Question about Pioneer Televison & Video
I have a Pioneer projection tv LS-501 almost 30 years old only problem intermitting distorted sound, cracks then normal sound then crack and back distortes. when I turn audio up high sometimes it pops back out. thank you for any help
  • lasoul Sep 11, 2010
    thank you will try
  • 85 Answers
Hi there.most likely there are dry joints on the audio ic..a few sharpish taps on the main board should make the fault come and go if thats the case, just a little bit of resoldering should do the trick.hope this helps, steve
Posted on Sep 11, 2010
  • 1 more comment
    thank you will try
  • voilegirl Jan 17, 2011
    I have one of these tvs as well. It works great still but im trying to find out what it's worth. Any ideas???
  • Steven Hill
    Steven Hill Jan 18, 2011
    unfortunately they are virtually worthless.plasmas and lcds ruined the market for them almost overnight!,but maybe a hundred gbp or so if you are lucky...
    regards,
    steve
Tv hit by tennis ball and now there is sound but no picture. Can it be fixed?
If it hit the screen unit and the display panel is bad, it could show not not show a crack but be toast inside, the part would cost more than a new set.
It does not take much of a impact to cause damage to the display panel.
Dec 21, 2012 | Pioneer PDP-506XDE 50 in. Plasma TV
My 12 year old Sony KP-53V80 TV suddenly turned off and will not show a picture just a small rainbow at the top of the screen, then a whistling sound, crack and turns back off. can you help?
sounds like the inverter went bad...There's a high voltage device in there that runs the whole "picture" thing. There are capacitors involved with it that have probably failed leading to this mess.. That would be what that "crack" is...If you try to turn it back on does it just "click " and then stay off?
Jun 09, 2012 | Sony KP-53V80 53" Rear Projection...
My 50 "Magnavox rear projection has a vary faint picture
If its over 6 years old , sound like the tube are shot , bright/focus together = bad tubes
sorry
Jun 30, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
SD-P50A5 Pioneer TV - No Video and Audio is 'chirpy'
CHECK IT FOR CRACKED SOLDIER CONECTIONS ON IC2603 AND IC2604.
resoldier all heat sink parts , this model came of the manufactior line with manny bad solider conections.
regards.
daniel.
Jan 14, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
My toshiba projection tv has a cracked screen.
With projection TV, cracked screen does not worth repair cost because it'd be more than the TV worth. You are better off getting a used projector HDTV on the cheap now ($400-500 or less) or a new LCD/plasma TV ($1000).
Jan 04, 2009 | LG 42PC3D 42 in. Plasma Television
Pioneer sd-t50w1
My SD P 50A3-K We unplugged it and now wont come back on to stay...we turn it on then the red lite comes on green flashes on then right back off.....Some times tv will come back on then it shuts it self off....please help thank you
Jun 30, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Toshiba TP50H95 No sound no picture
Sounds like a problem in the deflection circuits either vertical or horizontal. You may also want to check the solder connections in the tuner as they have been known to develop cracks over time. But the prior shrinking tends to say deflection problems.If I can assist you further please let me know.
Feb 03, 2008 | Toshiba 50H81 50" Rear Projection...
Color off
You need to have the pins of your convergence IC's checked for ring cracking. That cooling-off period is probably just enough to bring the crack(s) back into contact with each other and as they heat up they separate. It doesn't sound like a IC or component failure, at least not yet. But if it's ring cracked that arcing that happens is placing stress on the Ic's and they could eventually fail... Good Luck Bill
May 24, 2007 | Samsung HCL552W 55" Rear Projection...
Three seperate colors on Screen
Screen may have a hair line crack in it causing projection to be distorted. Inspect screen very closly with magnifying glass if necessary to insure no cracks. If crack is found replace screen.
May 18, 2007 | Zenith R40W46 40" Rear Projection...
Televison & Video Logo
311 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
