Question about KitchenAid KUDS03FTBL Dishwasher
The dishwasher seems to be cycling - but I no longer get the flush into my disposal and I don't hear much water circulating inside the machine. Also, the soap doesn't all diappear. Any suggestions?
  • KitchenAid Master
  • 17,130 Answers
The high pressure water pump is defective and is not spraying the much required jets of water to the dishes.
This is the reason that your dishes are also not cleaned.
You might have to remove and check if the pump is faulty or a cleaning job can rectify the issue.
Posted on Sep 11, 2010
Testimonial: "Thanks. I'll see if I can check it out myself - not too savy mechanically. I appreciate your response."
  • 375 Answers
Either:
  1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, if you don't see any water at least once - check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
    Champion:
  • 239 Answers
Hmmm...sounds like the chopper may be plugged causing water movement issues. The chopper is number 6 in the diagram below and is accessed from inside the dishwasher by removing the spray arm and upper feed tube.
Whirlpool dishwasher WDF520PADM5 won't drain. It will run through a cycle, but leaves a few inches of water at the bottom.
If the garbage disposal is clogged, the water from the dishwasher cannot drain. Most of the time the dishwasher drain hose is connected into the garbage disposal. Check to be sure water flows freely into the garbage disposal. You should hear it running into the bottom of the disposal when the dishwasher drains. The line connects to the garbage disposal at the top of the disposal with a hose clamp. If you undo it take the hose off and make sure the punch out inside the disposal tube is all the way punched out and there are no restrictions in their..ie stuck food particles or something else. Unplug the disposal when working on it. Just to be safe.
Hope this helps.
Dec 30, 2017 | Whirlpool Dishwashers
Why doesn't the water draincompletely after the dishwasher cycles?
It drains as part of a cycle as does the wash and rinse cycles.
Most will drain through a hose into a garbage disposal connection. First I would check the grate inside the bottom of the dishwasher for debris them in the disposal. That issue will slow down the water from draining and timing out the cycle leaving water inside. The water when draining from the dishwasher into the disposal should be seen from above flowing out rather fast if correct. If not? The hose from dishwasher to disposal also might be clogged. This is fairly typical issue for dishwashers, when the dishes are not Cleaned beforehand.
Jan 02, 2015 | Dishwashers
Dishwasher not draining
It has a drain line that goes to a fitting on the garbage disposal or the sink drain if no disposal. It is held on with a hose clamp and can clog easily
Apr 06, 2014 | Frigidaire 18" Built-In Dishwasher
Smeg Dishwasher not circulating water
Sound like the thermostat doesn't know what the water temperature is set at.
It could be the wash pump. Check to see that the float on the bottom of the DW is unstuck by gently picking it up and setting it down { It is shaped like a mushroom and controls the water level in the bottom of the DW }. Did it move freely?
Dec 29, 2013 | Dishwashers
Frigidare dishwasher did not spin
  1. Waste Disposal/Sink trap
    • Empty your food waste disposal unit if your dishwasher's hooked up to one. If it's not empty, the old food inside it will back water up into your machine. Check that your sink trap isn't blocked by unscrewing it from the base of your sink if you don't have a food waste disposal unit. Make sure your dishwasher or any other appliances connected to it are not running when you do so.
    Incomplete Cycle
    • You may have opened your dishwasher's door mid-cycle before it's had a chance to drain. Check the progress indicator on your machine's control panel. The structure of this will differ depending on which Frigidaire model you're using, but it should show the point your machine has reached in its cycle. If this is the cause of the problem, close your dishwasher's door and let it finish.
    Drainage Pipe
    • Inspect the drain pipe that runs from your machine to your waste disposal unit or sink. If this is kinked or has been squashed under another appliance or a base unit, the waste water inside your dishwasher will be unable to escape. Check that water can flow through your waste pipe freely.
    Filter
    • Remove the bottom shelf from inside your machine and take out the plate covering the filter area. If you don't rinse your plates before you put them into your washer, food debris could block your filter and stop water from reaching your drainage pipe. You can unblock your filter with your fingers. Turn off your machine's power before you attempt to do so.
Feb 02, 2012 | Dishwashers
I have a whirlpool Adp8540 that seems to go through the wash cycle completely but when we open it up the water has not gone through the spraying arms and the soap is a solid mass at the bottom of the...
It is likely the water circulation system is faulty. This dishwasher uses a single motor to run the water pump and the drain pump. If you hear the wash pump operate during wash cycle then it is likely there is a blockage in the water circulation manifold which distributes the water through the arms.
If you do not hear the pump operate during wash cycle then the sensor is faulty. The sensor tells dishwasher to switch to drain cycle from wash cycle.
Try following the diagrams at top of this website to get idea of parts.
Oct 13, 2011 | Dishwashers
Dishwasher fills up with dirty water after completing cycle.
does the drain line connect to the disposal?if so and dirty water is inside dishwasher the line must be looped under the sink so nothing can run back into the dishwasher,tie the drain line up higher than the disposal or higher than the point where it connects to the drain pipe so nothing can drain back into the washer.are you sure the water is draining out of the machine?fill it up and hit cancel drain and listen to see if you hear it draining in the sink,if the line isn't looped you could have a block in the drain line or in the pump
Feb 03, 2010 | Kenmore Dishwashers
Stopping the Cancel/Drain Cycle
Disconnect the Drain Hose from the plumbing under the sink and using a bucket hold the hose in the bucket and attempt to drain the dishwasher. If you have a disposal and recently replaced it, the knockout plug may be still inside where the drain hose attaches into the disposal. To determine if it is still there, using a screwdriver, stick the screwdriver into the drain hose hole on the side of the disposer and if you feel blockage then the knockout plug is still in the disposer and will need to come out. To remove the plug use a short screwdriver and a hammer and place the screwdriver into the drain and strike the top of the screwdriver once and the plug should pop out of the disposal. Be careful not to hit the disposal too hard or to damage any plumbing. Reattach the drain hose and you should be all set. When you remove the drain hose if the machine is flashing an error code, go to the circuit breaker box and turn off the breaker for the dishwasher, wait 5 mins and turn it back on. This should reset the board and the machine should operate properly.
Jan 28, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Sounds like water....dx doesnt work
2H means the machine is taking longer than 99 minutes to run a cycle. Start the cycle and wait 5 minutes, then open the door. If water doesn't look like it is spraying out the wash arms or slowly coming out the wash arms, then check to make sure the filter at the bottom is clean. If clean, then sounds like your circulation pump isn't running or impeller has came apart.
Dec 16, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Water still in the bottom of the dishwasher
If there is no air gap (silver cap) located on your sink next to your faucet, you could have a clog in the drain line or at the drain port at the motor/pump assembly. Also, check to see if the drain hose (under sink) has a loop in it before it goes to the disposal or pipe. If there is no loop, water could be backing up into the tub.
Sep 28, 2007 | GE GSD5320DBB Dishwasher
KitchenAid KUDS03FTBL Dishwasher Logo
215 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
