Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
F1 code how to fix and re-set - Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
  • Fisher and P... Master
  • 3,247 Answers
Is this happening with both drawers or just one.
You have water leaking into the base of the dishwasher under the drawer.
Most likely the drawer seal is leaking.
The flood switch is located at the base of the dishwasher and this needs to be dried.
Turn power off and take the bottom drawer out. Dry base with towels and hair dryer. Turn power back on without putting the drawer back.
Run top drawer to see if any water is leaking.
Water leaks can be due to faulty seal or drain hoses cracked.
Hope you are able to fix it.
Posted on Sep 13, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Have f1 code at times and lights around knob of settings flickers
    Hi
    Thanks for using FixYa. Error code F1 indicates primary control failure and to resolve this you'll have to replace the machine control assembly. Yes you are right, this error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please rate the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Sep 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Setting f1 code all the time
    Hi
    Thanks for using FixYa. Error code F1 indicates primary control failure and to resolve this you'll have to replace the machine control assembly. Yes you are right, this error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Sep 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 and F7 code ...how to fix it
    f1 code is a communication error with the main board.the main EOC needs to be replaced.you can unplug the unit for a few minutes and reseat all the wiring connector on the back of the board make sure they are all seated properly.check you main power terminal block and ensure there are no problems with it.
    Feb 23, 2010 | GE Kitchen Ranges
    F1 code whirlpool
    whirlpool F1 code - Appliance Repair Forum THERE IS A RECALL ON YOUR WASHER,CALL THE FACTORY AND GET IT FIXED FOR FREE
    Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    CODE f1 FLASHES , I unplugged the oven for 1 hour and stil comes back with the f1 and beeps
    f1 code on most ranges are erc failure. only way to fix is to replace the oven control board
    Nov 05, 2009 | Kitchen Ranges
    I keep getting f1 code on my cabrio washer
    by recommendation from this site, I called Whirlpool and was ready to do battle since my Cabrio washer was well out of warranty. As soon as I described the F1 code a very pleasant agent immediately admitted it was a quality issue and offered immediately to set up a time for a repair free of charge. 2 days later my washer was fixed. Great experience.
    Jul 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    KitchenAid KESS907 Electric Range E1 F1 Error Code
    F1 E1, replace Electronic Range Control.
    In other words, the controller board has failed.
    Jan 29, 2009 | KitchenAid KDRS807SSS Dual Fuel (Electric...
    My dishwasher keeps flashing F1 error message
    The f1 code is caused moisture in the electronics part most likely in the door.see if there is any way that you can see where moisture might get in and plug that spot up. In the case of the f1 code when not using the dishwasher leave the door propped open to help dry out the electronics.
    Nov 18, 2008 | Fisher Dishwashers
    Oven Failure Code F1
    F1 is a Relay circuit failure . you have a bad relay PCB or wire connection.
    to fix your F1 error
    92028 RELAY PCB, 105 C
    Nov 20, 2007 | Dacor Preference RSD30 Gas Kitchen Range
    Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
    960 people viewed this question
    Top Fisher and Paykel Dishwashers Experts
    Brian Coughlan
    marley mcelhinney
    Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
