Question about Whirlpool Washing Machines
I have a near new 8.5 kg 6th sense front loader that is leaking lots of water! I've cleaned the filter but no success
    Scholar:
  • 59 Answers
You will have to find out where the leak is . Get down and look. at the front, at the back, where? Check the hoses at both ends. Water can run down the hose from the tap or the drain hose can leak. Water can come up out of the grille in the floor This grille might be under the machine. Check it out Cheers Tony
Posted on Sep 11, 2010
My whirlpool 6th sense front loader has stopped whilst full of water, half way through a wash. Have emptied machine, Still no power, machine wont turn on.
Hello Janine Gooch,
Went out on our internet trying to find your trouble shooting guide (typically in the OWNERS MANUAL)...
Finally ended up in AU ... No luck.
(September 9th is only 6 hours old here (SF Bay area)).
Your local peers have NOTHING NICE to say about that machine... particularly the CONTROL BOARD:
Whirlpool WFS1071BD Question and Answers
Hope this helps (says top load... shows front)
Carnac the Magnificent
Sep 09, 2017 | Whirlpool Washing Machines
Lg Washing Machine Manualmy washing machines just started coming up with 1E in the display part what does that mean.. i have a lg direct drive 7.5 kg front loader, WD12020D
there is a problem in water inlet valve.....first turn off the water tap.then remove water inlet hose from washer end.after that see the inside of the valve.there is a small water filter in the valve.....take it out it using plier ...then clean it wel....now replace it correctly....now your problem will ok
Jun 02, 2013 | LG Washing Machines
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Were is the pump on whirlpool 6th sense
Whirlpool recently launched a new site and I find they have made it easier to find the solutions I need for DIY. www.whirlpoolwaterheaters.com/products/natural-gas/n50t61-403/
Jun 24, 2012 | Whirlpool 6th Sense 50-Gallon 6-Year Tall...
Whirlpool AWOE 9559B 1200rpm 6th Sense Washing Machine, 9 kg instruction book lost; can you provide me with a copy please
Morning, Your model number does not come up. It is located on a front loader behind the door, top loader under the lid. GE right side at front bottom of case. Will await your answer. Thanks
Jan 23, 2011 | Washing Machines
Hi i want to know that a waight of 6 kg washing maching is a small one for cloths or it is ok . should i go for more than 6 kg. for 4-5 persons family. thanks.i just choose a whirlpool compact model of...
Your question is not easy to answer. An average washing machine is 8 kg. The smaller 6 kg will use less water and detergent, but you will be limited to 4 or 5 pair of jeans at one time...unless your children are small. A front loading machine may be a better choice for you. It can do very large loads, 12 kg, and still use less water and detergent than most top loaders, but be prepared to pay three times the price of a top loader.
Sep 20, 2010 | Whirlpool Washing Machines
Zanussi front loader leaking
Most likely you have a pump shaft seal leaking you can buy a new pump at this site. You may remove the pump and clean with pool muratic acid, but it is very caustic you would have to put pump in the acid bath in a metal pan that you don't mind using it and it will eat all the organic buildup from the pump. However it may leak worse as the organic material may keep it from leaking too much. So I suggest you use the pump, if you use mueratic acid it is highly toxic so read directions on using it and were air mask and rubber gloves while using it then rinse off with clean water. You should put water hose in the drain pipe and tunrn on the water to test the drain pipe as well. this will make sure the drain pipe is fine. Look at the hoses near the clamps as this is where holes develop on the water pump hoses.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=Zanussi+front+loader
Sep 05, 2009 | Washing Machines
Clean pump light keeps coming on
That is the way to fix the issue. remove the debris and hope nothing else gets caught in the trap
Jan 19, 2009 | Whirlpool AWM8163 Front Load Washer
LINT LEFT OVER CLOTHES
It has a self cleaning lint filter. Front loaders call for "Special" HE detergent .....and I would only use about a table spoon..You may be Cloging the special self cleaning lint filter ,with extra soap .Top loaders use a lot of water compared to front loaders. Let me know ,If I could help Again! Thanks
Dec 14, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool 6th sense front loader awm 8121
my whirlpool 6th sense will not start all lights and power i think that it is the door sensor at fault? The green light door locked light is not on.
Jul 18, 2008 | Whirlpool AWM6100 Front Load Washer
Washing Machines Logo
90 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
