My 6-month old topload WF 8702CPG keeps stopping in the middle of the cycle with the code LE. Going crazy tyring to figure out what's wrong. Error code not in the manual. What does it mean and how do I fix it?
    Scholar:
  • 59 Answers
This means the lid safetey switch is a bit out of adjustment LE means Lid Error. if you press down on th lid it might take the error away while you are pressing. without breaking the lid. This will prove the lid error. A warranty call may be necessary . 6 months old must be under warranty Good Luck
Posted on Sep 11, 2010
My 7 year old LG Front Load Washer Model # WM1812CW displayed ERROR CODE LE(Overload in motor): how can I fix this problem ? The rinse cycle begins, shortly thereafter, the machine stops and the LE code...
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall Effect sensor is used in these washers which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when there is an issue with the motor or when the Hall Effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sensor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Aug 29, 2011 | Washing Machines
LG dishwasher model LDF6920WW 1 1/2 years old approximately. Suddenly stops a minute or so into cycle (it drains remaining water and fills with new water then get LE error). When I open the door at the...
The manufacturer has assigned this error or fault code to indicate a problem with the water circulation pump motor. Turn the appliance off for 30 minutes to allow it to cool. Then, restart the cycle. If the error code returns check the wiring to the pump motor. Also, if the wash impeller is broken this error can appear. If the impeller and wire harness check out, and the code keeps returning, you will probably need to replace the pump and motor assembly.
Aug 06, 2017 | Dishwashers
Keeps saying LE. Wont run. NEC Topload washing machine
Hi from retired Englishman in SW France, Frid afternoon, 14:24,
As you do not mention the model, I am going to guess it stands for 'Lock Error'. Either the lock itself is malfunctioning or the door lock sensor is, meaning that service is required. Sorry ;-0(
Good luck,
John C
Mar 04, 2011 | Washing Machines
LG WM0642HW ALWAYS HAVE (LE)
Unplug the unit from main outlet.Then drain the water from the machine.By disconnecting the drain pump ,There will be too much water so be care full.If you disconnect the drain pump from drain hose to drain the water it will flow on you,so keep towels ready to soak the water. Also clean the water filter. ----------------- In most of the case LE error is solved by just disconnecting the washing machine from main power outlet for 30 minutes.But if the problem is still the same then try cleaning the filter and draining the water from drain pump.This error occurs when motor stops functioning and water does not drain. --------------Also another cause of LE error is Regarding the LE ERROR CODE. This code is also caused by having a residue on the sensors in your unit. You have to use a HE liquid detergent.If you use fabric softener use half of the recommended amount and dilute if it is concentrated. Once a month (for a family of four) put 3 cups of white distilled vine-ager directly into the drum and select sanitary cycle or the hottest cycle you can. This prevents residue from forming in your unit and causing the LE ERROR CODE. ---------------- This should help.Thanks.Helpmech,.
Jan 25, 2011 | LG Washing Machines
Neptune tl washer
You will need to replace your timer control.
John
Sep 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
I'm getting a code "LE".
LE IS A LOCKED MOTOR CODE CHECK FOR OBJECTS IN PUMP BUT THE HAD THAT PROBLEM IS THE PAST
Sep 26, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG WASHER WM1832CW HAS LE ERROR MESSAGE
error LE Overload in motor.unplug for 1 hour plug back in. motors going bad or over loaded with stuff.
Jan 15, 2009 | LG WM-2277HW Front Load Washer
LE ERROR CODE
This new....just call out LG to repair under warenty!!
Jul 22, 2007 | LG LDF6810 Built-in Dishwasher
Washing Machines Logo
125 people viewed this question
Top Washing Machines Experts
