Panasonic CQ-DF903U CD Player Logo
Posted on Sep 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to program the presets for radio - Panasonic CQ-DF903U CD Player
Anonymous
Level 2:
Novelist:
  • Expert 127 Answers
  • Posted on Sep 11, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
127
Questions
0
Helped
51277
Points
411
Hi, it sould be easy, i have never do this one before, but, normally. you need to find SEARCH UP or DOWN.
you may have 6 or 10 preset staions this due to 6 CD or 10 CD
PRESS SEARCH UP find the station you want KEEP PRESSING No 1 POSITION, you should hear a BEEP or the No. 1 station will FLASH, and let GO of the BUTTON, this STATION IS SET.
the next station PRESS SEARCH UP find station KEEP PRESSING No. 2 a beep should be heard or flash station No2 is set and let GO of the BUTTON. this STATION IS SET,
that is the basics and the same for all the stations
1helpful
I have a 2002 Pontiac Grand Am how do i set the traffic, program, info,buttons
You don't set these buttons. The traffic button scans Radio Data Service (RDS) information from radio stations near you for Traffic information. The Info button changes what RDS information is displayed for the current station.
The numbered preset buttons are the only buttons on the radio you can program. Too program a preset, tune the station desired and hold the numbered preset button down until you hear a beep.
1helpful
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
How can we preset radio stations on RD-N1
I'm not familiar with this particular stereo but typically radio presets are programmed by manually seeking out your favorite channel. Once you' be tuned in, press and hold the button (usually numbered 1-5 or 1-6 for preset programming) hold the button until you hear a beep or the display flashes briefly. If this is a newer touch screen style radio, these instructions may be antiquated and most likely insulting :)
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
2helpful
Custom programing the radio
To set Radio options, press submenu in Radio
mode.
?? Select Add Preset to save current frequency
into presets.
?? Select Delete Preset to remove current
frequency from presets.
?? Select Delete All Preset to clear all presets, and
next time when you enter Radio Mode, Sansa
e200 will search automatically.
?? Select View All Presets to view all preset
frequencies. The autoscan option will replace
existing presets.
14helpful
2answers
LG LX-M240 operating instructions: I cannot set the presets
Owner's Manual is PN 3834RH0020U
On pg13
1. Press TUNER/BAND to select AM or FM
(Leftmost rectangular button on left of volume knob)
2. Select station by using TUNING +/-
3. Press PROGRAM/MEMO on the remote
A preset number will appear.
4. Press PRESET +/- (or PRESET ^/v on remote) to
select the preset number you want.
5. Press PROGRAM/MEMO again. The statio is stored.
6. Repeat above for more stations.
Believe you can store up to 30 stations.
Stations on presets 1, 2 and 3 take longer to 'kick in' when listening to the radio
as they are the 'tens' prefix for the preset numbers. 4 - 9 'kick in' immediately.
4helpful
2answers
Preset Radio Statios
I just dug out the manual and have now programmed a preset.
Instructions:
1) Make sure there are a pair of working AA batteries behind the second (inside) compartment door as these power the memory (mine were Duracells with an expiry of 2001 and had worked all the way through to 2010 before finally failing!)
2) Find the frequency you want with the Up/Down button
3) Press the M button - you will get a flashing M on screen
4) While the M is flashing, press one of the numbered preset buttons.
2answers
Radio Code and procedure to program it in
I am not sure what you want to program? The radio presets or the entire radio. I don't believe that you have to program a radio to a specfic vehicle from Ford in 2000. I think you can just swap them out and they should work. The 2006 and 2007 you have to program the radio to the vehicle. If you are just trying to set the presets just hold the button in for about 3 or 4 seconds and the preset will be on there. If you are trying to diagnose a problem with the radio then hold the preset #5 and #6 at the same time for at least 2 seconds and release them. It will go into a self test mode and check the system out. To exit the diag procedure wait at least 10 seconds from touching any other buttons then press preset #6 to exit. Good luck.
'87 Honda Accord factory radio
Find radio station you want to program and then hold on which number you want it to be programmed to like preset 1-2 and so on, when you hold (1) for about 3-5 second you'll hear a beep then release preset button and its programmed to 1. Good Luck
1helpful
5answers
Timex T600
Can anyone tell me where to obtain a owner's manual? I bought this clock used.
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
