Question about Whirlpool Washing Machines
My front loader machine says clean pump and wont work
  • 176 Answers
Take it of and clean it maybe something stuck inside.
Posted on Sep 11, 2010
My samsung front loader washing machine is not pumping or spinning says "error ND" checked pump all clear still nothing
on my kenmore machine nd means the drain filter is clogged. open the cover, drain water completely, remove and clean the filter, replace filter, tighten and close cover. hope this works for you. if not , at least your drain filter will be cleaned and you can eliminate it as the problem.
Feb 03, 2013 | Washing Machines
Front loader has stopped mid wash and red light has come on saying clean my pump. How do I do this?
Not knowing which model you have makes it a bit difficult. Most front loaders have a little trap door down on the front panel somewhere. Behind this door is access to the pump filter. Usually, it just unscrews, and you pull it out. If your machine is full of water, expect a mess. remove any buildup of fluff, foreign objects etc. If your machine has no trap or access. Unplug the machine and drag it away from the wall. Lean the machine back against the wall to gain access underneath. You should be able to see a large hose from the tub to the front ( or side) of the pump. They are usually held on by a spring clip. Slide the clip back or unscrew the clip to enable you to pull the hose off the pump. Clean out any foreign objects you find. As before, if the machine is full of water, expect a mess. Front loader drain hoses usually exit out the top of the machine so lying the end of the drain hose on the ground wont drain the water.
Jul 26, 2011 | Whirlpool Washing Machines
I have a he front loader washing machine. I cleaned the filter but it still wont drain. The pump makes a quiet humming noise but nothing happens
u have to have some one take your pump off i just did that and had a peice of broken of pencil in mine stuck works great now...
Feb 08, 2011 | GE Washing Machines
Something is stuck in our LG front loader washing machine so the water wont empty in the spin cycle
There should be two screws under the front lower panel. Remove the two screws and remove the lower panel. You should be able to access the pump from here.
Inscrew the cover on the front of the pump and clean.
Dec 31, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
My Kenmore HE 2 Plus front end loader washing machine has a load and when I open the door water pours out. It will NOT spin
since front loader wont spin till its empty
id be willing to b et you have a clog in the pump
get a few towels
and spread em out in front of the machine
take off the fron toe kick 3 T-20 screws on front lip bottom
you should see the trap cleanout dead center
turn the handle 1/2 tun and pull straigt out...
be advised the washer will dump
you now have the sump in your hand ensure it and the pump inside are clean
reassemble and test
use 1 tablespoon of soap no more
suds will mess this machine up
Oct 06, 2009 | Kenmore HE2 Plus Front Load Washer
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Wont pump water out after the washer fills
Ref. to manual to locate filter of machine, clean out. Caution unplug from mains. If that does not work you may have a block in one of the pipes coming down from under the tub (front loader?). You hv to unblock by disconnecting pipes. Next to look into is your pump, last.
Jun 09, 2008 | GE Washing Machines
Beko wma512w front loader
CHECK THE CONTROL CARD FOR DAMAGE OVERLOADING THE MACHINE CAUSES THE CARD TO OVER HEAT.AND MELTS THE SOLDER ON SOME JOINTS.HOPE THIS HELPS
Dec 03, 2007 | Hotpoint First Edition WMA22 Front Load...
Washing machine
You have to check and clean out your outlet filter. This requires periodic cleaning, according to your usage. If its a front loader, the small door is at the front bottom, be prepared for water to come out while opening.
Oct 06, 2007 | Washing Machines
Washing Machines Logo
13 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
