Need to know what requlator I need for using propane with a Bosch wr400 k1 water heater I was given one but did not get the requlator with it
  • 2,299 Answers
You can use the same regulator. Did you not get a regulator at all? If you did then you just need a different or-phis. You should be able to get the new propane or-phis at any hardware store.
Posted on Sep 20, 2010
Bosch 1600 h not lighting pilot light
If your getting a spark the generator should be ok I would clean the pilot injector and re try
Nov 16, 2014 | Bosch 1600H-LP Liquid Propane AquaStar...
I have a Bosch GWH 425 HNO propane Tankless Water Heater which began intermittently exploding when demand for hot water occurs.
Call a qualified service tech immediately.
Gas explosion indicates dirty combustion parts, and gas is not fully igniting when tankless turns on the gas. So gas builds up and then explodes causing serious damage to tankless, and serious risk to homeowner.
Aug 14, 2012 | Bosch & Tankless LP Hot Water Heater
I have a Bosch tankless propane water heater 125fx. Yes, I know it's ****, we replaced the igniter switch last year. Then struggled with ordering parts to repair a water leak. During the leak, it was...
There is likely an onboard relay stuck in the open position.
This is a gas appliance and should be serviced by an authorized BOSCH repair center to avoid potential catastrophe.
Thanks!!
Aug 06, 2010 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
Recently installed a Bosch 2700ES. I am getting
unplug power or turn off power,reboot, and try again
Jul 04, 2009 | Bosch 1600H-LP Liquid Propane AquaStar...
Looking for Outdoor Tankless propane water heaters
it will tell you right on the box if it for indoors or out doors either way they have to have a cover over them,,
Jun 09, 2009 | Bosch AquaStar Propane Tankless Water...
My Bosch on demand water heater is clogged. I cleaned the inlet line but seems to be inside the smaller copper tubing. HELP!
If you can access the pipe that is clogged, Poor some lime away into it . Let it sit and ad more as needed. the calcium will sofen and ca be flush out. Takes patience. Once you get some flow, fill the tubing with a descaling solution (hardware store) and let it sit. Pool acid works but must be thoroughly flushed out. be careful with acids, always wear gloves.
May 02, 2009 | Bosch & Tankless LP Hot Water Heater
Tubing size
Absolutely not. Unless it is installed exactly as instructed you will have a problem. Too small of a line = reduced flow rate.
Please rate if this helps-
Mar 23, 2009 | Bosch 1600H-LP Liquid Propane AquaStar...
Bosch 1600H-LP Overheating Problem
did you check to see if your temp regulater is working properly? also you have a thermocoupler that senses the heat of the water and works in conjunction with the regulator. have either one or both replaced and the problem will be solved. please rate this thanks
Aug 27, 2008 | Bosch 1600H-LP Liquid Propane AquaStar...
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
