Question about Samsung ML 1710 Laser Printer
Samsung ml1710 printer has both lights blinking after giving it for test print through printer button
  • 68 Answers
First, pull the tray out. Next, look for a WIDE rubber roller
right in the middle of two smaller black rollers, that's the
one you want to clean! Grab a lint-free rag (important!!),
get some alcohol. Next, dampen the rag with the alcohol and
start wiping across the wide roller so that when you rub your
finger tip across it, your finger barley budges, this means
it's completely clean. Now, here's the trick, there's a
black, thin lever that hangs down on the left side under the
bottom of the printer, this detects the paper level, it's
hangs loosely and you can push it up easily with your finger.
With the tray still pulled out, push the lever up so that the
status light on the printer turns green. Now, if you're close
enough to your computer, send one page to print while keeping
that lever pushed in. What you want to do here is watch as
that WIDE roller turns over to the other side where there is
still dirt that needs to be cleaned off. You've got to be
fast and time it right so that you can turn off the printer
as the WIDE roller flips to the other side, cause once it
gets there, you've got to turn the printer off to stop it
dead in it's tracks. Getting another person to help would be
best for this task. TRUST me, once you get that whole roller
cleaned with alcohol, it works like new!! :)
Posted on Sep 29, 2010
I need to download the printing software to my new computer for the ml1710 black ink only
http://www.samsung.com/sg/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=ML-1710
Jan 30, 2011 | Samsung ML 1710 Laser Printer
The orange light is blinking. Above the light is a triange with an exclamation point in it. I have tried deleting and reloading the printer and that doesnt work.
Do you have a new toner cartridge loaded? The red/orange light will blink when toner is low, even if everything else is working fine. Try printing out a test sheet and see what that tells you about your toner level. (Test sheep prints by holding the orange button down a second or two and releasing.)
Since I'm mainly printing drafts for my own use, I've just let the light blink while I eke out whatever I can from the remaining toner (occassionally removing the cartridge and shaking it -- being careful of clothes and surroundings -- to re-distribute the toner on the inside.
Oct 17, 2010 | Samsung ML-2510 Laser Printer
Samsung ml1640 laser red light blinking
samsung ml1640 laser red and green light blinking continuously and printing not happening
Jul 02, 2010 | Samsung ML-1640 Monochrome Laser Printer
I have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error...
By deepak_compu on Oct 06, 2009
i have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error show,but print not come. and when i print a test page from printer button it gives print. but on paper write like this toner exhoasted so what i do for this problem please give me soltuion of this problem
Oct 06, 2009 | Samsung ML-1640 Monochrome Laser Printer
Light is flashing and will not print
dude..u didnt mention printer's make n model nyhow give a try to dis one..
Remove all the cartridges and the paper from the printer...Power off the printer...unplugg the power cable from the back of the printer...while printer is unplugged from the power..press n hold the power button for atleast 60 seconds then release it..open the back door of the printer and look for any paper jam...remove paper from behind (if any) and roll the rollers in upward direction from behind..close the back door and connect the power cable to the printer and power on the printer..Look for the cartridge slots and clean it wid a lynt free cloth and the copper contacts of the cartridges as well...then insert only one cartridge (black or color) and close the cartridge door and check for any blinking lights on the printer...similarily repeat it with the other cartridge..by this u wud get to know if any cartridge is faulty? If u get blinking lights on the printer ...that means there is some problem,,,
Once you see the steady green light on the power..it means the printer is ready..You can also print a test page..."Press n Hold the power button down...while holding the power button down...either press "Down Arrow button" 4 Times OR "Red X button once"...then release the Power button to print the test print..
If it prints ..u r the master !!!
Best of luck
Remember if there is any blinking light,,the printer wont prin..
if the light blinks around the drops..it means there is cartridge issue and you may even replace the cartridges..make sure u remove the pink tape carefully before inserting the cartridges.
ALL THE BEST
May 08, 2009 | HP DeskJet 930cm InkJet Printer
HP LaserJet 1018: paper will feed, but no content can be printed
just try to print the self test of the hp 1018 printer.self pest is printed directly from the printer not by giving command from the printer. press any one of the button on the printer and hold it till the light blinks.leave the button when light starts blinking .place the paper in the tray.as soon as you leave the button .a self page will be printed..that is self test.if the self test comes out proper that means its your driver software problem.but if self test also has problem then its the clear problem of dust collected on the printer reading lens due to not using it for 2 years.so the printer needs servicing. get it serviced at local printer repair shop .
May 06, 2009 | HP LaserJet 1018 Printer
Blinking light--won't print
Best of luck
ALL THE BEST
Mar 22, 2009 | HP Deskjet 6940 InkJet Printer
Printer keeps blinking
I think its the toner low light, press the orange button to print a test page with diagnosis
Feb 02, 2009 | Samsung ML-2510 Laser Printer
SAMSUNG ML-2510 LASER MONO PRINTER
no, I have paper....the red-light on the top keeps blinking.....
I have used akums-razor to determine the answer.....
sol: push and hold down the orange button for 3-4 secs and wait for a print-out. It will give you the staus of the toner cartdg. MINE REPORTS A LOWWWW LEVEL. ( the orig. cartridge gives the user only about 1000 sheets and mine is around 783. This is why I think the light came on to tell me to jump in my Lexus, get down to Best Buy, and get another ( more capacity) new cartridge....
cool, huh?:>))))
May 09, 2008 | Samsung ML-2510 Laser Printer
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Samsung ML 1710 Laser Printer Logo
306 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
