Question about Qca Spas Paradise Hot Tub
My readout says econ and is not so warm have my kids wrecked it
  • 310 Answers
ECON is a different mode of operation. In this mode it only looks at the temperature of the spa once a day. You need to look at your manual and use the topside control to change from ECON to NORMAL operation.
Posted on Oct 28, 2010
WHAT IS THE PURPOSE OF THE COOLANT TEMPERATURE SENSOR IN 1997 CADILLAC DEVILLE
the coolant temp sensor lets the cars computer know that the engine has warmed up and to allow the fuel injection to go to what is called "closed loop mode" this is where max fuel econ and low emmisions are available , the driver can know car is not in closed loop mode by the higher idle that cpu adds to allow car to warm up faster
also on cadillacs/buicks only it lets the air condition system go to open vent where it allows fresh outside air to be drawn in to cabin
Aug 29, 2014 | 1997 Cadillac DeVille
Econ button
Econ button turns off the A/C but leave the climate control on (without A/C). The climate control will try to get to the set temperature but, obviously on hot days it never will without the A/C on. I use it during the winter and cooler temps, it saves gas not running the A/C, thus econ (economy).
Apr 04, 2014 | 2006 Volkswagen Passat
Turn on ac to auto then switchs to econ on its own and air blows warm
Mine did the same thing. Diconnect the Positive battery cable. Leave it off for about 5 minutes. Reconnect and your system will reset itself. Get in and watch the numbers cycle. Don't start your car until the cycle is complete. If it resets but reverts bach to the "econ" thing then you need to charge your system (Freon).
Apr 15, 2011 | 1992 Buick Roadmaster
My 96 Sedan DeVille Climate control system will not toggle between Econ and Auto Modes. It will only operate in the Econ Mode. The Auto Mode lights up when I push the button but immiediately switches...
This usually means the ac refridgerant is low. In Econ mode the ac compressor will not turn on, your car is staying in Econ to avoid damage to the compressor. If you are low on refrigerant it means you have a leak. Don't just buy a can and refil, have a professional shop check for leaks and fill the system with the proper oil and add refrigerant to the proper pressure.
Mar 07, 2011 | Cadillac DeVille Cars & Trucks
I have a 1996 Cadillac Sedan DeVille. This spring...
If the a/c does not engage as a result of the electronic control system in your 1996 Cadillac, the climate control system may need to be replaced.
However, if the problem is being caused by low charge of R134a in the system, have the system charged before changing that electronic part.
I have never seen a Cadillac Climate Control System do this, which leads me to believe that it may be more electronic than refrigerant pressure related.
If the refrigerant pressure was low in the system, the climate control system should still stay on 'auto' mode, I think, and simply blow warm air.
May 19, 2010 | 1996 Cadillac DeVille
I have a paradise spa the readout keeps saying econ what does this mean also Im having a hard time getting it to stay at 104 degrees
The econ sounds like a maintance mode that is to say economey mode. You probally have a simple way to set this back to a use mode but you will need to look this up in your book or find someone fimaller with this spa. Most books can be found on line if you look it up by brand and model number. Good luck.
Dec 14, 2009 | Qca Spas Paradise Hot Tub
The climate control system will not work in Auto mode but only in Econ mode in my 1989 cadillac fleetwood. I press Auto but it goes to Econ.
Your A/C system has lost its refrigerant, and will automatically go into "ECON" at that time. System will have to be leak tested , repaired, and recharged. Hope this helps.
Apr 09, 2009 | 1989 Cadillac Fleetwood
Qca Spas Paradise Hot Tub Logo
124 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
