Question about kawasaki Garden
How do you replace the trimmer line on the Kawasaki KTF27A-A3 trimmer?
I have a Kawasaki KZ 1100 A3 1983. Would like to know size of carbs. I need to replace #3. All I've found ref. to a b-34?
34mm sounds about right, ...,Why do you need to replace a carb?
Take a good set of digital or dial calipers... carefully measure the inside diameter of the throat that goes into the intake manifolds. It will be a round number.
Apr 07, 2015 | kawasaki Motorcycles
Why does my kawaski khs750b hedge cutter start easily but stop when tilted in a certain position
Answered your own question : generally the fuel supply to the motor is through a small hole at the base of the tank , at full you could probably tilt more aggressively and the line is getting fuel , however as the fuel runs down the fuel is on one side of the tank and is essentially not getting fed to the motor , you'll notice tilting it from horizontal to left you will get cut off , tilt to right it'll keep running depends on the locations of fuel line however , cars pre fuel pump days had similar problems
Sep 19, 2014 | Kawasaki Outdoor New kawasaki Hedge...
Kawasaki z250 A3
I have seen in the past, the rubber brake line separate and collapse inside the hose.
Jun 17, 2013 | Motorcycles
Kawasaki Brushcutter Td 34
More than likely the drive cable is broken.You will need to remove the engine from the handle/tube or remove the rotary trimmer spool to confirm.
May 08, 2012 | Garden
Replace trimmer line
The steps for replacing line in a single line trimmer head are virtually the same for many trimmer head types, like double line trimmer heads.
1. Remove the Trimmer Head Spool
Removing the spool is the first step in replacing trimmer line in any conventional trimmer head, but trimmer head spools can disassemble in different ways.
The trimmer head pictured above and below disassembles by simply unscrewing the knob around its arbor bolt. Other trimmer heads can use press tab and other twisting styles for disassembly.
2. Insert Trimmer Line and Wind the Line
Single line trimmer heads have just one channel in their spools for winding line. The channel will have a hole in it somewhere that keeps the line in place as it is wound around the spool. Insert one end of the trimmer line in the hole.
Depending on the trimmer head, it might be helpful to bend a small portion of the cutting line at an angle before inserting it in the starter hole. Also, cutting the line at an angle can help this first step on some trimmer heads.
Of course, it is also important to make sure that the replacement line matches the diameter specification of the trimmer head before beginning. Once the line is started correctly in the channel hole, you're ready to wind. Most trimmer heads will indicated the correct winding direction right on the spool somewhere.
It's also important to wind the line carefully, keeping it in neat rows as much as possible. The line will have a much higher chance to feed incorrectly during trimmer use if it suffers from sloppy winding.
3. Snap the Line into its Retaining Notch
A conventional trimmer head will have a retainer on its spool. Snap the end of the trimmer line into the retainer after it is wound around the spool. The retainer will hold the line in place as the spool is replaced in the trimmer head assembly.
4. Replace the Trimmer Head Spool
With the cutting line held in place, the spool is ready to be replaced in the trimmer head assembly.
First feed the extra trimmer line through the trimmer head eyelet. Make sure to release the line from the retainer before completely securing the spool into position.
Replace any knobs, bolts, or other trimmer head pieces removed during disassembly.
Your single line trimmer line is now reloaded, and your trimmer should be ready to get back to work.
Although there are many steps to reloading line the conventional way, a little practice and familiarity with your trimmer will speed the process up a great deal. Once you're up to speed, reloading trimmer line this way can take less than five minutes.
If you want to know about the double line replacement, please click this
Thanks.
Apr 01, 2012 | Garden
We have a Kawasaki Hedge Trimmer TF22. I need to know the ratio of gasoline and oil to put in it
The oil ratio for the trimmer is 50 to 1.
Good luck and please rate 4 thumbs uf for the free answer
Jun 26, 2010 | kawasaki Garden
My Kawasaki Trimmer is running bad. It will run
Check the throttle cable. You probably need to tighten it up. You will find it on the left hand side of the engine that is mounted it the top of the trimmer, thats where it normally is, but with the japanese you wouldn't know!! Have a look for it, won't be hard to find anyway. Also check the finger throttle. probably slack too.
Once you found the throttle cable at the top, find a optimum idling value and then tighten the cord at that point. (there should be an adjustable screw there.)
Hope it help's.
Hughie.
Jun 16, 2009 | Troy Bilt Tb70ss Gas Trimmer
Need a wiring diagram for a 2005 kawasaki kdx200
the hayns manuals usually carry the circuit daigrams.Take a copy to anybody with a good photocapier and expand the haynes diagram to A3 to be able to follow the lines.
I find that it is best to draw out the individual circuits making sure all the plugs and connectors are correctly copied in detail.
Dec 08, 2008 | 2005 kawasaki KDX 200
Garden Logo
213 people viewed this question
Top kawasaki Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
