Question about Bosch Water Heaters
Need to know what requlator I need for using propane with a Bosch wr400 k1. I was given one but did not get the requlator with it
  • kesamrn Sep 11, 2010
    I have the manual and there is not a pressure requlator shown in the part list that I can see. In the manual is says this must be installed. The heater is spec for propane according the the plate on the heater.
    I have a Bosch wr400 K1 water heater that was given to me. The fuel type is propane. In the manual it states that the gas pressure requlator must be installed. I need to know what requlator I need to use with it.
  • 905 Answers
If you are already using propane, then your supply tank should have a regulator on it (high pressure), and there should be another regulator on the building (low pressure).
Per the installation manual, at an altitude of 0-2000 feet, you will need a regulator that is able to sustain a flow of 117,000 BTUs.
For this flow rate, you likely will not be able to use a portable 20, 30, or 40# propane cylinder. These small cylinders are not able to supply enough gas at that kind of volume, and will end up refrigerating / freezing up. Use at least a 100# cylinder, or a bulk tank.
Posted on Sep 11, 2010
  • Sheldon Dedek Sep 12, 2010
    Based on last comment, I am assuming that you don't have LP in place at the moment.
    You will need a LP regulator, that is able to support 117,000 BTU (minimum) at an appliance delivery pressure of between 11-13" W.C. A larger regulator will reduce the tendency to freeze when running near capacity.
    A propane supply house can get you the regulator that you need.
  • 10,319 Answers
A regulator that is maked for propane conversion
  • 10,865 Answers
Hello. Here is a link to a free downloadable copy of the installation manual for your Bosch wr400k1. http://www.elpower.net/bosch_install_guides/WR400-K1P.pdf
Go to page 11 for the schematic and part numbers for the regulator. In addition to the regulator for liquid propane you will also need the orifice for liquid propane and the main burner for liquid propane. All of these must be Bosch parts. Converting an appliance from one type of gas to another is serious business. Do not proceed unless you have the correct Bosch parts and you are certain that all procedures are followed to code. J.
Bosch 1600 h not lighting pilot light
If your getting a spark the generator should be ok I would clean the pilot injector and re try
Nov 16, 2014 | Bosch 1600H-LP Liquid Propane AquaStar...
My Bosch Water Heater keeps going off. I reset it and then A7 keeps coming up. We had a power outage for about 6 days. I do not have the manual. Do you know what it is and how to fix it? Thank...
Questions might be asking for a manual, and asks what error A7 means, and asks how to fix error problem, but model number of Bosch heater is not given.
Error codes are start-point for troubleshooting, and can include multiple causes.
So following answer provides general do-it-yourself resources, without saying that problem can be 100% diagnosed or fixed by homeowner.
1) Error code A7 is outlet temperature sensor fault.
Problems include: need for descaling, dirty inlet water filter, debris in faucet aerators, dirty wiring terminals, bad wiring harness, or bad temperature sensor.
http://waterheatertimer.org/pdf/Bosch-GWH2400ES-error-codes.pdf
2) Before calling service technician who can test failed parts and catch tankless up on yearly maintenance, open following links for Bosch resources including error codes, phone number, possible manual, and descaling instructions, and cleaning inlet filter:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
http://www.boschhotwater.com/Portals/7/TechBulletins/TWH-G1-12_Cleaning_inlet_filter.pdf
3) Product manual: Question posted under model 125HX-LP
Open following link for possible manual:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/125HXTechSupport/InstallationManuals/tabid/542/Default.aspx
4) Do it yourself service bullitens for 125HX-LP
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/125HXTechSupport/ServiceBulletins/tabid/548/Default.aspx
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 07, 2011 | Bosch AquaStar Propane Tankless Water...
I have a Bosch tankless propane water heater 125fx. Yes, I know it's ****, we replaced the igniter switch last year. Then struggled with ordering parts to repair a water leak. During the leak, it was...
There is likely an onboard relay stuck in the open position.
This is a gas appliance and should be serviced by an authorized BOSCH repair center to avoid potential catastrophe.
Thanks!!
Aug 06, 2010 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
Recently installed a Bosch 2700ES. I am getting
unplug power or turn off power,reboot, and try again
Jul 04, 2009 | Bosch 1600H-LP Liquid Propane AquaStar...
Looking for Outdoor Tankless propane water heaters
it will tell you right on the box if it for indoors or out doors either way they have to have a cover over them,,
Jun 09, 2009 | Bosch AquaStar Propane Tankless Water...
My Bosch on demand water heater is clogged. I cleaned the inlet line but seems to be inside the smaller copper tubing. HELP!
If you can access the pipe that is clogged, Poor some lime away into it . Let it sit and ad more as needed. the calcium will sofen and ca be flush out. Takes patience. Once you get some flow, fill the tubing with a descaling solution (hardware store) and let it sit. Pool acid works but must be thoroughly flushed out. be careful with acids, always wear gloves.
May 02, 2009 | Bosch & Tankless LP Hot Water Heater
Tubing size
Absolutely not. Unless it is installed exactly as instructed you will have a problem. Too small of a line = reduced flow rate.
Please rate if this helps-
Mar 23, 2009 | Bosch 1600H-LP Liquid Propane AquaStar...
Bosch 1600H-LP Overheating Problem
did you check to see if your temp regulater is working properly? also you have a thermocoupler that senses the heat of the water and works in conjunction with the regulator. have either one or both replaced and the problem will be solved. please rate this thanks
Aug 27, 2008 | Bosch 1600H-LP Liquid Propane AquaStar...
Water Heaters Logo
79 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
