Question about Samsung Televison & Video
I can't access "advanced settings" while trying to set up my new 6400 series tv. The "advanced settings" line is not highlighted. The picture is too black and I want to change that. Thanks, Ellen
  • 43 Answers
SOURCE: Connect LG 42LY95 LCD to Toshiba Laptop
Hiran
can you use the vga source from your laptop to the pc input on the LG a standard vga monitor cable will do then set your laptop to output the vga signal
Scott
Posted on Mar 23, 2008
a-team2009
  • 4 Answers
SOURCE: TV PICTURE SETTINGS REVERT BACK TO DEFAULT LG 32PG6000
hi it sounds like when tunned in tv it was tunned in shop mode.
do a factory reset and choose home when installing
Posted on Mar 01, 2009
SOURCE: memory loss and inability to channel scan Olevia H537
Reintall the latest firmware and it will solve the problem.
Posted on Apr 07, 2009
SOURCE: Poor picture quality on Toshiba Regza 32AV555DB LCD TV
i had the same problem! i just changed my scart leads to some quality gold ones, this made the picture a lot crisper . hope this helps :0)
Posted on Apr 30, 2009
  • 210 Answers
SOURCE: Hello, I would like to retune my Tevion TV to
try putting tv in Analogue then press menu you should now be able to enter setup menu and do first time Installation
Posted on Oct 26, 2009
My Vizio E320i-A0 tv, has barley any picture when i pug in and turn on, VERY faint logo on screen, How do I fix it?
The picture settings may have been set very low. You can reset to the factory default settings using the steps below. You may also try selecting different inputs to see if the brightness is the same on all of them.
1. From the Picture Settings menu, use the
Arrow buttons to highlight 'More' , then press OK.
2 . Use the Arrow buttons on the remote to highlight 'Reset Picture Mode', then press OK. The TV displays, "Are you sure
you want to RESET Picture Settings to the factory defaults?"
3 . Highlight Yes and press OK.
4 .Press the EXIT button on the remote.
A manual is available here:
http://cdn.vizio.com/documents/downloads/hdtv/E320iA0/UM_E320iA0.pdf
Jan 17, 2015 | Vizio E320i-A0 32 Class LED Smart TV
Tip
SONY ERICSSON INTERNET SETTINGS LOOP MOBILE Compatible For All W Series, K...
1. Open Menu > Settings > Connectivity tab. > Internet Settings > Internet profiles > New profile.
2. Press Add.
3. Open Name and type Loopwap.
4. Open Connect using > New Account > GPRS data.
5. Fill your parameters as shown below:
Name: Loopwap APN: mizone User id: Mobile No. Password: mmsc 6. Press Save.
7. Highlight Loopwap and press Select and press Save.
8. Highlight Loopwap and press More, then open Settings.
9. Fill your parameters as shown below: Connect using: Loopwap Use proxy: Yes Proxy address: 010.000.000.010 Port number: 9401 Username: None Password: None 10. Press Save.
11. Highlight Loopwap and press More, then open Advanced > Change homepage.
12. Select Name and type Loopwap, press OK.
13. Select Address and type http://atcafe.loopmobile.in , press OK.
14. Press Save.
15. Return to Internet profiles.
16. Highlight loopwap and press Select.
17. To start WAP session return to Menu and open Internet services.
18. Press More > Go to and select Loopwap.
19. To finish WAP session press More > Exit WAP.
on Sep 02, 2009 | Nokia 9500 Communicator
Samsung 6400 3d 55 settings
SAMSUNG series 6 6400 User Manual Download the user manual to this TV by this site. It has all details.
Electro help
Dec 11, 2014 | Samsung 6400 Series UN55F6400AF 55" LED...
Sound bar setup
see this . God bless you
831d4bf7-b33d-475c-b709-bca857d43eb3.jpg2e546a78-185c-49d6-8958-689f2c5119fe.jpeg2c103a19-a29a-4301-9c23-1f3896cea0f0.jpegc9c5b78a-6c99-43ff-be85-91afda28411e.gif
Jul 14, 2013 | Televison & Video
How doi reset the picture after replacing the bulb and housing
It is not required to set the Picture after replacing the Lamp and Housing. To change the Picture Settings press the MENU button on the Remote, highlight PICTURE and press OK. There you'll get the option to select Picture Preset Mode, Picture Settings, Screen Format, Advanced Picture and Screen Adjust mode. You can customize the settings by selecting the each Picture Menu options.
Click here to download the manual of the TV. View page # 39 for the instructions to change the Picture Menu.
Good Luck!
Thanks for using FixYa
Dec 01, 2010 | RCA M50WH185 Television
SAMSUNG LE32R73BDX/XEU TV Digital TV Stuck on bbc1, no access to DTV menu to reset or retune. Sometimes picture is frozen, always it shows BBC banner and Mono. Standby - Info - menu - Mute - Power is not...
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Sep 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
C-rem
Try a new battery - The D1 series will refuse to take pictures in this manner if power is low or inconsistent.
Feb 02, 2009 | Nikon D1H Set Digital Camera
Child Lock is on and I am second owner of tv with no code
This function will block out the picture and sound of the selected channel or video input.
It can also be used to keep the TV from being viewed for a scheduled time period that you set.
The code to enter the Locks feature is a four digit secret code number. The factory preset code is 0000.
Use the number buttons to select access code.
Use CURSOR G or H to highlight function and then press the SELECT button.
To change the access code number, select Change Access Code. Enter a new four digit key number you prefer.
Select CHANGE ACCESS CODE to change factory preset code (0000) to your preference.
When ENGAGE LOCK is selected, SET CHANNEL LOCK, SET INPUT LOCK, and SET FRONT PANEL LOCK can be set individually.
When SET CHANNEL LOCK is turned on, the picture and sound for the chosen channel will be blocked out.
When SET INPUT LOCK is turned on, the picture and sound for all video inputs and the picture and sound for channels 3, 4 will be
blocked out.
When FRONT PANEL LOCK is turned on, all buttons on the Front Panel will be deactivated, except the Power button.
When TV TIME LOCK is turned on (r TIME LOCK) you can set the BEGIN and END times (CURSOR E) and the TV
cannot be viewed during that time period (Set clock first). Use CURSOR G or H to highlight ONCE (TV will time out one time
only), DAILY (TV will time out every day), WEEKLY - SUN~WEEKLY - MON (TV will time out one time a week) or OFF (to disable
this function).
When MOVIE RATINGS is selected, you can block various types of movies and video tapes based on motion picture ratings. Picturein-
Picture will also be blocked automatically (see page 45).
When TV RATINGS is selected, various types of television programming based on a parental guide ratings will be blocked.
Picture-in-Picture will also be blocked automatically
If you forget your secret code, use the factory code 7777 to erase your key number. This will reset the secret code number back to the
factory preset 0000.
Press EXIT to quit the menu.
Dec 07, 2008 | Hitachi 57F500 57" Rear Projection...
Lexmark 4800 series reset printer to factory wireless settings
i have a lexmark printer its plugged in but dont have a icon to make it print
Oct 07, 2008 | Office Equipment & Supplies
Sending pic's & email on cell
function atgss_LoadToolbar() { if (document.getElementById("topToolbarArea")) atgss_loadTopToolbar(); if (document.getElementById("bottomToolbarArea")) atgss_loadBottomToolbar(); } function emailAction(){ if(!IsIE()) { var styleVar= document.getElementById("content").style; styleVar.height = "inherit"; } } function helpAction() { if(!IsIE()) { var styleVar= document.getElementById("content").style; styleVar.height = "inherit"; } } function rateAction() { if(!IsIE()) { var styleVar= document.getElementById("content").style; styleVar.height = "inherit"; } } function atgss_loadTopToolbar() { var topToolbarArea = document.getElementById("topToolbarArea"); var topToolbar = new solutionToolbar("topToolbar", "","Close","2").toolbar; topToolbar.addButton("print", "Print", "http://www.wireless.att.com/support_static_files/TempSelfService/cingular/assets/solution-toolbar/btn_print.gif", "http://www.wireless.att.com/support_static_files/TempSelfService/cingular/assets/solution-toolbar/btn_print.gif", null, atgss_toolbarPrint, "right"); topToolbarArea.appendChild(topToolbar); } function atgss_loadBottomToolbar(){ var bottomToolbarArea = document.getElementById("bottomToolbarArea"); if(bottomToolbarArea) { var bottomToolbar = new solutionToolbar("bottomToolbar", "","Close","2").toolbar; bottomToolbar.addButton("back", "", "http://www.wireless.att.com/support_static_files/TempSelfService/cingular/assets/bt_back.gif", "http://www.wireless.att.com/support_static_files/TempSelfService/cingular/assets/bt_back.gif", null, atgss_BackOrClose, "left"); bottomToolbarArea.appendChild(bottomToolbar); atgss_InitRateDialog(); } } function atgss_toolbarPrint() { atgss_openWindow('/answer-center/panels/solution/printSolution.jsp?solutionId=KB63131&t=&ft=&ps=&locale=en_US&_dyncharset=UTF-8&viewMode=NORMAL&windowType=SAME&highlightInfo=&isRecord=false#','printSolution','menubar=yes,scrollbars=yes'); } function atgss_BackOrClose() { atgss_Back(); } function atgss_Back() { history.back(-1); } function atgss_closeTopToolbar() { var toolbar = document.getElementById('topToolbarArea').childNodes[0]; toolbar.setToolbar(document.getElementById('topToolbarArea').childNodes[0]); toolbar.closeDisplay(); } function atgss_closeBootomToolbar() { var toolbar = document.getElementById('bottomToolbarArea').childNodes[0]; toolbar.setToolbar(document.getElementById('bottomToolbarArea').childNodes[0]); toolbar.closeDisplay(); } function atgss_isEmailFormValid() { var isValid=true; var errorMsg=""; var emailDlim =','; var toAdd = document.getElementById('to').value; var fromEmailAdd = document.getElementById('fromEmail').value; var fromName = document.getElementById('fromName').value; if(atgss_isValidateEmailAddresses(toAdd,',')==0){ isValid=true; } else { if(atgss_isValidateEmailAddresses(toAdd,emailDlim)==1){ errorMsg+='Invalid Email Address Format - To'+"\n"; } if(atgss_isValidateEmailAddresses(toAdd,emailDlim)==2){ errorMsg+='Email Address cannot be blank -To.'+"\n"; } isValid=false; } var fromEmailArray = atgss_splitString(fromEmailAdd,emailDlim); if(fromEmailArray.length !=1){ errorMsg+='Only One EmailAddress is Allowed- From'+"\n"; isValid=false; } else{ if(atgss_isValidateEmailAddresses(fromEmailAdd,emailDlim)==1){ errorMsg+='Invalid Email Address Format - Your Email'+"\n"; isValid=false; } if(atgss_isValidateEmailAddresses(fromEmailAdd,emailDlim)==2){ errorMsg+='Email Address cannot be blank - Your Email.'+"\n"; isValid=false; } } if(atgss_isEmpty(fromName)){ errorMsg+='From Name cannot be blank.'+"\n"; isValid=false; } if(isValid){ emailFriend = new EmailFriend(); emailFriend.to= document.getElementById('to').value; emailFriend.fromName = document.getElementById('fromName').value; emailFriend.fromEmail= document.getElementById('fromEmail').value; emailFriend.subject = document.getElementById('subject').value; emailFriend.comment = document.getElementById('comment').value; emailFriend.excerpt = document.getElementById('excerpt').value; emailFriend.title = document.getElementById('title').value; emailFriend.url = document.getElementById('url').value; emailFriend.solutionId= document.getElementById('solutionId').value; if(__ppr_emailToFriendAction) { __ppr_emailToFriendAction.transact(); atgss_resetEmailForm(); atgss_closeTopToolbar(); //alert('Your mail has been sent.'); document.getElementById("emailToAFriendSuccess").style.display="block"; } } else { alert(errorMsg); } } function openEmailWindow(){ window.open('', "_self"); } function atgss_resetEmailForm(){ document.getElementById('to').value=""; document.getElementById('fromName').value=document.getElementById('oriFromName').value; document.getElementById('fromEmail').value=document.getElementById('oriFromEmail').value; document.getElementById('subject').value=""; document.getElementById('comment').value=""; }
Fact:
Symptom:
Internet access Accessing WAP or MEdia Net F
  1. From the standby screen, press Menu.
  2. Select MEdia Net.
  3. Select Browser Profiles.
  4. To set MEdia Net as the default Browser Profile,
    highlight MEdia Net and press Options.
  5. Select Activate.
  6. With Browser Profiles highlighted, press Select.
  7. With MEdia Net highlighted press Options.
  8. Select Edit.
  9. Verify the following settings:
    • Profile Name: MEdia Net
    • Home URL: http://device.home
    • Proxy: Checked
    • IP Address: wireless.cingular.com
    • Port: 80
    • DNS: Unchecked
    • DNS 1: Blank
    • DNS 2: Blank
    • Bearer: GPRS
  10. Select Advanced Settings, and press the center navigation key.
    • APN: wap.cingular
    • Username: <leave blank>
    • Password: <leave blank>
  11. Save.
  12. Attempt to access MEdia Net.
Jul 27, 2008 | Cell Phones
Televison & Video Logo
191 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
