Question about Ovens
I have a chef norfolk trend oven griller my fan forced wont work making grinding sound how do i fix it
SOURCE: I have an old Chef Balmain fan-forced wall oven.
just reset it and it'll stop flashing the help sign. i am just wondering if you still kept your ovens specifications, if you did, would you be able to help me as to the dimesions of this oven. i have the same oven and it died yesterday. i want to buy a new one and wants the measurement so that the new one that i'm looking for woiuld fit exactly in the old one's spot. thanks,
Posted on May 20, 2009
pincer
  • 377 Answers
SOURCE: Chef Oven instructions
may i know what exactly the model # that you have??
Posted on Jul 07, 2009
SOURCE: I have a Chef Select Fan Forced wall oven Model
I have had to get an electrician to replace thermostat.
Posted on Dec 10, 2009
award462
  • 395 Answers
SOURCE: chef gas oven user manuals
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
Posted on Jun 03, 2010
MNfisherman
  • 11896 Answers
SOURCE: I have an old electric Chef Glendale 600 fan
There is a fuse in the back if you remove the rear panel. Check to see if the fuse looks good. If the element is bad, it won't effect the switch, light, or fan. The switch, light, and fan all run off of there own circuit. If that circuits is bad, has a burnt out fusible link, or the electrical circuit board they connect to is bad, then they won't work. You will likely need to trace the wiring from the control panel to the circuit that runs these three things. Use a volmeter to test for power and you can also use an ohmmeter to test for continuity of the circuit itself.
Posted on Oct 07, 2010
Fan in CHEF STARFIRE fan forced oven is no longer working,how do I fix ?
Could be a wiring issue, faulty motor or control knob.
May 17, 2017 | Ovens
Chef Norfolk Deluxe fan forced oven. Oven, lights and separate grill - all lights went out, lost heat and stopped working.
there is a fuse inside the plug,unplug it to check it,please report the other posts
Jun 15, 2015 | Ovens
My Chef Classic Wall mounted fan forced oven stopped working. Its grill section working. Fan and the light in the oven working well. Bot oven doesnot heat up. Please give a tip what is probably wrong?
The bake element has gone bad. They can visually look fine but still be bad. To check and replace that element you will unfortunately need to kill the power and remove it from the wall. Remove the back cover. Check for a low resistance (around 16 ohms) across the bake element. If the resistance is high the element is bad. Google the make and model for a replacement element.
Dec 26, 2014 | Magic Chef Ovens
Where can I source a Chel Select Fan Forced Oven Manual from please?
You can try searching for Chef Select online but the age of your oven may make your search unsuccessful.
Jul 28, 2014 | Ovens
How to fix noisy fan in chef fan forced oven
Possible fault in the bearing bushes , in the first place you can spray a WD40 or even some light oil into the fan's rotor ends where the bearings are located. If the sound reduces clean and wipe off excess oil from the shaft side. Also make sure that the fan leaf is not making the noise due to any dirt accumulation or obstruction.
Jan 09, 2012 | Ovens
How do I ignite the oven on a Chef Benchline 540?
The ignition for the griller on our Benchline 540 isn't working properly - it takes about 10 tries then explodes. Any ideas?
Mar 07, 2010 | Magic Chef 9122 Gas Single Oven
Converting fromTown Gas to LPG in gas cylinders
Hi
Thanks for using FixYa. If your range/oven doesn't seem to work at all, check these:
Fuse/circuit breaker
Check to see if power is getting to the range/oven. If even a light won’t turn on then check for a blown fuse or tripped circuit breaker.
Main wiring
Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to.
Range/oven wiring
There may be a broken or burned wire at the back of the range/oven. If you repair any of the wires, use only proper appliance-grade wire and wire connectors.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Ovens
Jul 07, 2009 | Ovens
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
78 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
