Question about JVC MX-KC58 Shelf System
Cd spins but no light in the lens not picking it up
  • JVC Master
  • 17,129 Answers
The optical head is faulty. Do not try to look into the lens to confirm if the laser is working as you may end up damaging your eye. Try to clean the lens failing the optical head must be replaced.
If is ideal to follow procedural protocol in replacement of the head.
Posted on Sep 11, 2010
CDP cx355 cd doesn't spin
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 13, 2015 | Audio Players & Recorders
CD tray now operates perfect after belts replaced, but won't read CD's
Try 1st: You can take a q-tip dipped in alcohol (not dripping), rub the lens and gently blow it off with canned air. This will remove dust from under the lens as well. I don't recommend "lens cleaner CD's" that you can purchase as they sometimes rip of the lens.
Try 2nd: If the CD does not spin up to the proper speed, it is the motor that spins the disk. This can be temporarily fixed by disconnecting the motor wires and using a 9 volt battery to spin the motor in each direction. The trick is to reverse the direction while it is still turning in the opposite direction. This will hopefully burn off the carbon and debris in the motor contacts.
Apr 12, 2014 | Sony MHC-RX70 Shelf System
Disc player picks up CDs, puts them down, they spin and then it picks them back up without playing them.
In my experience this is usually a problem with the CD player or the CD control unit. I have had this problem with my Wurlitzer CD Carnegie and I solved it by simply taking a Q-tip, moistening it with rubbing alcohol and lightly rubbing it on the CD player's laser lens and then using the other side of the Q-tip to dry it. Over time dust and dirt can build up on the lens causing read errors, which in turn cause the jukebox to reject the CD. If that does not help, I would suggest looking into replacing the CD player or the CD control unit.
Mar 26, 2011 | Wurlitzer Jukebox CD Player
In CD mode, machine will not spin disc. Therefore no sounds can be reproduced. Has anyone else experienced this? GB
Hi
If the machine cant read a disc this would suggest either the lens of the optical pick up is dirty or the optical pick up has failed completely or something directly relating to the optical pick up i.e the spindle or stepper motor, if you can easily acess the optical lens you maybe able to clean it using a cotton bud and re-test, just try this with a dry contton bud to begin with if this gives an improvement you may wish to use a cotton bud with a alchol cleaner like I.P.A,
make light circular movements over the lens. If this makes no difference the machine requires repairing, so consult a local service engineer.
regards
Dec 11, 2010 | Denon D-A03 CD Shelf System
My DCM-360 has stopped playing discs after my moving house. It spins the carousel, picks up the disc and then puts it down without spinning the disc up. Laser problem or disc-spinning-motor problem or...
Had a similar problem with my Denon. When I inserted CD it takes it in but immediately stops - like it doesnt sense the CD. Same problem with Single or Multi changer. Removed cover, removed reader ( 4 screws) and found lens had fallen out. Cleaned, reinstalled with touch of super glue on rim - works fine.
Oct 12, 2010 | Denon DCM-360 5-Disc CD Changer
Kenwood XD-A55 CD player shows 'no disc'
The first thing you got to do is clean the laser lens maybe is dirt,witha qtip wet with alcohol clean the lens then with the dry part clean the residues of alcohol good luck
Jun 02, 2009 | Kenwood XD-A55 CD Shelf System
DVD player won't read disks
hi
you could try a dvd disc cleaner on the lens see if thats any help ,it could just be dusty on the lens ..
worth a shot.
riz.
Jun 18, 2008 | Toshiba SD-KV550
B&o sound system not working
try buying an ordinary cd lense cleaning (CD), if you are brave you can try adjustind the pick up of the laser on the laser board pot inside the cd player. it might just need a service
Nov 27, 2007 | Bang and Olufsen Beosound 2000 Shelf...
PD-F505
try a lens cleaning cd,if this doesnt work is more than likely optic (laser) faulty as laser has to focus first before spinning disc.if it cannot focus disc will not spin..
May 15, 2007 | Pioneer PD-F505 CD Player
JVC MX-KC58 Shelf System Logo
90 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
