
SOURCE: Hi I have a Flash Drive 4GB it says it is write protected when
This is a bear of a problem with Transcend owners. You need to use their new Jet Flash format utility. So before doing so, copy everything off your drive to a folder in My Documents. This tool will then format your drive so you can start adding new, more organized data of your choice.
Then, try to remember to keep your data on the pen drive below the 4GB limit. This all has to do with binary math and base 10 math. The drive really doesn't hold 4GB of data, its way lower than that around 3.6GB. So, keep this in mind and keep this format tool around for future use.
I found this download link here, which is dynamic and not static but should work by clicking here.
Should that not work go to this referrer page here. You will have to start by select your product type and then go down through each selection list until you find your model and then the downloads for it will be listed. Click on the Jet Flash utility download eventually.
Personally, I think they could have done this much better and made this way simpler for consumers to find the formatting tool.
Let me know if you run into trouble and if you don't hear from me in 24 hours click on my user name and send me an Ask Me message, I'll get that message and I'll be glad to help you out.
Regards,
Worldvet
Posted on Jan 20, 2009
  • 11 Answers
SOURCE: Transcend jet flash showing write protected message
hey, i was having the same problem with the same flash drive... there are two ways how you can fix it..
1. try formatting using cmd
Go to start-->run and then type cmd and press enter
now the command window will open
in that type format X: (x being your drive)
This should work fine if not try the second method
2. Go to this website and download the recovery tool software which is exclusively for transcend flash drives.. click the link below to so to that site..
http://www.transcendusa.com/Support/DLCenter/index.asp?axn=SRH2&ModNo=107&ItemID=TS16GJFV30&Controller=#5
Download the recovery tool software under the topic software and install it in your system.
Now connect the flash drive in your pc and run the recovery tool application.. This will format your flash drive
Posted on Feb 02, 2009
softwareguru
  • 78 Answers
SOURCE: flash drive write protected? can't add files
This seems to be the problem of most of us these days and some of our readers who wanted to know the methods how they can remove the Write Protected error from their USB drives like Pen Drives and memory cards.
What is Write Protected error and why it happens?
In the Write Protected error, we can’t write or copy any data in our flash drives and even can’t format the drive.
There are many reasons that cause this problem, let’s see solutions of them.
Solutions:
• First of all try to locate a small switch (if any, that you may have not noticed) at some place on the drive or memory card reader. This is the prime reason for this error. If there is one, switch it to the other side to turn the protection off.
• Yes I know this problem is also occurring these days without this switch but not to worry. Just download this helpful software form here
http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml
and run it to execute a “low-level format” on the drive. This software is quite handy and may take few attempts to actually remove the error.
• The problem can also be caused by some virus activity so just get it scanned by some updated good anti virus which may solve your problem.
• BUT if none of the methods listed above solves your problem then your pen drive might have gone corrupted, so just get it replaced.
Hope any of the methods listed above solves your problem.
Update 1:
After the low level format, you may need to “Partition the drive“. Dont worry, partitioning a pen drive means allocating it its File System and Cluster Size that was lost after the Low Level Format.
For that:
  1. Run diskmgmt.msc in Run.
  2. In the disk management window, select the pen drive, right click on it and click on Format.
  3. Now choose the File System and Allocation Unit Size and do not check the boxes below.
Click OK and the drive will be reusable after this.
Update 2 (Better Solution):
Follow the steps in this post and just put the value 0 (zero) in step 5.
This will surely solve your problem now.
rate me and vote me..
Posted on Jan 08, 2010
Hi I have a transcend jetflash d33193 4Gb flash that won't format. It tells me the flash is write protected and i don't she any physical lock. i have tried every possible thing i know on it but it...
The message which you are facing while formatting your flash drive maybe be due to below reasons.
1) It could be due to virus. Try to scan your flash drive with your anti-virus and check.
2) Second reason would be when you connecting your flash drive it may include some autorun files which starts its own when you connect your flash drive and because that file is running it wont allow to be formatted, so try to delete all the files including in your flash drive and than try formatting.
or
There is right protect switch on many pen drives , a physical write protect switch which enables you to either allow writing on the disk or disallow writing on the disk.
All you need to do is toggle the right protect switch and you would be able to write files on your pen drive.
Please find an image below for more information.
Jun 08, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I cannot delete a full list of folders on mu maxell 4GB flash drive so I can add more university files to it. I can copy to my documents but when I try to delete it says write protected so cannot delete....
Copy all the files from the flash-drive to your 'C:' disk-drive.
Open "My Computer".
Click with the SECOND (usually the RIGHT) mouse-button on the icon for the flash-drive.
Choose the FORMAT option -- to completely delete everything on the flash-drive, and to reset it to its "factory" settings.
Click OK to do the formatting.
Copy all your files back onto the flash-drive.
Apr 14, 2011 | Computers & Internet
I have a verbatim 4gb micro with a write protect error. I cannot delete the files, add more files or format the stick. Regards Mano
It has password protection. Open My Computer on your PC, insert the USB drive, open the password file, enter your password, then select the option to remove password protection from the USB drive. If this does not work, contact Verbatim for a solution, these USB flash drives have lifetime warranties.
Jan 06, 2011 | Verbatim CORPORATION 94933 USB 2.1GB...
I can't format,add or delete files form my flash it's Kingston 16GB Data Traveler G2
kingston is not good USB.....it is easy to be write protected.......difficult to solve
Oct 09, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I cant format and delete files on my usb flash drive. everytime i do formatting or delete files the msg write protected always appear. how can i remove the write protection of my flash drive in an easy way...
hey hi buddy.....
nothing to worry for that,in your u.s.b there will be a button usually at the side ahich is used for lock and unlock....
if it is put in lock mode u ll face all these problems,just u push that button to unlock and then you ll be freed from these problem....
still if u face some problem kindly let me know...
take care....good day
Sep 22, 2010 | Computers & Internet
My memory stick is write protected...i cant add/delete files.
CHECK if it is not physically protected, a small button/switch might be on the stick!
THEN, try any other flash drive or memmory stick to locate the target problem (memorry stick, or usb port mulfunction or even security/driver issue).
PLUS, there are some programes that might protect flash drives, check if u have any, and uninstall them, and make sure u have deleted ther HIDDEN system files located on the stick!
gd luck.
Jan 01, 2010 | Electronics - Others
Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
Jun 16, 2009 | Disney High School Musical Mix Stick 2.0...
8GB TRANSCEND PEN DRIVE - WRITE PROTECTION DELAYED - REMOVE WRITE PROTECTION
Use following link to download recover jetflash from transcend site.
http://www.transcend.nl/support/dlcenter...
note that the data on the pen drive will be erased. so back it up before you run it.
  • 1 week ago
Sep 16, 2008 | Electronics - Others
How to remove write protect on my usb flash drive
Make sure your mp3 "HOLD" option is not on!
Its really as simple as that. The hold button 'protects' the files.
Nov 24, 2007 | Audio Players & Recorders
Electronics - Others Logo
53 people viewed this question
Top Memorex Electronics - Others Experts
Stu Morris K
Are you a Memorex Electronics - Other Expert? Answer questions, earn points and help others
