Question about Astar LTV-3001 Television
Hello, Where can I get a Astar LTV-3001 power supply replacement? I would be replacing it myself. I saw how to replace it on youtube. Thank you.
  • 3 Answers
If you need a replacement, call me at 480-797-3846 and I can supply you with one for a fee and an exchage of your bad power supply.
Posted on Sep 12, 2010
  • ninos190 Sep 12, 2010
    I'll do that. How much would run me for the power supply replacement for the Astar LTV-3001?
  • pony-express Sep 24, 2010
    $75.00 $10.00 shipping/with the exchange.
I need a replacement circuit board for my Astar LTV-3001.. Mine began to smoke... and I don't allow smoking in my house...
The failures on these LCD's are due to defective capacitors in the power supply. There are about 23 capacitors that will need to be replaced to restore the LCD power supply functionality. Check the picture to see where the capacitors are located, the power supply on your LCD is not the same but similar to the one on the picture just the capacitors are place in a different order.
Let me know if you required further assistance.
Mar 10, 2010 | Astar LTV-3001 Television
Power supply burned
These power supplies are not longer being manufactured and very hard to find. The defective power supply can be repair.
If you need further assistance, write to jah2mil@hotmail.com
May 28, 2009 | Astar LTV-3001 TV
Astar LTV-3001 just shut off and I can smell something. Any ideas?
The power supply most likely failed on your LCD.
How old is your LCD?
If it is under a year old, can be fix under manufacturers warranty. If not, you can write to jah2mil@hotmail.com
Aug 01, 2008 | Astar LTV-3001 TV
Astar ltv 2601
Try call my friend Ivan at 323-767-6030 he know where to get the original Astar parts.
Apr 10, 2008 | Astar LTV-3001 TV
ASTAR 20'' LCD TV
TO ALL WHOM IT MAY CONCERN REPLACE THE WHOLE SUPPLY WITH NEW ONES AS IN 2OR3 SEPARATE ONES FROM HALTED ELECTRONIC SURPLUS OR HSC IN SUNNYVALE CALIF 408 AREA CODE LOTS OF ROOM
Feb 16, 2008 | Astar LTV-3001 TV
NO PICTURE OR SOUND.
Have you guy check the power supply for your TV?
Call me 323-767-6030 and I will go through with you.
Feb 06, 2008 | Astar LTV-3001 Television
Astar Plasma
try to contact my friend Ivan 323-767-6030. He had working for the astar company as electronic tech maybe he can help you and answer all the problem of your astar tv.
Thank you.
Jan 25, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
Screen goes black immediately after astar logo screen comes on
Astar 30" LTV 3001 ....These TV's have a cooling problem that causes premature electrolytic capacitor failure. De-solder and Test all the 2200uF-25v, 3300uF-35v and 1000uF-10v caps in the power supply (center board, back of TV). Use a good LCR meter that will read 3300uF or better, Replace all bad caps with 105c rated caps. If you don't have an LCR meter, replace all the mentioned caps on the PS. If fuse on board is blown, also replace the F9222L regulator IC chip. Mounting a small cooling fan on rear of TV over the PS will help keep your new caps from failing again. This requires holes in the stand bracket and the rear of the TV, power can be supplied from a 14V source near the bottom of the PS board.
Jan 21, 2008 | Astar LTV-3001 TV
Astar Plasma
I had the same problem... Astar 30" LTV 3001 ....These TV's have a cooling problem that causes premature electrolytic capacitor failure. De-solder and Test all the 2200uF-25v, 3300uF-35v and 1000uF-10v caps in the power supply (center board, back of TV). Use a good LCR meter that will read 3300uF or better, Replace all bad caps with 105c rated caps. If you don't have an LCR meter, replace all the mentioned caps on the PS. If fuse on board is blown, also replace the F9222L regulator IC chip. Mounting a small cooling fan on rear of TV over the PS will help keep your new caps from failing again. This requires holes in the stand bracket and the rear of the TV, power can be supplied from a 14V source near the bottom of the PS board.
Jan 13, 2008 | Astar LTV-3001 TV
Astar LTV-3001 30 inch
It's easily to fix the problem. Just replace the buffed capacitors on your power supply board.
Dec 03, 2007 | Astar LTV-3201 32 in. LCD Television
Astar LTV-3001 Television Logo
154 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
