Question about ASUS Eee PC 1000HE Netbook
My eee PC 1001A works fine playing DivX video files while AC adaptor is connected but on battery power picture is very choppy, not smooth. So, I have checked power management options and selected full power and still no good. Any suggestionss? Thanks.
  • 2 more comments
  • neil_farrar Sep 11, 2010
    I am running Windows XP and the netbook (Asus eee PC 1001A) is only four weeks old.
    It confounds me that VLC media player will only play movies smoothly with AC adaptor connected! Battery operation in any power mode is s l o w . Cheers.
    More info - Battery is new - The eee PC is only four weeks old and uses Win XP. Video. Win XP power management is set to high performance (no battery saving) and "eee Hybid engine" OEM software is set to "super performance".
    When the netbook is first booted DivX files will play smoothly on battery for five minutes. Then, the video becomes choppy. It would seem that there is some menu buried inside the netbook that is overiding the power setting chosen within XP.
    But I don't know where. Maybe within BIOS, but I don't know how to access it because boot up takes me straight to Windows with no option to enter BIOS.
    Sound like fun? Thanks, Neil
  • neil_farrar Sep 12, 2010
    Thanks for that comment - you led me to right area - I have been able to fix the problem by using Display Settings and lowering level of Graphics Acceleration.
    I am happy that it works, but I guess I still don't understand why this should be necessary only when operating on batttery power (given I have checked full power in power management boxes). i.e. Nonetheless I can't get rid of power saving slowdown in computer.
    I accessed BIOS but there is no power management or clock speed selection option there.
    Regards and well done.
    I am happy with the suggestions made. They have gone further than original request to improve performance of my PC.
    Neil Farrar, Melbourne, Australia.
  • 560 Answers
I would suspect your battery is failing . If it requires to be charged within less than half of its rated hourly service , it might not be providing enough amperage to power the VI circuit. (Voltage Inversion Circuit) If the battery is good and providing enough current , try changing your resolution and your screen refresh rate ( frequency in Hz.) located in your display settings, by selecting the advanced Option in the lower right hand corner and then display options .
Posted on Sep 11, 2010
  • Cool Blue Services
    Cool Blue Services Sep 12, 2010
    Neil, thank you for the compliment . I'm happy the video is working better . After giving it some thought , I have one other idea you might consider trying . Ready? OK Open control panel , scroll down to system and left click to open it . Then , left on the advanced option . When it opens , left click on performance and you'll see some options regarding how the computer prioritizes video functions as well as program rules memory cache, etc. Experiment with the settings and perhaps you can create an environment which is better all around . As you mentioned the computer is new , if you haven't already , be sure to update all of your software by visiting a couple of sites I will list for you . Visit : http://ww.filehippo.com and download the tool (program) called Update Checker. Be careful not to click too fast on the selection as a popup appears and offers you a free scan . Don't select that . The update checker selection download will appear in the upper right hand corner of the main screen . Download it , run it , paying attention to the default selections already checked . You can uncheck the free toolbar and search provider . Also , don't select the run at startup option . You can run it yourself from your desktop when you choose to . It works very well and is virus free . Also , visit http://www.windowsupdate.com to download all of your updates for Windows XP. Good luck with your new computer .
    President:
  • 2,777 Answers
Even at full power it will not fully utilize the CPU and VIDEO processing to it's fullest. I would suggest that you make sure all possible programs are closed aside from the divx player you are using. Also trying using a lower memory consuming video player such as media player classic (which is free) from this link:
http://mpc-hc.sourceforge.net/download-media-player-classic-hc.html
If that has the same result, you can also try VLC:
http://sourceforge.net/projects/vlc/files/1.1.4/win32/vlc-1.1.4-win32.exe/download
Between those two, one should be able to play on battery power only, without much tweaking at all.
Thanks Tim
Posted on Sep 12, 2010
  • 1,675 Answers
Hi you did not state what Operating System you are using, so i will give information relating to windows7 you have advanced settings which you can change to make the system faster while on the battery power, to do this, go to control panel, then hardware and sound, then power options, where it says select power plan, click balanced, then on the end of that click change plan settings,on the next page look for the change advanced power settings bottom left side of window, there you will find allot of adjustments you can alter , just do this until you find the right balance for what you need hope this helps
  • 905 Answers
Hello Neil,
Has your netbook always done this? It may be a symptom of a failing battery, but I wouldn't think so.
What you describe is indicative that either the processor or the graphics adapter has been slowed down to extend battery life. You might check the BIOS settings as the netbook is starting, those may be overriding software. Otherwise, check the clock speeds of the various hardware (I forget where it is in ePC's Linux) to see if the performance states really are changing.
  • Sheldon Dedek Sep 11, 2010
    When the computer is starting up from cold start (not resuming from standby or hibernate), Pressing the F2 should get you into the BIOS. If you don't see the option, press TAB to bypass the splash image. This works on some models, not sure about yours though. Wasn't able to find a "1001A" model in particular. Bios version, yes, but not model.
    There are also some BIOS updates that are available, but be careful about using them as they can break ability to upgrade to windows 7 and such.
My battery died, I plugged in the charger and the battery light flashes and then shuts off
Your battery might be completely drained. Remove your battery and and plug your laptop directly to the power outlet using just your laptop's AC Adaptor. If should now work with the battery being bypassed.
If it won't work in this way (connecting to AC Power with the battery removed), there must be something wrong with your laptop's board.
Feb 23, 2010 | ASUS Eee 4G Notebook
Uploading pictures
Cameras can't upload if low on power. Charge batteries or plug in the ac adaptor to an outlet and try again.
Sep 12, 2009 | Panasonic SDR-H40 HDD Camcorder
Will not work with ac power adaptor but does with
Did you wiggle it a bit when plugged in? You can't tell from looking on the outside if the plug is fine because it goes bad inside where it is soldered. This is a very common problem, and have fixed many laptops with the same problem. All of them had a bad solder connection inside. Did you dtermine the plug was fine by plugging another ac adapter to your laptop or you just checked it visually? Hit me up I will solve this one for you.
Aug 12, 2009 | Compaq Presario 700 470024-192 Notebook
Choppy Video Playback
it's probably the codec you're using. divx works nicely.
Feb 17, 2009 | Sony Playstation 3 (PS3) Console
Panasonic sdr-h40p cannot connect to my pc
hi all, i had exactly the same problem and finally managed to sort it out, here to share with u all. The AC adapter is the one looks like a battery cable which comes with the camcorder. You have to remove the battery first, and plug the AC adapter into the place where the battery was, then connect the other end to the battery charger. Now you can select the PC connect option and transfer your videos. Hope it helps. =)
Aug 25, 2008 | Panasonic PV-GS500 Camcorder
My computer won't play videos
You have to get proper drivers or your setting buffer for video is not set properly.
Jul 24, 2008 | Computers & Internet
Choppy result from playing DIVX via USB Direct connection.
Try a DivX movie from a disc, memory sticks are not very fast, they are just convenient.
Jan 24, 2008 | Philips HTS3440/37 System
Choppy sound and picture when I play DVD
get the divx codec http://www.divx.com/ try adjusting the advanced play back settings in media player my laptop does the same thing sometimes, a few reboots and it is ok again...
Apr 01, 2007 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
ASUS Eee PC 1000HE Netbook Logo
244 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
