Question about Linksys WRT160N Wireless Router
Help me access linksys router website. if i type 192.168.1.1 an error appears.
  • Linksys Master
  • 32,281 Answers
Typing the IP address will not get you to the Linksys WEB site.
The Linksys/Cisco WEB site is -
http://home.cisco.com/en-us/wireless/
The configuration URL for for configuring the Linksys wireless settings is -
http://192.168.1.1
The default login = admin
The default password = admin
Posted on Sep 11, 2010
Block https facebook linksys
Depends on the model router you have.
Generally connect either wired or wireless. Open a internet browser and type 192.168.1.1 in the address bar. A log in for your router may appear and ask for a user name and password. The default for Linksys is user = blank (nothing) and password = admin. If the default has been changed you'll need the user name and password to access the configuration menu.
Then look for URL filter under the Advanced tab or Access Restrictions tab. Type the URL of the website you want to block in the blank. Some will allow you to edit the days of week or times it will not allow access. (ie you can block access M-F and allow on weekends.) Click on apply, submit or save and exit out of the menu.
Dec 06, 2013 | Computers & Internet
Problem connecting router to lap top
Your Linksys router might be secured, so your going to have to open a port for it to able to connect to the laptop. I am not an Expert on routers, but maybe Linksys will be able to help you. You can do the Linksys Live Chat, or you could can look around at the Linksys support site. If this doesnt work, please do not give me a bad rating. Instead, tell me in a comment and I will try to assist you further.
Hope this helps :)
Jan 20, 2008 | Linksys Wireless-G WRT54G Router
My LINKSYS as for password, it is locked
Press and hold the reset button of the Linksys router using a pointed object (like a paper clip or pen) for 30 seconds.
The reset button is located in the back of the Linksys router closest to an Ethernet port.
The button is recessed to protect you from accidentally resetting the modem.
Unplug the Linksys router while pressing the reset button.
Shut down your computer for one minute.
Plug the Linksys router back into the wall outlet.
Reboot your computer.
Open your web browser to access a website.
Type the below in the address bar if you want to reset your password:
http://192.168.1.1
A prompt from the site will request a user name and password.
The user name stays blank, or, in some models, is "admin".
Navigate to the security tab. Input your new password to protect unauthorized access to your router
hope this helps
Sep 17, 2012 | Linksys E3000-rm 802.11a/b/g/n 2.4/5ghz...
No website through a limksys router
Are you trying to connect via wireless or wired?
Could be an IP conflict between your modem and router. Although rare, it does happen. Change the
setting in the router to something different. Default address for Linksys is192.168.1.1 - try changing it
to 192.168.0.1 or 192.168.1.2
Jul 09, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Networking question
Ok, you have several options. Go to a website such as bestbuy.com. Type in linksys and look of wireless access points, wireless usb adapters or a wireless desktop adapter. I would go with the third one.
Mar 30, 2008 | Linksys Wireless-G Broadband Router
Setting up linksys wireless router with motorola 2210 dsl modem
One thing that isn't mentioned anywhere is the modem has to be in bridge mode. I was told this by a Linksys tech after doing all that was documented in the references article. I contacted my internet provider and they told me how to set the modem to bridge mode. This corrected the PPPoE error.
Jan 01, 2008 | Linksys Wireless-G WRT54G Router
Password protection for my linksys wireless router
you need to get into the routers settings and look in the menu for security and select atleast WEP security and either you type a password in to reveal a 8 digit code or type in your own mixture of numbers and letters, which will then have to be entered into each pc when they try to connect. You can also look in the SSID and remove the name or dissable SSID so as your network will not appear on anybody elses wireless searches.
Oct 09, 2007 | Linksys Wireless-G Broadband Router
Static IP on machine, no outside access
Double check that the Default Gateway in TCP/IP properties is the routers LAN IP address (By default this is 192.168.1.1) Without a gateway installed, there will be no Internet access. After verifying this go to Start>Run and when the "Run" window appears type command into the "Open" Field, then click OK Once the Command prompt appears type in: ping 207.69.188.185. If you don't get a reply, the gateway is not installed. If there is a gateway already installed, check for any third party firewalls that may be installed on your computer. These can sometimes block Internet access. For more information please see the related article on assigning a static IP address behind the router. If still having problems, contact Linksys Technical Support.
Feb 16, 2006 | Linksys BEFSR11 Router
Feb 16, 2006 | Linksys WRT51AB Wireless Router
Linksys WRT160N Wireless Router  Logo
415 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
