Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
8 yr old GU1200 stopped mid cycle - no apparent reason - no response to buttons - appears dead?
  • 375 Answers
These dishwashers have a thermal fuse in the control panel. If it overheats for some reason (sometimes a bad connection on the fuse itself causes that)it will turn whole machine off.
  1. Disconnect power to dishwasher. Remove screws holding the control panel from the side of the inner door. Remove control panel. If it does not come off - remove all screws on the inner side of the door and separate the inner and outer door.
  2. Fuse is on the right side on top of the control board. it usually has tan or black or yellow wires to it. Disconnect wires and check fuse for continuity. if none - replace fuse. Here is your part
Good luck
Vlad
First Choice Appliance
Posted on Sep 11, 2010
  • sariahbink Dec 04, 2010
    Thanks to you my husband was able to fix our dishwasher!!!!!!!!!!!! We had NO money to buy a new one or pay someone. Thank you SOOOOOOOOO Much!!!!
Why did my washer stop mid cycle and now won't work at all?
Hope your warranty is still in effect. It sounds like your control board has an electronic problem that will require replacement; typically around $135 for the part and $110 for the service visit.
Aug 21, 2014 | Zanussi Washing Machines
In mid cycle machines went dead. Power is ok at
http://www.servicematters.com/maytag_library/docs/16022808.pdf
use the service manual troubleshooting procedure above to isolate your issue and hopefully effect a repair.
May 25, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Young dryer quits in mid cycle.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 05, 2010 | Estate EED4300TQ Electric Dryer
Hi. We have a 3 yr old top-o-the-line Samsung
turn machine off at power point the door should then unlock after a couple of minutes. Drive belt may be broken as well.
Dec 22, 2009 | Washing Machines
GU1200 will not drain. Seems to have stopped mid-cycle. Pressed can cancel button , now it just blinks.
Does this model have a rotary control? If it does switch the unit off at the mains and move the controller to the end position and then switch back on. If the pump is working it should then start the pump to drain the machine.
If it doesn't have a rotary control just switch off and leave for a few minutes. When you switch back on it should then pump the water out.
If the pump isn't working you should be able to open the door with the power off. Dishwashers don't fill up with water so water won't leak out. Clean the filters and look for something blocking the outlet.
Aug 29, 2009 | Whirlpool Dishwashers
My dryer has been difficult to start lately especially if stopped mid cycle. The lights are all on but it won't start up. Today I only used it 2 times and it was very difficult to start after pressing many...
You may be experiencing "Heat Retention" by stopping your dryer mid-cycle, which you should NOT ever have to do! If you have a minor vent restriction or if you open the dryer mid-cycle when the heat is on, this will cause a disruption in the airflow and rising temperatures can keep the dryer from restarting until it has been cooled long enough.
Check your vent all the way to the outside for restrictions/obstructions every 6 months. Clean your lint filter after each load and DO NOT stop the dryer mid-cycle!
Note: Stopping the dryer mid-cycle can also cause severe burns and even melt polyester fibers.
Jul 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
No power
Hi lushman001
I'm Harvey the Master Plunber.
Your question is: your 3-yr-old dishwasher (Whirlpool 24-inch ) stopped in mid-cycle. A small amount standing water in the bottom of the washer. None of the control panel buttons were lit up and none of them will work. NO POWER
First check all the breakers (or fuses).
Second check the electrical connections. If you're not a qualified electrician or service tech then call one. It"s under the unit behind the kickplate.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher stopped mid-cycle
you have a bad thermal fuse in the control panel. it's the whit thing with 2 wires going to it
Sep 07, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
555 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
