Question about Avanti Fitness HG2000 HomeGym
I need to tighten main cable Thankyou - Avanti Fitness HG2000 HomeGym
My 06 impala has full charge but wont start and no power?
1. Check positive/negative battery cables at battery-- no corrosion wanted and tight clamp.
2. check + battery cable at starter and wires at starter solenoid.
3. check - battery cable ground connection point.
4. check main power fuse/fusible link.
tighten and or replace cables.
Jun 21, 2014 | 2002 Ford Explorer Sport Trac
Sony Bravia 46'' picture has a slight green tint and adjusting the Hue does nothing.
hello!
that could be the t-con to main board cable's problem. first, try to tighten grounding screws.those, which connecting grounding latches of the cable.
You need to open your set. This cable is a thick shielded one with two 30 or so pins plugs. They are NOT interchangeable. In case you try to swap cable's ends. Try to move latches by hand without unplugging connectors, while TV is running. Very gently! If those moving a bit, you may see "greenge" vanishing. Tighten those screws with "phillipls" screwdriver by hand. if there is no difference, you may need to replace that cable. I'm talking about "greenish" ghosts on the picture, intermittent. If I'm wrong, it might be the main board's issue, but always start with small. Main boards are not interchangeable, factory replacement only! Cables-are.
Good luck,
Alex.
Nov 26, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
2006 cobalt wipers dont move. but the moto is running, so how do i get to the wiper rod or motor section to tighten nuts or replace motor at please! please send a pictures etc. too me too. thankyou..
Hello
I would first try to tighten the wiper arms first where the arms bolt to the rods at the cowl remove the plastic caps and tighten the 13mm nuts that hold them down then you might need to adjust them if they wipe past the windshield
Good luck
Chris
Mar 22, 2011 | 2006 Chevrolet Cobalt
On my vizio tv i have to turn the volume to max and its still hard to hear all the cables are right. thankyou
your volume may be turned down on your cable box or satelite box. if this is so, a dvd should be loud, but cable/sat quite.
go into your settings, then find the audio settings
find the audio output setting, and put it to "fixed" instead of variable
or push "cable" and then try to turn up the volume on your cable remote. .
it may be "fixed" to tv.
this is usually the cause..
it could be your tvs audio amp or processing, but not as likely (main board bad)
let me know if you need further assistance.
Jun 06, 2010 | Vizio VX37L Television
My philips flat screen has sound but no picture all of a sudden what could be the problem?
Hello Bobby, hi, well, most common solutions, would be to tighten all screws, and clean contacts of the main board to the LCD panel due to poor connections.
One possibility is: Do you have LCD illumination? If the LCD is totally black, you may need to replace the inverter board.
Or : You need to open up the back cover and locate the main board, (usually the biggest circuit board), try to loosen and then tighten the screws, check for good contacts, make sure all cables are tight and neat (especially the cable from the LCD panel to the main board), then test.
Or this may be: Check also for loose cables from the power supply board, a loose cable here can cause several portions of the main board to fail so make sure they are snug and tight.
Worst is: If the unit does not respond, you may need to bring it for service, I see replacement of the main board.
Mar 24, 2010 | Philips 42PF9630A 42 in. Plasma Television
E-brake in 93 Ford Ranger doesn't work
The cables are probably stretched if you use it on a regular basis or seized if you are like me and never use it. Crawl under the truck on the driver's side, about 1/2 way to the back and find a steel cable running to the back wheels. Follow it down until it hooks up to 2 cables. Pull on the main cable by hand and watch to see if the other 2 move when you do that. Give it a good yank. If the 2 cables don't move they are seized and need to be replaced. If they move then the main cable is stretched.You can replace it or you can buy a tightener at the auto parts store. It's commonly refered to as a Chevy e-brake cable tightener. It just hooks on the cable and shortens it by tightening a nut on the J hook. You can use more than one if you need it. This would be easier and cheaper than replacing for now. Hope this helps.
Nov 03, 2009 | 1993 Ford Ranger SuperCab
Apart from the main supply to the cooker terminals
So long as the earth is connected to the earth terminal, then there is no prob for you to worry about.
The normal twin and earth cable is adequate.
Please rate my comments.
Thankyou..
Mar 05, 2009 | Neff U1661 Double circotherm super...
BUSH IDLCD32TV006
Try replacing the cable.
Oct 05, 2008 | Bush Televison & Video
"load main image failed switch to recovery mode" error. need help please?
For this problem i believe try to do the above steps. switch to recovery mode then connect the player to the computer. When the player is connected to the computer open the version.txt document and see if your firmware is up to date if not try to update the firmware of your player. I believe the latest one is 18 or something. If your firmware is up to date try to call sandisk, i had this problem once but they resolve it with the steps i have said.
Jul 03, 2007 | SanDisk Sansa e250 MP3 Player
Avanti Fitness HG2000 HomeGym Logo
26 people viewed this question
Top Avanti Exercise & Fitness Experts
richie46
robert
ray gallant
Are you an Avanti Exercise and Fitnes Expert? Answer questions, earn points and help others
