Question about Sharp AR-161 Laser Printer
Error h2 & h4 model:ar-161 - Sharp AR-161 Laser Printer
  • 2072 Answers
SOURCE: SHARP AR-M277
this should resolve it.
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly.
Posted on Jan 22, 2008
sir fixalot
  • 146 Answers
SOURCE: Sharp AR-M237 Error Code H4-21
-H4-21 means:Sub heater lamp abnormally low temperature detection. The setup temperature (about –25°C: Sim 43-1-1) is not reached within the specified time (about 32sec) from turning on the power ON SW. (When the temperature falls below 140°C in the standby mode.)
-Causes:
Sub heater thermistor defect
Sub heater lamp failure
Sub thermostat failure
Control PWB failure
-Check the sub heater lamp blinking with SIM 5-2-2.
When the lamp blinks normally: Check the thermistor and the harness. Check the MCU PWB thermistor input circuit.
When the lamp does not light: Check for disconnection of the heater lamp and thermostat. Check the interlock switch. Check the power PWB and the MCU PWB lamp control circuit.
Clear the display of self-diagnostics with SIM 14.
The H4 errors will not reset by themselves. You must enter service mode to reset this error even if the problem has been repaired. The reset process is outlined below (DO NOT USE ANY OTHER FUNCTIONS IN SERVICE MODE):
Press the following sequence: "#/P" "*" "C" "*"
Type in 1 4
Press start
hit 1 for yes
hit start
Unit should power off and the restart.
If the error code recurrs ther are other problems.
Posted on Jun 06, 2008
  • 62 Answers
SOURCE: Error code H4-01
This mean you have low temp. on heat lamp 2 program interput clear interrupt 14 print may clear this code. if not you can look at the fusing unit and reset thrmo breaker that may be pop off.
Posted on Jul 30, 2008
SOURCE: Error Call for Service H4-00
# - intrrup key - clear - interrup key 14 print
this all
check fuser lamp, thermost
just
Posted on Oct 26, 2008
  • 37 Answers
SOURCE: SHARP AR 5316 error H4
The problem is in the fusing unit try these steps:
STEP1: Press continuously CLEAR then INTERRUPT then ZERO then INTERRUPT
STEP2: The panel display will turn off it means that you are inside the simulation if not repeat again step1.
STEP3.Then type 14 then press the print button
If these steps doesn't work you must call an authorized serviceman to check your machine, maybe something is busted on the fusing unit like thermostat or fusing lamp.
Posted on Mar 01, 2009
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
Tip
How to clear code H4 in All sharp copiers.
All the sharp copiers reset by code 14.
type of codes entry:# interrupt C interrupt.led goes off,press 14 and start.
2`nd type:(# * c * ) 14 start ( M 207 model)
3`rd type: C interrupt 0 interrupt (almost for analog copiers)and AR-161 .AR - 5015
on May 30, 2010 | Sharp AR-5320 Black and White Copier
Estudio 161 4h error code
h4 low heat from heater unit do the following [c key]-[auto/text/photo key]-[c key]-[auto/text/photo key] machine will go dead key in 14 press print machine will cycle if the error code returns you will have to replace thermistors and thermofuse
Mar 19, 2011 | Toshiba E-Studio 161 Copier
What does it mean when h is flashing
There is a problem with the fuser unit , H2 means thermistor open or not connected, H4 means low temperature or fuser lamp not working. Reset with by pressing ; # , Interrupt , C , Interrupt. Display will go off then enter 14 and press Print key.
Jul 29, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
Service Code of H4-01
H2-01 Fusing Temp. to low
Use DIAG (SIM5-2) to checkthe heater lamp
Blinking operation.
If the heater lamp blinksnormally:
Check the thermistor and its harness.
Check thethermistor input circuit in the
control PWB.
If the heater lampdoes not light:
Check for heater lamp disconnection and
thermostatdisconnection.
Check the AC PWB andthe lamp control
circuit in the control PWB.
Use DIAG (SIM14) to cancel the trouble.
***ALWAYS DISCONNECT POWER WHEN WORKINGON MACHINE***
You have to reset fuser errors with simulation 14.Push P * C * then 14 then Start (the button you use to make copies)and it should reset the code. If not then replace the fuser.
SM5-1 should turn the lamp on. If lamp blinks on and off it is thethermistor, if it does not it is the lamp, but check the contacts onthe lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defectivereplace.
Jan 25, 2009 | Sharp AR-M237 Copier
Sharp Photocopier AR 161
it is the signal h4 if this it is the problem heater unite
Jan 07, 2009 | Sharp AR-161 Laser Printer
SHARP AR163 Displaying H2 error code
Dec 11, 2008 | Sharp AR-163 All-In-One Laser Printer
183 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
