Question about LG LRTBC1825T Top Freezer Refrigerator
Refrigerator runs all the time ,the freezer compartment on the outsie is cold.
    Problem Solver:
  • 10 Answers
Check the seals on the doors- a decent seal should be able to grip a piece of paper, if the paper just drops out or pulls out very easily you need to replace the seal. There are many excellent online guides on how to change a door seal, just make sure you get the right size.
Posted on Sep 11, 2010
My freezer is freezing and the refrigerator is not cooling. The refrigerator runs all the time
If your refrigerator freezer compartment is cold, but the refrigerator compartment is warm--It could be a defrost problem. When a defrost problem occurs, it is usually the fault of one or more of three basic parts: defrost timer/adaptive defrost control, freezer thermostat or the defrost heater element. See in detail how to dx and fix: Refrigerator Defrost Parts .
Jul 25, 2014 | Refrigerators
Model 106.9630280 The freezer is working but
you probably have a bad air circulation fan or a restriction in the ductwork between the freezer and the refrigerator that the circulation fan supplies the cold air from the freezer to the refrigerator compartment. you should be able to hear the circulation fan motor running when the unit is in normal operation mode. the only time the fan will not be running is when the unit is in defrost mode which occurs once every six to eight hours depending on the defrost timer in your unit.
Mar 14, 2010 | Refrigerators
The freezer is working just fine but the refrigerator is not cold at all
CHECK THE FREEZER FAN MAKE SURE ITS RUNNING AND IF THE BACK WALL OF THE FREEZER IS FROSTED UP YOU HAVE A DEFROST PROBLEM. I ONCE FOUND SOMETHING FELL BEHIND THE BASKET SO THE DOOR DIDNT SHUT ALL THE WAY, CHECK THIS AS WELL
Jan 13, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The top of the freezer part is getting cold but the bottom of the Refrigerator part is not getting cold. The Refrigerator is only 10-11 months old ; what is wrong?
you need to check and see if the fan in the back of the freezer compartment is running. when the fan is not running the cold air will not be passed to the refrigerator compartment. open the freezer door and turn the unit to its coldest setting until the compressor kicks in then listen to hear the fan in the freezer compartment.
Sep 16, 2009 | Refrigerators
My bottom refrigerator is not cold. The freezer is okay.
Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
Jul 22, 2009 | Refrigerators
Freezer not freezing properly
You have a manual defrost freezer . Ice build up of over 1/2" can act like insulation on wires . If you have no frost build up , and runs constantly , then compressor or refrigerant leak is the problem . Advise to replace freezer . Only 2 parts on manual defrost freezer...compressor and cold control . Compressor will not run if bad cold control . If you have a leak , very expensive to have repaired .
Jul 10, 2009 | Whirlpool GD2SHGX Refrigerator
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
Refrigerator
Sani, see if the evaporator fan is running. That would be the fan in the freezer compartment. It moves the cold air to the bottom. If that is ok, then you may have a defrost problem. Is the freezer panel in back all frosted over? If so, it's probabley a defrost issue. Check these things first and post back...Catriver.
Mar 12, 2007 | Whirlpool GAFZ21 Bottom Freezer...
Refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Jan 02, 2007 | Jenn-Air JFC2089HE French Door...
LG LRTBC1825T Top Freezer Refrigerator Logo
116 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
