Question about Bosch Dishwashers
Hi All my powerpoint dishwasher 1dw12 keeps flashing E4 and starts to drain and will not work now .Anybody know how to fix this problen. emmetot
  • 10,515 Answers
Any water that leaks (for whatever reason) from the internals of the machine finds it's way down to the lowest point of the machine - down under the washzone and into the area where all the workings of the machine are located. There's a sensor there (a polystyrene float operated switch in fact) that detects this water - causing the machine to empty and go into error 4 (E4).
The solution will depend on the nature of the leak. If it's due to one of the various seals on the floor of the washer leaking or there is some problem with water level controls then that will have to be repaired first - otherwise you'll keep on getting the error. In my case however, the "leak" was actually a design feature of the machine and is easily rectified.
Open the dishwasher door fully and look at the floor of the machine where it meets the bottom of the door. You'll see a couple of plastic tubes protruding from the floor by about 12mm - one to the left and one to the right. Their function appears to be to act as an overflow if the water level in the machine gets too high (for whatever reason). This excess water is directed down these tubes and into the bottom of the machine where it can be detected - rather than letting it spill out onto your expensive floor. The weakness in this system is that it only takes a soup spoon of water to produce the error - something which might accidently happen during the course of a normal wash.
Options:
1) Leave the machine idle for a few days until the water evaporates. The sensor switch will reset and the error will be gone when you switch on.
For either of the following solutions, turn off the power to the machine by unplugging it or tripping the relevant switch at your fuse board
The stainless steel washcabinet is only slightly thicker than aluminium kitchen foil. Handle the machine gently and never force it otherwise you're in danger of distorting the cabinet.
2) Tilt the machine right the way forward so that the water leaves the area of the sensor. It'll flow back again once you level the machine but in wetting the floor area of the machine, the level at the sensor will be a little lower than before - permitting the sensor to reset. Switch on and the problem should be gone.
3) Pull the machine out from the built in unit to gain access to the right hand panel. Remove it (just a lot of philips screws holding it on) and you can just about see the polystyrene float (near the front) and the slightly depressed area underneath it - in which the water accumulates. You can poke a stick in with some tissue taped to it to mop up the water. Be careful not to disturb or damage the float.
note:
I've had this problem occur twice in as many years. If it keeps on occurring then you likely have a genuine problem with water level controls during filling or a leaking internal seal dripping water into the bottom of the machine.
Don't be tempted to block the overflow tubes - a genuine overflow could destroy your kitchen!
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 11, 2010
Where do you place your washing tablet in this particular dishwasher powerpoint 1dw12
JUst place it in the bottom of the tub, it knows what to do
Feb 07, 2016 | Dishwashers
Hi... I just bought Electrolux Dishwasher ESF2433W. When i first time turn it on, light at "Normal" button keep on flashing with beeping sound. After checking the trouble shooting manual, it actually refer...
E4 Overflow
Sometimes during trasport it is possible that styrofoam float mechanicaly activated overflow microswitch. So, you should check complitely overflow system.
At any time, if overflow micro-switch act and keep for longer than 2 seconds, the E4 would occur. When E4 occurs, the drain pump will run until flowmeter keep motionless for 2 minutes (if the model with the pressure switch (83/63),drain pump would run till the pressure switch reset and continue draining for 60 seconds.) and all the other components will be stopped immediately. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown. Note: Priority level of E4 is the highest. E4 operation is valid after other error operations have done. When E4 operation has done, all the others are invalid.
Dado
Feb 20, 2015 | Electrolux Dishwashers
Powerpoint 1dw12 dishwasher
Just put the tablet in and Don't close where it goes. I do this now. Then if you don't want to do that check the spring might be bad.
Jul 18, 2014 | Dishwashers
Hi my powerpoint 1dw12 dishwasher has an error code E2. can any one help
see your instruction manual, and go to the section troubleshooting and fix it.
if you do not have i.manual download from www. retrevo.com or www.fitness.manualsonline.com
God bless you
Jun 19, 2012 | Dishwashers
Hi, We have a fairly new ADP600IX dishwasher. It has stopped mid cycle and is flashing up ERR 4 What does this mean? Many thanks
Error 4 means dishwasher has overfilled with water and is not draining out. This has happened to me twice and I have found turning the dishwasher offf at the powerpoint for at least a week seems to fix the problem.Keep your filter in the bottom of the dishwasher clean.
Mar 28, 2011 | Whirlpool Dishwashers
E4 flashing and water not draining away
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Mar 12, 2011 | Smeg 24 in. DWF614SS Stainless Steel...
Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Aug 07, 2008 | Dishwashers
Dishwasher problem powerpoint IDW12
clean the filter on the intake pipe, just done mine.
Apr 02, 2008 | Dishwashers
Dishwashers Logo
110 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
