Question about Cameras
My nikon d3000 showing error press shutter release button again. iam pressing the shutter release buttion iam any change it is showing me the same sign again and not abel to capter photos.
I had the same problem. After looking up information on google, I found a very good solution. But be aware, it requires you to open the body. So, you'll need a set of very small screwdrivers, make sure you take one that fits perfectly to the screws. Open up the bottom part, you should see a small red gear (responsible for lifting the mirror). Turn it manually a bit, then insert battery and check if your camera works then. If it does, you're lucky. If it doesn't, you'll have to take off the metal part, to which you screw on tripod, as there is another white gear (responsible for lifting the sensor protector) under it. But to take the metal part off, you will have to take off both front and back sides of the body, to get to the screws. At all times remember where each of the screws go, as they have different sizes. when you get to the point where you have removed the metal part, you should get small tweezers, or anything small enough to fir under those wires next to the red gear, as that is where your white gear is at. Move it couple stops back and forth, and then insert the battery, try to press the shutter button 2-3 times, and it should be working. At least it did the job for my D3000. If your camera works, but everything back in the correct order and screws in their correct places, and that's it. You just fixed your camera.
Posted on Mar 17, 2013
I have the same problem with my D3000, as far as I've seen though, it only happenes when I try to take pictures sideways! my guess is there is some dust or other type of dirt in the camera, which stops the shutter when you try to take the picture!
Posted on Apr 17, 2011
Got the same problem with my Nikon D3000 today while shooting in broad daylight and with high suttee speeds. The problem however went away after the shutter release was pressed a couple of times. Continued to shoot at ISO800 just to see if the problem popped up again, but it did not.
Posted on Mar 13, 2011
Error press shutter release button again. After countless button pressing, message continues
When I have this problem on my D-90, I can usually fix it by turning the camera off and back on. Occasionally, I have had to remove and reinstall the battery. My D-90 manual says that this is a camera malfunction error and that it can be fixed by releasing the shutter. Unfortunately, when I have this error, the shutter won't release without turning the camera off. The manual also says that if this problem occurs frequently or persists to contact an authorized service center. I suggest you contact Nikon tech support at www.nikon.com, first, to see what they have to suggest.
Mar 17, 2013 | Nikon D3000 Digital Camera
Keep getting a message saying press shutter release buttom
What happens when you press the shutter release button? Are you talking about a message about a real problem or is the message about a non-issue? Please give all the details.
Jun 03, 2012 | Nikon D3000 D3100 18-55mm
Error. Press shutter release button again
Press the shutter release again what is the solution
Sep 11, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
On my D3000 once taken a shoot, monitor displays error. press shutter relase button again.
Press the button again. If it doesn't work, take the battery out and put it back in a while. If this doesn't work, reset the camera with the reset button.
If all this fails the problem has to be taken care of by authorized dealer repair shop.
Jun 19, 2010 | Nikon D3000 Digital Camera
Nikon d90, blinking "Error"
You "release the shutter" by pressing the shutter release button, often called the shutter button. That's the button you press to take a picture :-)
The camera may or may not return to normal after that. If it doesn't, remove the battery, then put it back in and turn the camera on again. Try removing and reattaching the lens (with the power off). If the problem persists, have a certified Nikon tech look at it.
Feb 18, 2010 | Nikon D90 Body Only Digital Camera
Nikon d3000 autofocus issue
you should change the focus lock to AF-S, instead of AF-C
Jan 02, 2010 | Nikon D3000 Digital Camera
D40 "Error: press shutter release button again." Nothing happens.
If you can dare servicing youself You can open bottom cover of and turn a little red wheel manually. try pressing the release button now and will start working. If you have this problem re-accuring, then get it checked wih professional.
Dec 19, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
When i take a pic,it says error press shutter release button again
I e-mailed nikon for this same problem. Their solution was to take out the memory card and press the shutter release button in the demo mode. To get to the demo mode you first need to go to custom menu/controls/no memory card?/press ok/ arrow down to enable release and press ok. Now you are ready to try solving this problem. Press the shutter release button to see if it will reset the shutter release button. I haven't tried it yet but it is worth a try.
Aug 24, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d40x shutter stuck
The manual (pg 112) simply, and unfortunately, states this message "Press shutter release button again. If error persists, consult with Nikon-authorized service representative".
Some questions that might help: have you had the camera in some extreme conditions, damp, sand, etc. Clean the shutter button really well. Maybe use a small air blower and clean in the shutter release creases.
In the end, if the error continues, it will need to be serviced.
Dec 28, 2008 | Nikon D40x Digital Camera
Cameras Logo
1,253 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
