Nokia 6300 Cell Phone Logo
Posted on Sep 11, 2010
Nokia 6300 wont turn on, blue lights on side stay on
Anonymous
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Oct 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
4028
Points
11
Hey !
1 . Open the backside of the phone
2 . take off the battery
3 . wait approximatively 10 secondes
4 . back the battery inside & close the phone
5 . switch on the phone
Et voila.
I hope it helps, I have experienced the same and it works for me.
If it don't work try to clean (softly) the sim card and the parts under the battery with air.
bbye
Denyzor
5 Related Answers
Anonymous
  • 1884 Answers
  • Posted on Aug 08, 2009
SOURCE: nokia 6300 will not power up blue lights come on
Bucks, Your phonr needs firmware re-install. There does not seem to be any HW problem
Anonymous
  • Posted on Sep 28, 2008
SOURCE: nokia 6300 wont turn on, blue lights on side stay on
I had a simliar problem with my k800i, it turned out that it needed its firmware/software updated. So u can either get it "flashed" at a shop (around £10) or you can try doing it at home but you'll need the software and the data cable for the phone. Google it i'm sure you'll find something. Good luck
ElDopa
ElDopa
  • 295 Answers
  • Posted on May 06, 2009
SOURCE: my nokia 6300 will not power up.
You can try updating the firmware using a Windows XP computer, which will also reset the phone to factory defaults (and thus probably fixes your problem).
Download the Nokia Software Updater from: http://europe.nokia.com/A4579163
Connect your phone to the computer using an USB cable, run the program and just follow instructions. Please note that you'll lose anything stored in the phone's memory (but not the SIM contacts !).
Whenever you still have warranty, you could take it to a Nokia Care center and have them update/reset your phone ...
Anonymous
  • 51 Answers
  • Posted on May 27, 2009
there is bettewry problem and also check ur charger problem..if there is no image on turn on then u have to change the LCD of mobile..but this model always has less timing of bettry
Anonymous
  • Posted on Aug 27, 2009
SOURCE: My mobile 6300 will not turn on, have 2 blue lights on the side
dead solution
8helpful
2answers
Nokia 6300 blue light
Side Blue Light is the indication of new messages
Wont turn on, blue light stays on?
The blue lights dont stay on.
Its jus a alert to you if you have a message or missed call.
Please check whether the light effect is ON in your current profile.
To turn the light please follow the below steps,
Menu > Settings > Profile > Select the profile you using
> personalise > Light effects.
Put it to ON.You will get the lights
Thanx
6helpful
Nokia 6300 will not power up blue lights come on
14helpful
3answers
My nokia 6300 has a blue light on all the time on both sides of the phone.How do I switch it off
my Nokia 6300 got wet and now both blue lights are showing and the phone will not turn on?
1helpful
6300 Won't turn on
The file you have received corrupted your software you need to get it flashed
2answers
Nokia 6300 blue lcd lights staying on draining my battery
This could be a software glitch. Perform reset settings on the handset. You will not lose any date, only personalized settings will be resorted to factory defaults. If this still does not help, you would need to reflash the software on the handset.
2helpful
Nokia 6300 -Wont switch on , only has blue lights
your cp having a defective lcd now. it need to be replace and send it to repair center,
2answers
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
