Question about Toshiba REGZA 42RV530U 42 in. LCD HDTV
Toshiba regza zv650u power light blinks 3 times pauses, and then blinks 3 times again. It went off when I was watching it, and now i get no screen, just the blinking power light
djchillsnyc
  • 151 Answers
SOURCE: Toshiba Regza with red LED blinking
hello the red blinking lights is a service code when this happens it means theres a power problem or a fualty circut. it happens alot with these new plasma and lcd tv's its very common since these units have built in protection and power loss a fualt or short will cuase this.
the tv needs service the tech will know what to look for according to the number of blinks.
hope this helps.
Posted on Dec 18, 2008
SOURCE: power led blinks but no picture or sound
The number of the small white connector on my plasma was PJ63A and is located on the left side. Thanks again to mchale420.
Posted on Apr 24, 2009
SOURCE: Black screen and no sound on TV
what is the brand, model? try to be specific if you want be helped!!!
Posted on Sep 11, 2009
tvservice306
  • 458 Answers
SOURCE: I have a toshiba 42HL167. Love it but recently
Try firmware update
If the TV loses A/C power (e.g., a power outage occurs or the power cord is
unplugged), when power is restored, the yellow LED will blink while the TV is booting
until the remote control is usable. This is normal and is not a sign of malfunction.
Posted on Nov 06, 2009
SOURCE: Our Toshiba Regza won't turn on.
Down load this firmware file p/n 2007SEN069 from this address http://www.tacp.toshiba.com/customersupport/model_firmware.asp?model=26hl67. The instructions are here also. Un zip to a blank sd card. I'm not sure if the set will boot to the card or not.
I finally got the tv to boot by constantly plugging in the a/c power and unplugging the power until it filally booted and was able to turn the set on.
Remove the sd slot cover from the lower right rear of the set, and insert the sd card with the unzipped firmware. Monitor the screen and follow instructions. Do not remove the card until the set powers off.
This fixed mine, hope others benefit from this repair.
David
Posted on Jun 28, 2010
Why won't it turn on?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Dec 14, 2015 | Toshiba REGZA 52RV530U LCD TV
I have a regza zv650u 55 in LCD TV. It is not powering on and there is no led light nor clicking sound. What could be the problem?
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
May 01, 2014 | Toshiba REGZA Televison & Video
REGZA 47HL167 TV is difficult to turn on. when powered on the amber lite flashes 3 times then pauses for 1 second then repeats the 3 amber flashes. If I keep pushing the power button on the side,...
3 flashes of the led light at the front panel is means that the unit is in booting process. The symptoms you've mentioned is caused by faulty electrolytic capacitor in the power supply section.
Look for faulty capacitor with bulged, dome at the top and then replaced it with same ratings. If you have a capacitor checker, it will make you more easy to identify the faulty capacitor without a physical indication of fault.
http://www.youtube.com/watch?v=oDGjWOabJ2E&feature=related
http://www.youtube.com/watch?v=YCSNWi3UHf4&NR=1&feature=fvwp
Oct 07, 2011 | Toshiba REGZA 47HL167 TV
Had my toshiba regza 42rv530u since March 2009 a few days ago it cut off and will not come back on, the yellow light flashes at the bottom of the tv, 3 blinks pause 3 blinks etc....
try resting your tv. power off it press and hold av select botton and then power on your tv wait few minutes and it will rest your tv.... if not used the same wy holding menu botton instead.
May 30, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Hi,Iwas watching TV and the screen went black.No lights on,I unplugged and plugged again but anything happened. My TV is a Toshiba Regza model 42RV530U. Can you help me? Thanks
If there was a popping noise of any kind when the tv screen went black there's a high possibility that one of the fuses in the tv popped and there is no power to the tv. It could also just be the outlet itself and try plugging the tv to different working outlets.
May 24, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Blinking red light on bottom of tv
Have Toshiba Regza 42" LCD HD TV. Turned on TV. Heart a pop. Power light on TV blinks 3 times.
Dec 20, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Wont turn on but yellow light is flashing
I followed the steps at the following link and it worked for me. I have a 2007 Toshiba Regza 42HL67, but the firmware applies to many models as documented in the readme file at the location found via the link below. I used a 1gb SD card formatted FAT16, copied the unzipped files and folder to the card (wasn't sure if it required the top level folder or only the files under the top level folder so I copied both to the root of the SD card), unplugged the TV, inserted the card, plugged in the TV, waited 2.5 minutes, unplugged the TV, removed the card, plugged in the TV, yellow light flashed 3 times and went out. I turned on the TV and it has worked normally since last night.
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
Jul 23, 2010 | Toshiba REGZA 47HL167 TV
I have a 42 inch toshiba lcd tv its bran new led blinks 3 times then a pause, over and over again can you help me trouble shoot this problem?
3 Blinks indicates that there is fault with the power supply of the set. Since the set is brand new, run back to the store and get a replacement. Also purchase the extended warranty(Think of the 250$ that you are gonna spend on this repair if the same thing happens right after your 1 year warranty expires?)
Hope this helps,
Sai.
Dec 25, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I have a toshiba 42HL167. Love it but recently when the power is off iget a repeating blinking yellow light. Blinks 3 times pauses blinks 3 time pauses blinks either 2 or 3 times then stops for 25 seconds...
Yes. The Yellow LED blinking 3 times is a normal boot-up, but if it keeps doing it -- it needs the firmware "update" (which is more like a reload because it got corrupted.) The problem is, no one talks about how to do that. (there is a PDF and firmware on toshiba's website, but it lacks some crucial details.)
My friend gave me his 42HL167 after this problem started after a power event during a storm and I managed to fix it by reloading the firmware.
I posted instructions on my website at:
Once I figured out some of the facts, it was a breeze...
Nov 06, 2009 | Toshiba 42HL167 42 in. LCD Television
REGZA 42HL167 Won't turn on
I found it!
I posted detailed instructions on my website at:
I hope this is still useful for others. It's so embarrassingly easy anyone can at least TRY it before calling a tech if they have any friends that are computer savvy.
-Ben
Apr 22, 2009 | Toshiba 42HL167 42 in. LCD Television
Toshiba REGZA 42RV530U 42 in. LCD HDTV Logo
293 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
