Question about Yamaha Televison & Video
Our Yamaha DVR C300 player suddenly won't play ANYTHING. Put any kind of disc in and it tries to load each disc and at the end says "NO DISC". Any tips??
  • 85 Answers
Hi there. take the lid off and try cleaning the laser lens with a cotton bud.its next to the small round platform that the disc sits on when loaded,and looks like a pale blue-ish round bead,about the diameter of a cigarette end...if the disc spins very slowly,on the other hand,its possible the spindle motor is faulty..dont bother with a cd lens cleaner,they are worse than useless!! hope this helps,steve
Posted on Sep 11, 2010
MY TOSHIBA DVR MODEL DR420KU WILL NOT RECORD ON DISC. IT KEEPS GIVING AN ERROR CODE AND NOW IT WILL NOT PLAYBACK DVD-R DICS, BUT IT WILL PLAY MY DVD+R DISCS. WHAT COULD BE THE SUDDEN PROBLEM?
see the cause and remedies:
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Finally the OPU optical pickup contain lasser beam, NOT are reading the TOC from DISK+ Syscon can be defective, you must go to the repair shop TV for fix it see the diagram attached, is a complex equipment.
God bless you
Jul 16, 2012 | Toshiba RS-TX20 DVD Recorder
DvD disc won play
the lazer might not be seeing the disc properly try a disc cleaner which has nylon string on it and they clean the lazer lens
Jul 06, 2010 | Onkyo DV-SP800 DVD Player
Dvr?
Many (not all) sets will give you the 'blue screen of death' (just like a crashed Windows installation but with even less information) if they have no signal input.
You didn't mention where your TV signal comes from; antenna, cable or satellite box and how it is routed.
DVD players normally put some kind of logo on the screen while they are trying to read a disc so the screen shouldn't be totally empty unless the player has failed altogether.
I'd recheck cables for seating and if you have another TV set of some kind, check to see if you are getting any signal for the set to see.
Feb 01, 2009 | LG 42LC2D 42 in. LCD HDTV
My Sony DVP-cx995v stopped playing DVD's
I had the same "Cannot play" problem - happened suddenly, I don't think I was doing anything unruly at the time.
After checking repair (exchange) prices in excess of $250 from Sony, I decided to open the cover to see if I could see anything wrong - normally a futile exercise with electronics except that in the past I have cleared errant disks that have lodged themselves near the drive/player at the rear of the library.
Upon opening and watching the library try to load and play I noticed the drive itself was not spinning the disk once loaded. It would sit for awhile, thinking about it I'm sure, then would unload and load the next dvd, again failing to spin.
I thought okay, maybe try to spin the dvd while in the player to see if it's jammed or otherwise hard to turn. It was not hard to turn and spun freely. In fact, when I put my finger through the hole at the exposed side of the player at the hub to spin the dvd, clockwise, it suddenly started to spin - and play!
I put the whole thing back together to test and all seems to be working fine at this point. Not sure what would cause the motor to stop spinning and remain in that state through poweroff/on cycles etc. but I'm sure this is not the last time I will have trouble of this kind.
I would note that when replacing the library back in its home on the shelf, be careful not to tip the library, especially toward the player area because the disks will spill out of the carousel near the player and become jammed when you power it on and attempt to load. A final tip of the library away from the player area may clear this if you hear the disks rolling out of their slots and you don't want to open the top again (it's a darned heavy box when fully loaded).
Jan 05, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Portable dvd player showing"no valid disc"
try to clean the lens using cd cleaner or cotton buds with drop of water on it. that really works.
Dec 03, 2008 | Venturer PVS177W Portable DVD Player
Canadian dvd
you can try what is called a region code hack
go here:
http://www.videohelp.com/dvdhacks/yamaha-dvr-s120/3397
Jan 04, 2008 | Yamaha DVR-S120 DVD Player
The drawer open & close function on my Yamaha DVR C300 isn't working.
could be that the rubber band is need of replacement, take it in to radioshack and they will get you the right piece, it should cost you a few dollars
Jan 01, 2008 | Televison & Video
Cyberhome dvr1600 problems
Try cleannng machine with dvd cleanner if u have staples surplus near u it only costs 10 can cn twice thiswoked for me had a same promblem.
Aug 10, 2007 | Cyberhome DVR 1600 DVD Recorder
Yamaha dvr-c300 dvd playeer
Hi sponge your lens is the problem call a tech to look at your set.good luck.
Apr 26, 2007 | Yamaha DVR-S200 DVD Player
DVR doesn't read disc, says region doen't match
check the region of the new one probably it is region 4 made in china.your disc is a region one thats the reason why it cannot play on your new dvr which is a region 3 or 4.go on the web and see hw you can hack the code or burn a copy of that same disc.then try it in your new dvr.good luck
Jan 22, 2007 | Yamaha DVR-S120 DVD Player
Televison & Video Logo
497 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
