Question about Coleman Heating & Cooling
My Coleman DAGT gas furnace blower fan will come on at time when there has been no heat cycle or will stay on after heat cycle is done. I have replace the the themostat and put in new intregated control panel. It still does this. What can I do to keep the blower from coming on without a reason? The little green light will blink 5 times when the blower is on without the heat cycle going.
  • Coleman Master
  • 2,598 Answers
Try looking at the afc the fan control might need cleaning at the back of it could be filled with dust, or blocked air filter afc works on temp rise to start fan running and temp fall to stop running check settings on the afc thhey should be in your manual or afc might need changing
Posted on Sep 11, 2010
I have a Coleman evcon gas furnace that the blower comes on for no reason . Does not do this all the time . It comes on and runs for about 3 minutes and shuts off . Does this 4 or 5 times in a row .
James, If it has a electronic board, it has a heat sensor built into furnace that turns fan on to get all the heat out of furnace for efficiency. May need adjusted a bit, or replaced.
Feb 29, 2016 | Heating & Cooling
Coleman evcon furnace
How old is your furnace? Does it have a circuit board that controls everything, or are there separate controls for each function?
Nov 19, 2013 | Heating & Cooling
My Coleman gas furnace turns on, ignites and the flame will keep going out. The entire time the blower motor will stay on humming until its hot to the touch. If I tap the gas pipe I can get the pilot to...
IT could be the temp is too cold at night and the tank cannot make vapor ie gas, The liquied has to boil inside to make the gas you can get a heat blanket to warm your tank. Ask you gas suppier if they have one.
Mar 17, 2011 | Coleman Propane Forced Air Heater...
I have a coleman furnace it comes on the electric igniter glows red the gas comes on then the blower starts and the fire goes out it gives 2 different code for this 1 is ignition failure and the other is...
I would have the ignition control board replaced. That is what tells the gas valve to come on and if there is flame or ignition it will keep the gas on if the flame sensor gives the board a signal that the burner is lite. By you shuting power off and on to the furnace it resets the board and it will go through its cycle again.
Feb 10, 2011 | Coleman Heating & Cooling
I have a Coleman Evcon gas (propane) furnace. When the t-stat is switched to heat the furnace heats up but the blower will never turn on. The unit then shuts down and tries to cycle again. I have replaced...
If the unit fires but the main blower fan doesn't come on the the unit is shutting off on a temp high limit switch and it sounds like the problem is the main blower fan motor or control
Jan 18, 2010 | Coleman Heating & Cooling
Coleman Presidential II Model 7656A Mobilehome Furnace blower p
have you changed t-stat? if so you need to increase the heat anticipator. if you have a fan limit switch, the setting may need adjusting. Thay will change with age
Nov 01, 2009 | Heating & Cooling
A 1979 Colman RV furnace. Blower shuts off shortly after burner shuts off leaving a hot heat exchanger. After 15 seconds blower comes on again blows for 10 seconds shuts off comes on in 15 seconds blows...
The fan limiting switch is acting up. It should stay running until lower temp is reached. It will cycle until the temp stays below or at the low setting. Limit switches are adjustable.
Jun 09, 2009 | Coleman Propane Forced Air Heater...
Heater blower motor cycles on and off (frequently). I have a class 2 LR95329 Honeywell Thermostat
The clicking noise is a relay or switch of some sort. You are right about that. I have 2 questions. 1) does the thermostat have a mercury bulb in it? 2) when the fan shuts off and on, does the burner stay on?
Nov 05, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
112 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
