Question about Maytag Neptune FAV6800AW Top Load Washer
"od" error message when I try to start a wash
  • 526 Answers
I feel you have lost signaling thru the Left Hand Lid Lock.
See this post to get you started; Left Hand Lid Lock Troubleshooting
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Let me know if I can help.......Rich
Posted on Sep 15, 2010
  • 1 more comment
  • martyschuck Sep 24, 2010
    Rich,
    I disassembled the whole left hand lid lock and cleaned all the contacts. I tested with the ohm meter and feel everything is ok except I can't seem to get juice through the reed switch. It remains open. I noticed it operates on 12v dc. Is that correct? Can I test it with a 12v power source to close it? I put the lid lock back on the machine and it didn't change anything by cleaning it. It must be the reed switch or the lid lock isn't my problem. Thank you.
    Marty
  • FAV6800A FAV9800A
    FAV6800A FAV9800A Sep 24, 2010
    Marty,
    If you have the Left Hand Lid Lock on the work bench with and with an external magnet you are testing for continuity thru the Left Hand Lid Lock with your Ohm meter. When you bring a magnet near the Magnetic Reed Relay it should close and give you a path via the wiring harness for 12VDC back to the Control Board. This 12VDC can only be measured if your DVM common lead is referenced to the 12VDC common on the Control Board not Washer chassis ground. This 12VDC is signaling voltage for the washer Control Board input for “Lid is Open” and “Lid Is Closed” I’ll bet if you open the washer lid and press the Start key pad button you don’t take a “OP” error code for Lid is open.
    Let see if I can post a Pic and give you the Pin out to test for proper closing of the magnetic reed relay in the Left Hand Lid Lock on the work bench. FIXYA has become a real pain to post Pics’s. If the Pic comes thru I will give you additional info. The most common problem is severe corrosion in the Left Hand lid lock (due to proximity of Bleach Dispenser Reservoir). Most “OD” error codes are caused by the Black Lead on the magnetic reed relay in the left Hand Lid Lock. Did you remove the top cover of the Left Hand Lid Lock to observe in side? I will post a pick if I can. If not I will try to find a previous post I have done on FIXYA for other owners as you and I to show how to remove the Left Hand lid lock top cover. You have to be careful not to break off the lid mounting tabs on the Lid Lock.
  • FAV6800A FAV9800A
    Marty see this post Left Hand Lid Lock Troubleshooting
    http://www.fixya.com/support/t3295201-ne...
    and this back when I could post pics.
    http://www.fixya.com/support/t3124779-od...
    I can’t post pics any more on this site I believe they have locked me out. I’m done with this site see me as dh1200s on this sitehttp://forum.appliancepartspros.com/wash...
    I will ttry to help you thru this issue with Pic's and post just post there. I'm a little slow with shift work schedule but I will reply..........Rich
Washer won't start. Display shows "od"?
od is an open door error if the door is closed then you would have to replace the door switch or the wiring that goes to the door switch first try to open and close the door and make sure it seats properly in the small hasp type holder if the error code still persists then check the wiring to the switch and if the wiring looks like everything is connected well then you would have to order a new door switch i hope this helps in your appliance situation and please remember to rank this solution if you have any more questions please message me back. Have a great day
rickead1
Aug 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
Won't start/"od" displayed
Yes, OD is a open door error code. You may need a new door latch assembly. pn 22002262.
Jul 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Od code when trying to star
You have lost signaling from the Left Hand Lock. The washer has not see the lid go open thru the signaling with the magnetic reed relay in the Left Hand Lid Lock.
See if this post will help you Left Hand Lid Lock Troubleshooting
The p/n for the Left Hand Lid Lock is 25001048
Some other handy links. The Service Manual for reference. Sears Parts Direct for reference.
Rich
Jun 14, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Hi! getting od error and waher will not let me start any cycle
Hello, the "od"error you getting means the control did not detect that the door was opened between washes. Try opening and then closing the door again and if the error message is still present, there may be a problem in the door switch mechanism, the electronic control or the wiring between the two.
Thanks
Jun 05, 2010 | Maytag Neptune MAH6700A Front Load Washer
"od" error code Maytag Neptune FAV6800Aww
At 12 years of age, your Maytag may be telling you it needs to be replaced.
Sep 23, 2017 | Maytag Neptune FAV9800AW Top Load Washer
My machine has a code and is full of water
can you provide the full model # and also the full error message?
Sep 08, 2008 | Maytag Neptune MAH5500B Front Load Washer
Od error
Dear HAPPYFACE,
ngfam at you service!
Try to unplug it and then reboot it!
Otherwise
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
Aug 19, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Washer, Neptune TL
This means the computer is not seeing that you opened the lid between cycles 3 times. So likely the lid locks are faulty. PLEASE rate my help as solved all other ratings dock us
Oct 02, 2007 | Maytag MAT13MN Top Load Washer
Error Code "od" while trying to start machine
Could od mean overload? Reduce or actually weigh load and re-try
Apr 15, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
419 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
