Question about Garden
Fuel line replacement on a stihl 020 AVP chainsaw?
5 Suggested Answers
  • 211 Answers
SOURCE: Fuel line for Stihl 025 chainsaw
Hi
It happens sometimes.You have to replace the fuel line.This is a trick.Remove the gas tank cap and take off the fuel line and remove the fuel filter.Take off the fuel line from the gas tank.Cut off the piece of the fuel line wich is larger and seals the gas tank.Now through that piece of fuel put an ordinary fuel but about the same diameter.Put all back and that is all you have to do.If you need farther info just let me know. best regards savumihai71
Posted on Dec 20, 2008
steve_lima
  • 181 Answers
SOURCE: How to replace the Husqvarna chainsaw fuel line.
let me knoe the model number and i'll see what i have....
Posted on Feb 11, 2009
dontbother10
  • 2220 Answers
SOURCE: my McCulloch chainsaw 3200 internal fuel line in
Try your friendly neighborhood chainsaw seller/mechanic. Take a piece of the old hose with you.
Fuel Line Replacement
SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank.
Posted on Oct 13, 2009
SOURCE: stihl 009 chainsaw
http://www.ultimatehandyman.co.uk/manuals/stihl/19.pdf
manual above it is all in there..
Posted on Mar 26, 2010
How do you replace the fuel lines on a Stihl chainsaw electronic quick stop 009L?
Hey Doug,
Replacing the fuel line is a pain.. not hard.. just time consuming and requires some disassembly.. TAKE PICTURES OF ALL PHASES OF DISASSEMBLY....From the Stihl's I worked on, you have to remove the air filter, the carburetor, most of the covers.. when you get to the fuel tank.. just remove the line with needle nose pliers..reinstall everything according to the pictures... Good luck..
Aug 30, 2017 | Stihl Garden
Stihl 012 av fuel lines
The 2nd line might be a vapor return line back to the fuel tank? I've dealt more with repairing bigger saws more than smaller ones. You should go to a Stihl shop&take a look at chainsaws about the same size as yours&take off the air filter cover&look to see where the carburetor lines go.
Aug 01, 2014 | Stihl 011avt Brake Handle 009 010 011 012...
Need a diagram of fuel line system for a 311y chainsaw
http://www.doityourself.com/forum/outdoor-gasoline-electric-powered-equipment-small-engines/279941-stihl-chainsaw.html#b
  1. Stihl Chainsaw - DoItYourself.com Community Forums
    www.doityourself.com/forum/outdoor.../279941-stihl-chainsaw.html
    Oct 4, 2006 - I am in the process of rebuilding my Stihl chainsaw carb. I am having troubles identifying this Stihl model. The only sticker on the saw is 311Y.
Mar 22, 2014 | Stihl 311y
Can't get a spark on Stihl 020 chainsaw. Tried another coil and switch module but still no spark
It is possible your flywheel has lost it's magnet strength, if you noticed it turn a blue. Can take off flywheel and replace with a good one. Or you can play with the gap on the magneto/coil, and insert a piece of paper between the coil and the flywheel magnets, to set for air gap.
Sep 09, 2013 | Stihl Handle Chainsaw 020 Avp
I need help in replacing a gas line on a Stihl chainsaw model ms250c. The line is cracked and leaking bad.
Best way i can help is to fix it for u. But if u want to try here goes. Pull off air cleaner housing, Fuel line runs from left of carb to under carb, remove. install new line. Looks easy, sounds easy, very tight fit.
Aug 24, 2011 | Stihl Garden
Im having problems starting an MS250 Stihl chainsaw. Can you give
Chances are good that the compression is not to blame. I would look at:
1. Bad Fuel
2. Fuel Line/filter
3. Carb dirty/mis adjusted
3. Spark Plug
4. Ignition
Dec 01, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Stihl chainsaw
Hi
First remove the cover,air filter and the carburator.Then remove the gas tank cap and the fuel filter from inside of gas tank,at the end of fuel line.Take off the fuel line from the hole of the gas tank(at the top),replace the fuel line,put all back together and start the engine.
Feb 13, 2009 | Husqvarna Chain Saw 20" Bar
there is a good video on this problem on you tube. should be easy to find.
Dec 20, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
354 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
