Need to know what requlator I need for using propane with a Bosch wr400 k1. I was given one but did not get the requlator with it
  • kesamrn Sep 11, 2010
    I just need to get all the parts in place, then a pro will do the actually connections. THe plate on the water heater says propane. I have a copy of the manual and it states that I needed the gas regulator installed. If I understand you correctly then I do not need the regulator at the water heater the one at the pickel barrel size tank will be sufficent. Is that correct?
  • 11,800 Answers
You need one that is rated for a gas flow of at least 35KW/120,000 BTU and has a 2 inch connectors - any good supply store will have them. But you must be absolutely sure you actually need it: look on the label and make sure that your unit is for natural gas; if it's already set for propane the the regulator is not only useless but it will create some problems in the long run.
Here is the install manual if you need it
http://www.astravan.com/WR400-1.pdf
You should really let the selection and installing to a pro, this is gas we are talking about.
Posted on Sep 11, 2010
  • Azrael SRL Sep 11, 2010
    Yes, if the heater is already set up for the propane gas supply then you don't need another regulator.
How do I know if my Caloric Heritage gas range is propane or natural gas? It is a used stove that was given to us
Stoves are usually sent from the factory set for natural gas. they have to be converted to Propane. If it is set for propane the flame will be very low on natural gas. If set for natural gas on propane the flame will be very large. The orifices for natural gas are much larger than propane orifices. and the regulator is converted acordingly.
Nov 10, 2014 | Kitchen Ranges
I live in Wisconsin (so it gets cold) and I just built a 1,000 sqft detached garage with 9' walls and I looking for the most efficient way to heat it. I will generally only be using it on weekends, but,...
Hi Rob - There are a bunch of variables that come into play. If you're going to use liquid fuels such as K1 kerosene or "home heating oil" (red dyed diesel fuel without the "road use tax"), you have to consider the tank location. Since home heating oil is really dyed diesel fuel, is reacts to cold just like diesel fuel does. It begins to gel - paraffin separates and the fuel gets cloudy around the 20 degree F mark and can clog the supply lines and filter. It gets worse as it gets colder. You can get around this somewhat by installing larger diameter and insulated fuel supply lines and moving the filter bowl assembly inside where it won't be subjected to that much cold. Your dealer may put additives in the fuel to prevent separation or you can add it yourself. K1 can be added to home heating oil tank to reduce clouding and straight K1 can be burned by an oil burner (you can not burn home heating oil in a K1 heater though). K1 on the other hand, flows just fine at these temps and lower. You'll need to supply storage tanks for these fuels.
The amount of heat or BTU's per gallon of these two fuels is significant. Home heating oil checks in with 50% more heat with around 140,000 BTUs per gallon while K1 has just over 90,000 BTUs per gallon. Cost is another factor. Typically, K1 sells for more than home heating oil, but has the benefits above. Prices for home heating oil and K1 are volatile and change daily and from dealer to dealer. Many dealers will lock prices and / or offer purchasing plans.
Next is natural gas (or just plain "gas") and propane (or LP). Gas is usually delivered via underground supply pipes and propane is delivered by truck to your on-site tank in areas that don't have the underground gas pipe infrastructure in place. The LP dealer will usually supply and install an above ground tank. You'll likely have just LP or both LP and gas available in your area. Heating appliances must be set up to burn one fuel or the other - not both. It is often a relatively inexpensive operation to convert from one fuel to the other, meaning separate appliances for either are not required. Gas prices are usually fixed for different times of the year, while LP prices may change daily and based on the volume used. Lower usage customers often pay more than their next door neighbors that use more from propane the same company. Like home heating oil and K1 dealers, many companies offer price locks and purchasing plans.
Gas and LP heating appliances burn "clean" meaning that there is little smoke, soot or tuning needed. Oil and K1 however, require regular tuning and cleaning to achieve maximum efficiency. Oil and K1 will burn but not rapidly combust - as gasoline would. LP and gas however, will explode if allowed to collect in an enclosed area and ignited by spark from a ringing telephone, etc. Prices of the heating appliance itself come into play as well.
You can heat the space by your choice of fuel and method of heat delivery. Forced hot air is probably going to be your best choice, but you could choose a forced hot water system if you add antifreeze to it. You'll also need a source of water to make up any lost due to pressure relief valve discharges, etc. If you chose the forced hot air system, you could probably get away without the expense of duct work - where a forced hot water design will require baseboard radiant heaters or a fan forced hot water coil.
That should be enough to get you thinking.. good luck!
Lastly, electric heat. Electric heat is 100% efficient, but is probably the most costly to operate. It's listed because it is available - not because I recommend it.
The best thing you can do is insulate. Insulation pays you back quicker with each rise in fuel costs. Put money into proper insulation as you can. Low E glass in your windows, weather strip doors, etc.
Nov 12, 2010 | Heating & Cooling
I have a Bosch tankless propane water heater 125fx. Yes, I know it's ****, we replaced the igniter switch last year. Then struggled with ordering parts to repair a water leak. During the leak, it was...
There is likely an onboard relay stuck in the open position.
This is a gas appliance and should be serviced by an authorized BOSCH repair center to avoid potential catastrophe.
Thanks!!
Aug 06, 2010 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
My Bosch on demand water heater is clogged. I cleaned the inlet line but seems to be inside the smaller copper tubing. HELP!
If you can access the pipe that is clogged, Poor some lime away into it . Let it sit and ad more as needed. the calcium will sofen and ca be flush out. Takes patience. Once you get some flow, fill the tubing with a descaling solution (hardware store) and let it sit. Pool acid works but must be thoroughly flushed out. be careful with acids, always wear gloves.
May 02, 2009 | Bosch & Tankless LP Hot Water Heater
Bosch wol2200 instructions needed
I have a Bosch wol 220 washer, it is not clearing the water on spin. I have checked for blockages and it appears clears.
Feb 18, 2009 | Bosch WOL 2200 Top Load Washer
Bosch dryer not heating
make sure you try it a couple of times. gas takes a long time to travel to the pipes. no way to purge the lines.
check if there is propane in the new tank, check if the valve is open, check if the propane is at the hose going to the dryer already.
tnx 4 using fixya,
drcool
Oct 11, 2008 | Bosch Nexxt WTMC 6500 Gas Dryer
Bosch 1600H-LP Overheating Problem
did you check to see if your temp regulater is working properly? also you have a thermocoupler that senses the heat of the water and works in conjunction with the regulator. have either one or both replaced and the problem will be solved. please rate this thanks
Aug 27, 2008 | Bosch 1600H-LP Liquid Propane AquaStar...
I dont know how to use the webcam feature on my Megxon K1 digital camera and i want to use it !
Hi - You can download the manual from the link underlined in blue below:
Megxon K1
You need to install the drivers for your PC, if you don't have the CD then go here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 05, 2008 | Cameras
Buzzing in KLH R7000
look on the component for details or in the schematic of the device if u can find a voltage requlator that matches the same specifications as in ur system then u will b happy till then u will need the manufacturer requlator good luck windman
Nov 27, 2005 | KLH R7000 Receiver
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
