Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
I am having problems while booting. it says that "you need to backup your data as soon as possible, the problem might be eminent". also the hdd has become very slow while reading and writing..is it for the bad sectors..? plz. help..
  • Seagate Master
  • 27,725 Answers
Try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
good luck with this
Posted on Sep 11, 2010
Can't perform system recovery on Fujitsu LifeBook UH 552
If you started a system restore from your CD, all of your data is gone and you must rely on your backups. Usually if you press F8 just before it tries to boot, you may be able to use the recovery partition on the hdd.
Apr 09, 2014 | Fujitsu LifeBook AH531
Hdd not found
If your Hard Disk Drive (HDD) is not found and assuming that this is also your boot disk for starting the laptop, then you have several possible causes:
1. The HDD has failed / died / become non-operational and will need to be replaced and your operating system reloaded or restored from a backup if you have one.
2. The computer BIOS has lost the configuration for the HDD and doesn't recognise it as a valid boot device. In this case, you would need to go into the BIOS settings and check to see what HDD devices are beig detected, then look at the Boot options within the settings and ensure that the HDD is selected as the main boot device.
Note: It is normal to have other removable devices set ahead of the HDD such as CD / Diskette or USB devices.
3. The HDD boot sector has become corrupted and the computer no longer recognises the disk as a valid boot medium. You would need to repair the HDD is this is possible using an alternative boot media such as the Hiren's Boot CD which you would need to download as an ISO CD image then burn on to a blank CD disc, then boot from. The DOS programs on the Hiren's CD provide a very good HDD repair tool called HDAT2.
An alternative approach would be to remove the HDD from the laptop and connect it as a slave in a different computer and then perform any repair activities from that system.
Jan 04, 2012 | Computers & Internet
My hp mini netbook hang at the boot... it appear in blackscreen and state that my windows unable to open becouse some software change might cause the windows cannot open. and ask to insert the disk in...
you will try to restore the system.
Please follow the below links.
http://www.microsoft.com/windowsxp/using/helpandsupport/getstarted/ballew_03may19.mspx
http://www.youtube.com/watch?v=hF4bTnb_HMk
http://bertk.mvps.org/html/safemode.html
http://vlaurie.com/computers2/Articles/windows7-system-restore.htm
If your problem is same after doing these option please repair your HDD.
Regenerate the HDD
Download the iso file from =http://www.fullandfree.info/software/hirens-bootcd-v100/
Write the iso in blank cd
Boot from cd
DONT PANIC follow all the steep It is very simple. (Use the down arrow key.)
1.INSERT CD TO CD TRAY
2.Boot from cd
3.Select start boot cd
FOR REPAIR THE HDD DONT PANICI
Choice hard disk tools
1.select HDD regenerator>enter
wait create it auto mode
2.Enter(If you have one HDD)
3.Press "1"ENTER for scan and repair (With out lose any data)
4. press 3 for REGENERATE ALL SECTORs
I will sugest press for "1" and enter
press( 1-9 )any one number and type mb and ENTER
Repair will Start soon.
zerro fil the HDD.
Dont panic,follow the instruction.
1. May be bad sector on HDD only the reason you did notuse for a long days. or electricity problem .so need zero fill by ontrackbootable dm follow the step > 2. boot from cd 3. go to dm 4. Type that letter where the dm software in the cd. 5. Type in DOS mode .all it will be possible if you know dos, other wise it will be difficult. 6. download link 7. http://www.fileguru.com/Partition-Recovery-Bootable-CD/download 8. 9. http://www.fileguru.com/apps/dm_bootable_latest 10. e.g.if your two partition C: D : so your dm file will be in F:. 11. typeF: and enter , for observation type= dir and enter >now you can see is thereontrack or dm (directory or folder) have or not try it once afterone 12. ifhave ontrack in that folder type=cd (space) ontrack>cd (space) dm hit enter. NOTEit depends on bootable CD maker. You can also create self through narrow cdwriter . 13. Ifall ok type dm and enter 14. enter 15. advanceinstallation 16. eminence 17. utility 18. zerofill 19. yes 20. itwill take 8 to 10 hours don't panic all data will be lost 21. Withthis processes your HDD can be ok. 22. andafter complete all the program install OS again
or click on the link
Hope it will help you.
Jan 08, 2011 | HP Mini 110-1037NR Netbook
When i start my laptop a messege displyed...like...SMART FAILURE PREDICTED IN THE HARD DISK PRESS F1 TO CONTINUE ...and when window starts the computer takes much more time to initialise....and system...
If you have no need save your file do this step
  1. May be bad sector on HDD only the reason you did not use for a long days. or electricity problem .so need zero fill by ontrack bootable dm follow the step >
  2. boot from cd
  3. go to dm
  5. Type in dos mode .all it will be possible if you know dos, other wise it will be difficult.
  6. download link
  8. http://www.fileguru.com/apps/dm_bootable_latest
  1. e.g. if your two partition C: D : so your dm file will be in F:.
  2. type F: and enter , for observation type= dir and enter >now you can see is there ontrack or dm (directory or folder) have or not try it once after one
  3. if have ontrack in that folder type=cd (space) ontrack>cd (space) dm hit enter .
  1. If all ok type dm and enter
  2. enter
  3. advance installation
  4. eminence
  5. utility
  6. zero fill
  7. yes
  8. it will take 8 to 10 hours don't panic all data will be lost
  9. With this processes your HDD can be ok.
  10. and after complete all the program install OS again
Another option can save the file .follow the instruction.
Boot from cd
2.Boot from cd
Help it will help you.
Jan 07, 2011 | Computers & Internet
Click sound on hard when it gets hot then freezes up ????
Hello
OK, this is not good at all...This means that your Hard drive is failing. The best advice you can be givin at this moment will be to backup the data on the drive as soon as possible, it might be too late already.
If the drive does not want to backup, you will need to send it to a recovery centre to recover the data.
If you need a second opinion, click HERE.
Kind regards
Andrea
Dec 01, 2010 | Western Digital Caviar (WD307AA) 30.7 GB...
I have Acer Aspire One ZG5 installed with Windows XP. My computer show the windows boot screed and reboots after Blue error screen is displayed. The computer also ask for safe mode boot but the problem...
Hello
OK, i had this exact error on my other laptop yesterday, sorry to say, but you will need to format the computer and reinstall windows XP. If there is data on the HDD you would want to keep, you will need to plug your HDD into another computer and backup the data before you format.
Kind regards
Andrea
Aug 31, 2010 | Computers & Internet
The dvd recorder and it hdd can't record since hdd full
Miss Fouzia Morocco
pls try to format all HDD first backup ur data by connecting the dvd recorder to pc then format ur hdd it will help lemme know
Feb 20, 2009 | Funai PY90DG DVD Recorder
Restore deleted movie files
It is still possible however you need to call a company to do it for you.
One example is drive savers
www.DriveSavers.com
Oct 31, 2008 | JVC GZ-HD3 HDD HD Camcorder - 60 GB USB...
Need to restore emachine 667 to factory settings
Did you create backup disks when you got the pc? If not, do you have an operating system cd? You could also go into system tools and do a restore and choose factory during the process if it allows. If you get it to work and you do not have backups then create them as soon as possible.
Aug 24, 2008 | Computers & Internet
Windows XP cannot find filepath
Probably your disk is going..going...gone.
Back up all the data you can as soon as possible. If you have one use a boot cd, like norton utilities boot cd and check the hdd from boot cd.
Alternatively take out the HDD and mount it on a different computer as a slave hd so that you can get out data. After you can format and reinstall windows if HDD is still physically ok.
Even better if you buy an external hard disc caddy enclosure, take out HDD from computer. Put hdd in usb caddy. Connect usb caddy to working computer and take data out.
User data are on C:\Documents And Settings\"name for the user"
Regards
Mar 19, 2008 | Microsoft Windows XP Home Edition
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
46 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
