Question about Canon MV900 Mini DV Digital Camcorder
The images on display are criss-crossed and the dispay is divided in three separated areas with different images.What should I do?
    Genius:
  • 1,812 Answers
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 11, 2010
Head bolt tighting pattern
opposite corners, and then criss cross your way along. Take at least three passes to get from hand tight to the full torque. Difficult to know without knowing the exact make and model of your vehicle
There are many images here
http://www.bing.com/images/search?q=Head+bolt+tighting+pattern&FORM=HDRSC2
May 09, 2015 | Cars & Trucks
Am missing parts for Mattel Hot Wheels Criss Cross Crash Track. Need 6 curved track sections (Part number 2148-2050).
I don't have a solution to your problem with hot wheels but am wondering if you were Rosalie DeGraff 55 years ago when I knew you.
Nov 13, 2011 | Mattel Hot Wheels Criss Cross Crash Track...
What are the torque specs for cylinder and head bolts on a 2001 kx 250?
The torque specs for your cylinder base nuts are 25ft.-lb.and the head flange nuts at 18ft.-lb.tighten them in criss cross pattern,at three different stages,ex.25ft.-lb.start with 8 then15 then 25,18ft.-lb.start with 5 then 10 then 18.good to go.Hope this helps.
Feb 08, 2011 | kawasaki KX 250 Motorcycles
What is proper method for aligment of tires. is it front to back or criss cross.
If you have unidirectional tires it is front to back, ordinary tires are criss cross.
Aug 09, 2010 | 2005 Lexus RX330
I want to drain the oil on my 2000 audi a6 avant wagon...where is the drain?
underneath the car in the engine area up in front just back past the front bumper you will find an aluminum cross hatched (criss cross lines) oil pan at the lowest point is the drain plug.
Jan 13, 2010 | 2000 Audi A6
Look like the image is divide on three.red,blue,green .yesterday was normal.my son finish video game and turn off.Today I turn on and the image cannot show all colors together.
this is a normal problum pls. check remot cantrol on menu key press then selact convergen seting see on the screen canter three cross line arrow to set UP / DW/ LIFT/ RIGHT key maeching 3 line and see cross line is White then see the pictuer is ok
if not working convergen seting then spare STK replace in inside your tv set
Oct 29, 2009 | Sony KP-61HS30 TV
The dispay panel dispays message vir 1.2 I can not set and training modes.
unplug it for about ten minutes or so and then plug it back in and try it
May 24, 2009 | Fitnex E70 Elliptical Cross Trainer
Security camers not displaying on
Try going to that input and changing ntsc/pal or make sure your closed captions are off.
Nov 21, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
PG-C30XU projecting criss-cross plaid image.
i suggest you do not have the projector too far away... 7ft away distance would be a Good resolution will also dimm don the square's image in the picture
Nov 08, 2007 | Sharp Notevision PG-C30XU Multimedia...
Canon MV900 Mini DV Digital Camcorder Logo
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
